Wind noise?
Bikes: 70's frame, newer parts
Quoted: 92 Post(s)
Liked 38 Times
Wind noise?
Is it just me or does this happen to everyone? When the wind speed over my head is up to maybe about 18 MPH the wind noise is loud enough that I don't hear much else.
I have an older bike with friction shifting so I like to listen for chain noise and move the shift levers to minimize the noise. The other day I was trying to listen for a squeak in the crank and then another time it was a once per tire revolution noise I could not hear. The solution is to wait for an uphill section where I slow.
Two days ago I was riding downhill at about 24 MPH (I'm a chicken on residential streets with driveways and intersections.) and some guy had to say "on your left" maybe five times before I noticed. (He was smart enough not to pass until I did notice then disappeared)
Another issue is tire and drivetrain noise from another bike. I can hear a bike following me if we are going downwind but in a headwind I'm deaf.
I wonder if different helmets are different in the amount of wind noise we hear. I know as we get older hearing is not so good and I am over 60 but I hear these things at low speed with no problem.
Quoted: 4559 Post(s)
Liked 2,802 Times
Yeah, I'm a little concerned about wind noise, mostly to preserve what hearing I have left. It's still pretty good in my right ear but I've lost a lot in the left.
Helmets can create wind turbulence noise and vary a lot between designs. Subjectively, while my POC Omne Air Spin is cooler and better vented than my Bell Formula MIPS, the POC seems to produce less wind turbulence noise. The vent designs are very different.
I occasionally mount video cameras on my helmets and can hear significant differences in wind turbulence. The camera mics can screen out most wind noise from itself, but it picks up whatever turbulence is created by where it's mounted -- stem, seat post, helmet, etc.
I added a set of AirStreamz Cat-Ear Classics, their thickest, to the straps on one helmet. Helps a little but not as much as I'd expected. I wouldn't bother with their smaller, less obtrusive versions.
I got more wind reduction with a $5 set of ear warmers from Walgreen's -- it's just a thick layer of breathable wicking fabric similar to the stuff my Bontrager RXL Thermal gloves are made of, in a springy headset that's comfortable and lightweight. But I don't wear 'em year-round. Probably the same material used by AirStreamz Polartec ear warmer doodads that fasten to the helmet straps.
I've also noticed slight differences in wind turbulence noise depending on the doodads attached to the helmet. I removed the video camera plastic mount from my POC Omne Air Spin before my ride Sunday and it seemed quieter, despite a very windy day (20 mph steady with gusts to 35). I was still wearing front and rear helmet mounted blinkies, although I didn't use them since I was riding in daylight. Next daylight ride I'll omit all the helmet doodads and try again.
I also have an aero helmet with minimal vents and a snap-on cover that blocks even those tiny vents. And it includes a magnet-attached tinted visor, to replace sunglasses. Subjectively, it seems quieter. I don't wear it often. Might try again soon while the weather is cool. It's a rounded shape, not one of the time trial/tri-bike aero helmets with elongated tails, so it doesn't look out of place on a regular road bike ride. Giro and others make this style for folks who don't want a full-on competition style aero helmet. I mostly got it for tackling Strava PRs and it does seem to help a bit, along with aero fit jerseys, etc. But the harness and strap aren't quite as comfortable as my POC and Bell so I don't wear it often.
There are also all kinds of noise-cancelling headphones, ear buds, etc., all claiming to reduce ambient noise while allowing other sounds to pass. They were originally designed for reducing impulse/impact noises for shooting ranges and similarly noisy environments where wearers still needed to be able to hear range commands, etc. Not sure if they're suitable for bicycling.
Theoretically, we could wear earphones or ear buds that exclude most sound the ear would normally pick up, and replace them with a microphone strategically placed where it would be out of the wind. For example, behind the wearer -- clipped to a jersey pocket, seat post, etc. That might work for folks with tinnitus or hearing impairments who want to hear approaching vehicles. I do know from running a rear-facing camera (Drift Ghost-X) that it picks up very little wind noise from the seat post mount. So it's plausible that a wireless mic there transmitting to ear buds could be useful.
I suspect helmet shape plays a part and also angle of helmet.
I listen to music when I ride. Generally, I set my Pandora to an artist and when a song comes on I don't care for, I take my earbuds out and listen to my bike. Sometimes I have to look down more to hear my bike. Other times tilt my head to the side or turn my head s little. Or even tip my helmet up with my hand. Just depends on direction of wind and direction I'm headed.
Fortunately and usually it's not overwhelming wind noise. Once again my relatively inexpensive giro helmet helps...I think.
Of course, because I listen to music while riding I worry less about wind noise, however with some earbuds you still hear wind noise.
Quoted: 73 Post(s)
Liked 41 Times
The "right" large glasses and helmet for you, can make a substantial difference in wind noise
Not just and aero helmet, or what a friend may recommend, but a setup that works well for your head/face
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
There's nothing you can do about it. Do not, under any circumstances, wear anything to dull your hearing while n the bike. Especially headphones.
Likes For dmanthree:
Quoted: 642 Post(s)
Liked 1,526 Times
I have moderately bad tinitus, and wind noise aggravates it quite a bit. I've tried the small cat ear things that go on the straps and they provide minimal protection. The winter cat ear things that go in between the straps and cover your whole ear work better but if it's not cold out, they get hot.
there are also attenuators, basically ear plugs designed to just reduce the db level as opposed to blocking out everything. I've tried a couple of different ones. One was really bad and the other worked pretty well. The only issue with those is if you start getting sweaty, they can fall out pretty easily. At this point, i just accept that its there and try not to think about it.
Regardless of whether you do anything to reduce wind noise, I would highly advise some kind of mirror that you can look at periodically so you'll see people/cars coming up behind you. I find this so valuable I have a hard time riding without one.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
My wife and I got helmets with the magnetic snap-on visors and find them much quieter.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,034 Times
I always ride with headphones. It helps cut down wind noise very well. As an added bonus I can listen to music. As another bonus I can take phone calls without stopping my ride. As an additional bonus it stops the wind noise from damaging my hearing.
Quoted: 1068 Post(s)
Liked 785 Times
"..........Florida, however, is one of only just a few states (Maryland) that make wearing typical headphones and earbuds while riding a bicycle illegal........"
The circumstance is you're on country roads,you're riding alone, and you're tired of hearing nothing but wind noise.
Earbuds are the only sustainable way to eliminate wind noise from any direction.
I've ridden with earbuds since I started riding in 1985. The only time I don't wear them is when riding with someone else, And if I'm gonna be riding in town where there is a lot of stop and go traffic. However....
Where,and when I ride (country roads, FM roads) I'm gonna hear mostly wind noise and frankly I'd rather hear music.
Likes For texaspandj:
Yes, you can wear earbuds, it will cut down or completely eliminate wind noise.
Headphones are the only sustainable way to eliminate wind noise from any direction.
I've ridden with headphones since I started riding in 1985. The only time I don't wear them is when riding with someone else, And if I'm gonna be riding in town where there is a lot of stop and go traffic. However....
Motorcycle riders often wear earplugs because wind noise at motor vehicle speeds will cause hearing loss over time. I'm not sure if bicycle speeds could have the same effect.
i can tell you from experience that foam earplugs don't make it so you can't hear, they just cut the level down a little
I could see over the ear headphones cutting the wind noise, but I don't see many folks riding around with those :-)
Quoted: 608 Post(s)
Liked 352 Times
Interesting question and interesting responses. I don't have this problem yet, but probably will at some point. My hearing is deteriorating as a I age.
If it is an issue with the helmet, I wonder if an experiment is in order. This won't be popular but try riding without a helmet for one ride. Yes, there is risk but be extra careful and even more diligent than usual. Listen and note if there is less or more air noise. If it is the same, no point in looking at different helmets. Maybe it is something that just isn't fixable.
Though this won't help you with the person behind you trying to overtake you but there was a discussion on another thread about the Garmin Varia which might augment the hearing you do have on approaching vehicles.
Oooooooofffff SALESMAN!
What are some of the quietest helmets on the market these days that won't break the bank?
Ear plugs are better than headphones, you don't cut down on noise when you just drown it out with a louder noise
The tips i can give about using earbuds and listening to music is make sure you get proper fitting ones. The new rubber type ones are a hit and miss type thing. The foam ones were really good but I can't seem to find them anymore. And lastly only listen to GOOD music.
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
So funny, I was thinking about this yesterday. I normally average only around 16 mph, but during the stretches where I'm at 24 +, I've noticed the wind noise as well. And it's night and day whether I put my head down or look up. It made me wonder about the pros who average in the 28 mph range... I wonder how they deal with the constant noise. They don't wear headphones or anything either (I wonder if it's a lot quieter inside the peloton)... My guess would be yes, but I wouldn't know as I've never ridden with anyone else.
Anyway, I use the Apple AirPod Pro (in my right ear only). They have active noise cancelling but I don't use that feature so I can hear what's around me. Regardless, when you're above 24 mph, headphones or not, you can't hear much.
I wouldn't use the earbuds if I rode in the city though (my normal route has a very few opportunities a car can turn in front of you).
Regarding long term hearing loss, I've spent years in semi-loud environments at work. It's not the loud spikes in noise, it's the constant drone over hours and hours a day that I've seen affect people (in the long term). I'm not sure a few hours a week on the bike would hurt you, but if you already have hearing loss, I can see a valid concern.
Likes For Racing Dan:
Liked 2,802 Times
Same principle used in designing aero kit -- skin suits, helmets, bikes, etc. Wind tunnel and computer modeling revealed some non-intuitive results -- a little disruption of the air flow can often be more efficient.
But it still requires testing or experience. I suspect the reason some folks have differing impressions of turbulence noise from the same helmet may be due to their preferred head/neck angle, ear shape, hair length (or bandannas or other head covering), etc. My older Bell helmet had a short flared tail extension that was popular with helmet designs in the mid-2000s. I could hear and feel slight differences depending on my head/neck angle. My POC helmet has no tail extension and seems less affected by head/neck angle. Same with my rounded aero helmet.
But riding the middle of the pack is risky in other ways, otherwise every rider would want that position in the peloton. It's easier to be trapped in a wreck, or be unable to respond to a breakaway. That's why many teams rehearse team tactics until they operate like clockwork, protecting the leader from wind resistance while rotating around him taking pulls. They work hard to prevent infiltrators from other teams disrupting the rotation, or boxing in the leader just before a mountain attack, etc.
A few folks I ride with use a generic product similar to Windblox (look it up - I can't post URL's)
I haven't used it but feedback seems positive.
Quoted: 174 Post(s)
Liked 177 Times
Sounds terrible.
Likes For Ross520:
Quoted: 762 Post(s)
Liked 4,034 Times
Other riders passing me? Right!
Quoted: 174 Post(s)
Liked 177 Times
No, not at all. I don’t listen to the music load enough to damage my hearing. The phone calls are few and with people I enjoy talking to. Cars approaching, I don’t usually hear. Same as when I don’t have ear buds in place. And what would I do differently if I heard them approaching?
What would you do if you knew a car was approaching? I’m surprised such an experienced rider doesn’t know the answer to that question.
And I’m sure you’re quick, but there’s always someone faster. Do you hold KOMS on every single segment in your area? I’d assume not, which means you are always at-risk of being passed by a faster, or fresher rider.
If you can hear a car approaching from the rear what difference does it make? However, if you can tell by the sound a car makes whether it's going to hit you or not, you are incredible.
Also, do you drive with the radio off too?
What about people who are deaf, how are they able to ride a bike?
Quoted: 762 Post(s)
Liked 4,034 Times
Most people don’t realize how loud earbud music actually is, especially considering you have to compensate (volume-wise) for road/wind noise and deep breathing.
Whether a car is approaching or not, I do the same thing. I try to hold a straight line. Do others really ride on the road looking back to see where each approaching car is? I trust that they see me and my blinking taillight and that they don’t want to hit me. If they want to hit me, I’m not going to be able to out maneuver a car. That leaves distracted driving. Do others really look at each approaching car and wonder if they’re going to try to jump the curb to avoid it? Maybe the drivers here are particularly respectful. If I thought I had to be aware of every single passing car in order to survive, I’d just ride the trainer at home.
The comment about not getting passed was humor. Even so, in about 65-70 hours of riding per month I get passed by one or two other riders per month. There just aren’t that many riders out when I’m riding. But there again, is passing another rider so dangerous? I just ride in a straight line, if another rider passes me, I trust him to do so safely.
Quoted: 4806 Post(s)
Liked 3,928 Times
No respectable cyclist would be caught dead using them but they do work. Google Cat Ears. Probably first hit. (Was on Duck Duck Go.) I've never used them but can only make that same excuse. This might get me off my duff.
Ben
Quoted: 174 Post(s)
Liked 177 Times
Also, operating a metal cage in the traffic lane and riding a bike on the shoulder are apples and oranges. But to answer your question, I listen to music at a reasonable volume, it is never too loud to hear horns or sirens.
