Tandem Trike revisited.
Hi folks,
I'm a trike rider and have been for many years.
I also own a George Longstaff tandem trike, now that the kiddies are getting older I decided to take the dust sheet off.
Went for a little spin with my daughter and son.
The plan for this year is daughter 6 and petite up front and son nearly 10 stoker.
I ordered crank shorteners from St John Street Cycles in the UK.
So this time next week we shall be up and mobile and I can intice the kiddies away from multimedia for a few hours
I enclose a pic so you get the idea.
Regards from JD in Belgium.
Quoted: 77 Post(s)
Liked 19 Times
Belg:
Tandem trikes are a bit of a rarity here in the US; but have seen a couple recumbent trikes.
Where are you located in Belgium? Vlaanderen area?
Pedal on!
Rudy and Kay/zonatandem
Pedal on!
Bikes: Road, Hybrid, Tandem, Mountain, Gravel
I've often thought if I were to lose my balance, I wouldn't hesitate to purchase a tandem trike.
Quoted: 2494 Post(s)
Liked 738 Times
H
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
3 wheeled vehicles, particularly with one front wheel are inherently tippy. At low speeds, the intial stability of an upright trike is great. It won't tip over at all at 5mph, unlike a bicycle.
Cornering at 25mph downhill is a different story.
You could get lost and die.
You could hit a tree and die.
Liked 738 Times
H
pan y agua
Liked 724 Times
No, I meant what I said; they are inherently tippy. Because you only have one wheel in the front, it tends to tip over in the direction of centrifigul force.
As to whether they're more or less stable than a bike, the distinction I'm making is between initial stability and ultimate stability. A trike at low speed has very high initial stability and won't tip or lean, but once its starts to lean, it is much less stable than a bicycle.
A bicycle has low initial stability, in that it will lean over very easily, but it has greater ultimate stability because you manage the forces on the bike by leaning, and you can control the lean.
It's similar to the difference between a flat bottom kayak, and a rounded bottom kayak. The flat bottom kayak has great initial stability, and feels more stable, but when it goes over it goes over quickly with less control. Whereas with the rounded bottom kayak, you can control the lean, and while it feels quick to lean its ultimately more stable.
Happy to see a bit of banter re trikes in general.
Rule 1 of trike riding "Never take your trike for granted"
On to the business in hand. The crank shorteners from St John Street Cycles arrived. They are very well engineered and finished.
I enclose a pic.
Managed to get senior junior away from his tab and went went for a spin. He really enjoyed himself and said he'd like to come out again.
Junior junior is too small so I plan on getting a trailer bike so the tandem trike will become a quad.
Enclosed a pic of senior senior and senior junior.
Regards from Belgium.
I enclose a pic.
All sorted now. Really going great. Its me and the kids out everyday and they really look forward to it. I like tandems because as a serious cyclist of nearly 43 years on the saddle its great to get the kids out and cover some kms.
Tandems are great but tandem trikes are trice the fun.
Enclosed a pic.
Enclosed a pic.
Uber Goober
In the UK, they, to some extent, have lightweight racing trikes. Those are pretty well unknown in the US. The only upright trikes in the US are primarily intended seen as an old-person's ride, with the stability issues noted above. One of those trike manufacturers, Worksman, does in fact make a tandem trike. But it is a tandem version of a heavy upright trike, and not a 3-wheel version of a tandem road bike.
The arrangement above looks like lots of fun.
groverdill
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
17
11-04-18 04:14 AM
