How many Head-Set Spacers are too many?
Quoted: 702 Post(s)
Liked 672 Times
The owner of this bike insists the fork is original, I'm not so sure...
Quoted: 4511 Post(s)
Liked 6,378 Times
Depends, I did this on purpose for better reach later on.
Can't imagine the Raleigh came that way.
Quoted: 702 Post(s)
Liked 672 Times
That is one artfully crafted cluster !
I don't even know what question to ask first....
Likes For ofajen:
The short answer is 2.
There was no reason to stack spacers BITD with quill stems. It just was not done.
Likes For Salamandrine:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
That's a one-year-only Raleigh International Mk.II. Japanese made and liquidated through Michael's Cyclery when Raleigh USA was taken over by Huffy and sold only as framesets. See: https://www.bikeforums.net/classic-v...onic-bike.html
As such, the fork is correct for it and the paint original. There's no reason to assume the fork isn't original except for the stack height, but the chances of a nicely kept International Mk.II being reunited with another International Mk.II fork is pretty difficult, even in these days of the world wide web.
Charles Wahl bought one new, so perhaps he can explain whether they came with extra steerer for the assembler or not. If not, I'd take a guess that something happened along the line where there was a missing or damaged fork on a frame and Michael's substituted one from a frame the next size up for delivery.
I have no reason to doubt the owner's claim.
-Kurt
-Kurt
Likes For cudak888:
Yeah, despite my comments above, I don't doubt that it's original, because that was a weird period for Raleigh. A pro shop would have chopped the steer tube to the correct length before putting it out on the floor, but if it came that way out of the box, I suspect many if not most shops would not have bothered.
Liked 4,395 Times
-Kurt
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,482 Times
Liked 6,378 Times
Here's the build thread if you want.
https://www.bikeforums.net/classic-v...-decide-4.html
Yeah, I think that's likely. I'm not a Raleigh guy, but that does look like a frameset plus random parts type build. It appears to be a Raleigh fork, but for the wrong frame, or more likely it was built up from a frameset by an amateur, and they simply didn't figure out that the steer tube needed to be trimmed. .
Liked 4,395 Times
-Kurt
Quoted: 4722 Post(s)
Liked 3,036 Times
As previously noted by Kurt, the fork is OEM and these frames were part of the liquidation of Raleigh stock that Huffy refused to assume when they obtained the Raleigh license for the USA in late 1982. We've seen enough of them with properly sized forks to know that the subject frameset is an anomaly.
When originally manufactured, these were not intended for sale as framesets but as bicycles. However, due to the timing of the deal with Huffy, they were caught in limbo and it was decided to liquidate then as framesets. There are several possible scenarios that could cause such as mismatch but the most likely is that an employee at Michsel's Cyclery simply selected the incorrect fork when preparing a shipment for a customer order. When these were shipped from Japan, they almost certainly would have shipped in separate crates for frames and forks, with the matching being performed at Michael's Cyclery.
Edit: Given the height of the OP's stem, I think he lucked out. The slightly longer steering column mitigates the tall stem effect..
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
I own one of these, and built it up as a gravel bike.
It really only clears 35 in the rear, though. I tried 38s, need them here, but no mud clearance. Any frame guys out there that would like to do a chainstay crimp for me?
That's a low stack headset on the OPs bike, and on mine, I had no issue putting a centerpull hanger on with whatever headset I had in the parts bin. So I don't think this frame was designed/built requiring a low stack headset. I'm going to have to check to see what I do have installed.
EDIT: I checked out the other thread, with that nice spec diagram, and the designed stack height is 46mm. The Tange headset pictured is shorter than that spec.
Likes For Ex Pres:
Disraeli Gears
My Raleigh from Michael's Cyclery had a steerer that was just long enough to fit a Campagnolo Super Record headset, with it's taller alloy spacer replaced by a thinner chromed one.
My guess is that the frame was sold to someone out of a place like that (if not Michael's) with a fork for a larger frame.
I passed that frame on to Neal Lerner almost a decade ago, don't know whether it's still in his rotation. But it lives on in his Flickr and mine. It was fun to ride, but too small for me; my first "serious" bike.
Here's the OP's Raleigh, I think:
-Kurt
-Kurt
Quoted: 2363 Post(s)
Liked 1,749 Times
(Gotta wonder if that bike spent its service life with zero spacers, and the lock nut mashed directly to the top race.)
Disraeli Gears
Oddly, though, the number of spacers is 5, only 4 more than would be normal. Even if each is 3 mm thick, that's only half an inch, but the chart above suggests that they were sold in even inch increments. So the question is: what bike did that fork fit correctly?
Quoted: 702 Post(s)
Liked 672 Times
After seeing the elegantly designed and crafted head-tube cluster owned by merziac , and reading some the comments here, I'm starting to think that the original owner may have been a mechanic who wanted a smaller frame with a taller steering column.
Disraeli Gears
Good catch! Who builds bikes to have that sort of stack height? I don't have any like that! was there some fixture one was expected to use on a touring bike, like a tall brake hanger or decaleur? One question for the OP: is the steerer overthreaded enough that it could simply be cut down to a size that required 1/2" less spacer stack?
Edumacator
Quoted: 2439 Post(s)
Liked 3,124 Times
Some stack heights are funky when replacing a headset with something different. More often for me, I can't fit the top nut on and have to find a lesser stack headset. But a few times I have used extra spacers...as Ex-Pres stated.
I think it's much more likely that a home mechanic assembled it from the frameset, noticed the steer tube was a little long, but lacked the confidence and/or the hacksaw to trim it the right length correctly.
Flash forward to the here and now, and there's no reason not to trim it down correctly, and use one spacer. Given a few decades of hindsight, there isn't any harm in some extra 'stack' either. The only possible issue is that the expander of a vintage quill stem might end up in the threaded portion of the steer tube. That should be avoided.
Thanks cudak888 and T-mar for the information about these framesets.
Quoted: 702 Post(s)
Liked 672 Times
While that is possible, I think it is extremely unlikely. Extra 'stack' just wasn't something that was done during this time. As always, there's probably an exception out there somewhere if you look hard enough. At most a washer might be added to compensate for a removed CPSC reflector or center pull cable stop hanger, but even then the correct way to do it would have been to trim the steerer.
Given the higher than normal positioning of the stem, it's "plausible" that the extra stack height was chosen to facilitate higher handlebars.
I'm not negating anyone's opinion here, just stating my own.
If that technomic stem is original, then the original assembler clearly was going for a higher handlebar position. It's possible or even probable that the builder figured there was no logical point in chopping the steer tube. Those stems are long enough that the wedge would be in a safe place even with the extra washers. (I suggest that this be verified)
AFA my estimate of the likely hood that a pro mechanic did this, I repaired or otherwise worked on thousands of bikes during this period, and never saw that many extra washers on a headset. Therefore, the conclusion that it is unlikely. But there it is with a big stack of washers, so obviously someone did it.
Quoted: 702 Post(s)
Liked 672 Times
