Problems unclipping - Assioma Favero
Bikes: Bianchi Veloce and a custom-made Commonwealth (Medford, MA)
Quoted: 22 Post(s)
I had the extremely distressing experience yesterday of being unable at one point to unclip from EITHER pedal on my Assiomas. Earlier, only the right foot would not come out with normal pressure. I had to find a wall, ride up to it, lean on it, and pull violently to get out. This must be like the feeling of a pilot who cannot get his landing gear down.
The cleats (red Look) are not worn. I'm unsure that the float mechanism in the pedals resolves this, but I did loosen them and, since I only had two miles to go, while tentatively it worked, I can't be sure it's a permanent solution.. I do not, of course, want to have the inverse problem.
Is it logical that something like this can happen - the mechanism actually becoming tighter? I would have innocently though that the inverse would happen with wear, or whatever other mechanical influence.
Thanks
Thanks
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
Thanks
Thanks
Quoted: 2026 Post(s)
Liked 1,095 Times
How old are these pedals and cleats? How many miles prior to the problem?
Quoted: 152 Post(s)
Liked 173 Times
If they are the original Assioma's with the silver spring there were many complaints that the pedals were too tight for some people to comfortably unclip. Last summer Favero made a change and started using a lighter spring (black in color) that resolved this issue. You can retrofit the black spring version for the original pedal bodies but would need to purchase new bodies. If you have been riding them without this issue before I would do and thorough cleaning and light lube to see if that helps. I have the black spring version and find them very easy to unclip from even in my gimpy left leg that has problems uncliping. FWIW, I ride the 0° float black Wellgo (xpedo) cleats.
Quoted: 22 Post(s)
The pedals are about a year old (2,200 miles) and I don't remember when I changed the cleats, but they are not worn. I use them on my other bike on the Cyclops and the movements are smooth there.
Quoted: 22 Post(s)
Thank you. I have to look at that spring mechanism. I hadn't paid too much attention to it.
I found that the original Assioma cleats are the only ones that actually worked with my pedals. I had real Look Keo cleats on my shoes when the Assiomas arrived about 2 years ago and I couldn't get them in or out easily. Luckily I was on my trainer trying this out. I swapped in the Assioma cleats right away and while they were tight I could get in and out. When I took the bike outside the first few times I would ride with my right foot unclipped in traffic. Eventually though everything wore in enough that it became easy, although when I needed new cleats I bought another pair of the Assioma ones again, but they weren't nearly as tight even when new.
The other thing with the Assioma pedals, and probaby all pedal power meters, is that you can't unclip by twisting your heel towards the bike as the power pod gets in the way. It may not have been the right way to do it, but I was used to being able to go either way. My fear was that I'd join club tombé. I got used to it pretty fast.
Thanks
Thanks
Quoted: 22 Post(s)
SpeedyTurtle -
This happened quite a few months ago, and I do not recall anything other than that it was indeed resolved by loosening mechanism on the pedals, as odd as that may seem. That said, since then, I've had another peculiar problem - and I'm not sure if this relates to the pedals or not, but I've never experienced this before - some screws in the cleats themselves get loose every so often, in fact too regularly. This could be a coincidence, but...
Quoted: 112 Post(s)
Liked 25 Times
I have the same problem with the red cleats and tension adjusted to min.
The springs are black.
This situation has not improved after 2 years of use.
As the cleat wears it becomes easier to unclip.
On new cleats I am only able to unclip with the pedal at 6 o'clock position, and still with considerable difficulty.
This situation is quite dangerous if you suddenly need to unclip.
Quoted: 112 Post(s)
Liked 25 Times
SpeedyTurtle -
Quoted: 112 Post(s)
Liked 25 Times
Recently, replaced old red cleats with new.
I tried unclipping, even with the pedal at the 6 o'clock position, it was very hard. Tension was adjusted at minimum.
Then I lubed the side sliding surfaces of each pedal with light oil, and the situation improved substantially.
