What kind of rubber is a tan sidewall?
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
The tread is butyl, right, and the sidewall is what, latex?
Anyone know if you can dye it?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 1438 Post(s)
Liked 1,091 Times
I suspect that it is the same rubber as the rest of the tire, just without the carbon black added.
Likes For dsbrantjr:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,559 Times
I've always figured it was just latex with coloring added as necessary to maintain the desired color. Tread rubber has all kinds of compounds in it for grip and durability that I doubt they would want to put into the casing.
Likes For Brocephus:
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I feel like this came up in a thread about a year ago. I remember reading an article -- maybe it was from Jalopnik -- that went into a deep dive as to why tires are black. The very short answer was that it had to do with material shortages in WWI.
But yeah, I think tanwalls just don't have the carbon black added.
Quoted: 140 Post(s)
Liked 159 Times
I suspect the same thing. The carbon black adds some UV protection, and I think that's the main reason the gumwall, tanwall type of sidewalls you see on old tires of that type are often badly degraded (dry rotted, cracked, etc), while the black portion of the tire is in much better shape.
Quoted: 4730 Post(s)
Liked 3,831 Times
That's a little like asking what kind of fabric is a red shirt. Some tan sidewalls are little more than the cotton or silk casing.with a little perhaps shellac. (I'm guessing 100 years ago, this was most tires.) Some are dyed rubber/butyl. Some are a near transparent coating over a tan colored synthetic cord. If you want a definitive answer, you have to specify the tire.
Ben
Ben
Likes For Leebo:
Quoted: 1572 Post(s)
Liked 642 Times
Back in the olden days when men were men and such things were common we used to call them "gum walls".
bike whisperer
Liked 716 Times
Liked 3,831 Times
bike whisperer
Liked 716 Times
Didn't want black, and I wanted the Corsas, so I want to try dyeing them. Vittoria's idea of tan is way too light for my taste.
I figure I can mix the dye with cornstarch or something, and smear it on and leave it for a few hours.
Apparently you can dye rubber with fabric dye? But that's not very specific, since there are different types of both.
Quoted: 4554 Post(s)
Liked 2,789 Times
The new Conti GP Classics are true skinwalls, not gumwalls, and translucent against bright light. I'm assuming that's the base for the entire tire, and the tread is laminated onto that base. But it's 700x25 clinchers only, no tubs. I just got a set, only ridden 'em twice for 15 miles each. They seem good. I'm gonna try 'em again this morning at lower pressure.
bike whisperer
Liked 716 Times
So I got some brown fabric dye. Figured I needed something to thicken it, like cornstarch, got arrowroot instead. Mixing it up, I accidentally dumped a fair bit too much of the stuff in, and it was a gluggy mess... couldn't dissolve all of it.
Anyway, I thought what the hell, and pressed on. Painted one side of each tyre, checked back in an hour, hadn't done much. Not much more another hour later, so left it overnight.
Cleaning it off was a mission, took twenty minutes or more for each tyre. After which, disappointing results were revealed. The dye mixture was about the colour of dark chocolate, and the original colour of the sidewall was kinda creamy with a slight green tinge. The dye kinda went with the green; all it really did was darken the existing colour some, to the point it just looked like an old tyre, and pretty blotchy too.
Oh well, I knew it was a cross your fingers and hope sort of scenario... and come to think of it, since this is my first set of tubulars since the 90s, I'll need some spares. Ordered another pair in anthracite.
Señor Member
Quoted: 648 Post(s)
Liked 290 Times
I don't think there is much real rubber in modern bike tires - they are mostly or completely made from synthetic polymers. I could be wrong about this, so please tell me if I am.
Anyhoo, polymers are all colourless in their natural state, if my college materials course recollections are correct. Carbon is added to the tread portion for duability (I think) and any other colour in your tire aside from clear or opaque whitish are added just for looks.
Likes For TimothyH:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 735 Times
They smell amazing and perfume the entire house when they are delivered.
It reminds me of my father taking me to get new tires on the family car when I was a wee lad.
-Tim-
Disco Infiltrator
Quoted: 3124 Post(s)
Liked 2,101 Times
Aren't most tires of any sort made of natural rubber? Butyl is for keeping air in.
Edit: about half of production is natural rubber, the other half is styrene-butadiene.
Genesis 49:16-17
Genesis 49:16-17
bike whisperer
Liked 716 Times
Yeah, I already sort of knew that in the back of my mind, but when it said 'tan' on the website, I was like, oh hey, cool. Pff
