High Alpine Lakes in San Juan Mountains, Colorado - rinkable?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 735 Times
Title should say drinkable.
I would filter. Pathogens are not my concern.
My concern is mineral content. Some of the lakes look pretty colorful and I'm sure there are lots of minerals.
Anything to be concerned about?
Looks like there are lots of streams and rivers to draw from but I was just wondering about the lakes.
-Tim-
-Tim-
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
They sold all the uranium production to the Russians, so nothing to worry about. They are great environmental stewards.
@cyccommute might have a real answer.
Mad bike riding scientist
Quoted: 6133 Post(s)
Liked 4,067 Times
-Tim-
-Tim-
Rivers, on the other hand, are much more questionable, especially around towns. Most of the towns were mining centers and there are thousands of mines draining water into the rivers around Colorado. And don’t be fooled into thinking that just because the water in a river is colorless that it is safe. Gold King Mine may have turned the Animas River orange but mines in the area drain hundreds of times the volume of the Gold King Mine into the river daily. It just happens not to be orange. It’s still toxic.
Stuart Black
Stuart Black
- Soli Deo Gloria -
Liked 735 Times
To be clear, I'm talking about lakes at >10k feet elevation in the San Juan mountains.
Sloan Lake in the American Basin is 12,900 ft.
Lake Como below California Pass and Blue Lake (below) are both at 12,200 ft.
Again, I'm not concerned with pathogens and would use a filter. I'm concerned with minerals from the surrounding land.
Is water from these safe to drink or does the color indicate minerals one would not want to ingest.
-Tim-
-Tim-
Rod & Judy
Bikes: Specialized S-works E-5, Davinci joint venture , CoMotion Pangea
Quoted: 21 Post(s)
Liked 7 Times
I like running water better, but have filtered lake water many times, Agree with cycocommute, if fish, ok!
R
R
Liked 4,067 Times
Filters don’t work on heavy metals.
It would be hard to make a blanket statement. Mining activity has occured at elevations to the tops of mountains. Animas Forks, for example, is over 11,000 feet and there are mines higher than that. Look around and if you see mine tailings, it might be best to pass. If the tailings have a very yellow or red, that means there is probably acid discharge downstream of those tailings. If the water and the ground under the water you are thinking of using is red, yellow or basically any color by dirt brown...pass.
I haven’t run across any high lakes that I wouldn’t filter from. They are generally safe but not always.
-Tim-
-Tim-
Stuart Black
Stuart Black
Quoted: 19 Post(s)
If you're not sure you can use a Sawyer Select S3 filter to remove metals. https://www.rei.com/product/123094/s...ottle-20-fl-oz
I did a Google search for the three lakes mentioned and could not find any info on water quality. Though it appears that Blue Lake is a source of water for Telluride so would imagine it is okay to drink after filtering for pathogens.
The simple, economical and safe solution is to load up with known good water from purchased bottled water or a municipal water tap, and carry in bladder(s) through areas of unknown/unreliable water supply. Arsenic and lead can do significant, lasting damage.
Liked 4,067 Times
It’s also a difficult place to ride a bicycle because it is also the highest county in the US. The Alpine Loop that TimothyH is planning on riding is not that long but the altitude kind of keeps even those of us acclimatized from doing massive mileage. Since most of the route is over 10,000 feet and on Jeep roads, doing more than about 25 to 30 miles per day is difficult. And the altitude requires more water, especially if you are not well acclimated. So you’d need to carry water for about 3 days. Based on 4 hours of activity, you need about 200 oz (2 Camelbaks full) of water per day just for riding. That’s 600 oz for 3 days plus what you might need for cooking. That’s about 40 lb. Carrying what you need probably isn’t an option.
Stuart Black
Stuart Black
Quoted: 1216 Post(s)
Liked 605 Times
Sounds awesome Tim! I did just a little googling, found a site promoting hut to hut cycling/trekking adventures. Here's a blurb from their site:
https://sanjuanhuts.com/hike-questio...he-hiking-huts
Sounds like they tell you just to grab it from nearby water sources and filter. I wonder if they test and certify those particular water sources near the huts if they're advising hut users to use the water? I'd assume they have some liability? Unless those huts are public?
Anyway sounds epic
Anyway sounds epic
Liked 4,067 Times
Filters used for backcountry travel don't work on heavy metals. A portable filter filters for particle size mostly.
Stuart Black
Stuart Black
Liked 4,067 Times
I can also see the allure of the route that TimothyH is proposing. I plan on doing parts of it myself this summer. It's not a complete poisonous hell hole. Just parts of it.
Note to TimothyH: Put aside some time in Silverton to visit the Mayflower Mill...you'll be going right past it...it's a mill for metal extraction that worked from the late 1800 to the early 1990s. It's not a museum and it's as if the workers just got off work. Really fascinating to see how metals were extracted from the ore.
Stuart Black
Stuart Black
- Soli Deo Gloria -
Liked 735 Times
I'm really hoping to go but not 100% sure. My younger daughter might go to a pretty pricey school. We'll see.
This is the general idea, only twice as long.
The Alpine Loop, Colorado - BIKEPACKING.com
Experience is worth a thousand suppositions. Thank you for the information and for taking the time to post.
I'm keeping a notebook of everyone's comments and suggestions. Yours are included.
Anyway, water shouldn't be an issue. I was just wondering about the color of the lakes, that's all.
-Tim-
It’s difficult to carry that much water. TimothyH’s ride is going to remote areas that take several days to traverse. San Juan County is sparsely populated in the extreme. The population of the county is 699 people in a 388 square mile area. The only “city” in the area is Silverton where 530 people live and it’s the only municipal water source in the area.
-Tim-
Liked 4,067 Times
-Tim-
-Tim-
Stuart Black
Stuart Black
Quoted: 92 Post(s)
If there are glaciers or snow available, that's another option. There are portable distillation devices that would take care of heavy metals and minerals. Also, it's a very different situation when you are ingesting the water for a meal or two or a day or two, vs having it as your everyday supply. We get tiny doses of all kinds of things with no problems. There is arsenic in many foods, for example. In the case of rice, the levels can be concerning if you are eating rice from certain parts of the world (including substantial areas within the US) frequently. If only occasionally, none of it is of concern.
- Soli Deo Gloria -
Liked 735 Times
The color of the water in your picture is probably due to silt. Here's an explanation of why some glacier lakes are turquoise in color. Blue Lake (one of dozens of so named lakes in Colorado...we can be boring when it comes to names) is a glacial tarn lake. If you look at the picture you can see a glacial valley curving off to the right high above the lake. Although the glacier melted long ago, water comes down that scree slope and carries a lot of silt with it. It may be slity but it would be fine to drink after filtering.
Advanced Slacker
Quoted: 2747 Post(s)
Liked 2,515 Times
