mismatched brakes
mismatched brakes
my nephew has a Marin Gestalt all road bike, i am going to send him some upgrade parts, thinking about the brakes. right now, he has Promax Render disc brakes. TRP HyRd would be a big improvement, but i'm pretty sure the rear triangle is too tight for the caliper.
has anyone setup up a bike with mismatch braking?
specifically, i'm thinking to pair a TRP HyRd front with TRP Spyre rear. the Spyre is not as good as HyRd but still an upgrade, i think, and he would still have a pretty good front brake, at least as stout as you can get with a cable disc. but i'm not sure about how they would feel at the lever, comparatively. personally, i need both levers to feel the same, so i assume everyone does and i don't want to make it weird for him.
any feedback would be appreciated.
Quoted: 850 Post(s)
Liked 344 Times
I believe shimano rim brakes are mismatched out of the box. The rear caliper has less mechanical advantage than the front and is therefore harder to lock. I bet 70% of riders who have these brakes don’t even realize it.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
I had Spyres front and rear and found them to be excellent. I don't know if the HY/RD has the adjustability of the Spyre to avoid rotor rub, FWIW.
Likes For shelbyfv:
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
The 2006 Chorus brakes on one of my bikes are like that. The rear brake looks to be SINGLE pivot, versus the dual pivot front.
Quoted: 550 Post(s)
Liked 325 Times
Yes. Like many Campagnolo riders, I use a dual pivot front brake with more mechanical advantage than my single pivot rear.
Campagnolo introduced "differential brakes" in 2001 so Record brakes could weigh less than Shimano Dura Ace. It's been the standard setup on the top 2-3 gruppos since then.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I guess I don't understand what you're trying to say about "feel the same at the lever". I have cable disk brakes and simply adjust them so they feel the same front and rear. Align the pads and set the adjustment for the pull distance on the lever that you like. The biggest improvement I found in braking ability was swapping out those stock pads for organic resin. They're quieter and offer a much improved stopping performance. They don't chew up your disk's as fast as the metal composite pads either. It's nice that you're taking an interest in your nephew's riding.
Likes For Bigbus:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I don’t believe that is true now. I’m certain that it hasn’t been true in the past. There is nothing different mechanically between the front and back Shimano side pull or cantilever. There isn’t anything different dimensionally either. Rear brakes tend to be a little spongier than front brakes because of the longer cable run and cable housing but they don’t have to be.
Stuart Black
Stuart Black
Liked 4,218 Times
Untitled by Stuart Black, on Flickr
image by Stuart Black, on Flickr
I’m not sure now a hydraulic...even a hybrid hydraulic like the TRP Hy/Rd...would match with mechanical brake. It might be hard to moderate both brakes the same.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 850 Post(s)
Liked 344 Times
Also the rear isn’t more spongy. It’s less spongy. It feels more stiff under braking, and there’s marginally more clearance between the pads and rim at the rear than the front.
I could be imagining all this but it seems like a very random thing to imagine.
Liked 4,218 Times
Hm. Based on my crappy measurements, it seems like the front (R7000) caliper has 1/8” longer arms than the rear. The difference isn’t massive.
No other type of brake...Shimano or other brand, cantilever, linear or disc...detunes the rear brake nor even designates where the brake is to be used. In other words, there isn’t a front or rear cantilever, linear or disc brake caliper. Reduction of mechanical advantage would almost have to happen at the lever and if that were being done, there would need to be designated front and rear brakes for all brake systems.
Stuart Black
Stuart Black
Quoted: 850 Post(s)
Liked 344 Times
Clearance from pads to rims is based on cable tightness and is set by the mechanic or user. Shimano only lists one number for reach which is the measure from the pivot point on a side pull to the maximum possible distance on the brake pad. The pads can be adjusted up and down as needed but, again, that is set by the user or a mechanic. Generally, the frame and fork and the position of the attachment point of the brake set the position of the brake pads.
R7000 has separate front and rear brake calipers...
And by arm length I don’t mean pivot to pad. I mean pivot to cable attachment point.
And the clearance depends on the cable setup, yes, but if the lever bottom-out point is the same left and right, then the clearance should be the same on both calipers.
I could still definitely be wrong. I’ve never seen anyone else mention the difference, and I don’t see any mention of front vs rear in the manual besides “Front brakes cannot be installed as rear brakes and vice versa.”
Regardless, my opinion is that a stronger front brake is not a problem.
Randomhead
Liked 3,698 Times
Braking between front and rear is different enough you have to adapt to it anyway.
Quoted: 576 Post(s)
Liked 1,002 Times
Quoted: 4259 Post(s)
Liked 1,360 Times
The question seems to be whether the brakes should be the same model.
The answer is obviously no.
Front and rear braking is inherently "mismatched" functionally. You use them differently. They are never going to "feel the same".
The front and rear brakes of a "matched" set might not be constructed the same. But the don't typically seem to be.
You probably don't want them to work too differently.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I think your braking habits would very quickly adapt to it, I find the braking characteristics vary a lot from bike to bike, and after about a couple test stops, I'm all set. A front and back mismatch, by design or otherwise, wouldn't be a problem for me as long as the front is the stronger one.
Likes For livedarklions:
Quoted: 1074 Post(s)
Liked 295 Times
For people wanting to put modern brakes on old bikes, there are after-market bolts one can buy to make the install easier.
The presumed front brake gets used as a rear, since the stubby bolt for the ”new” mounting method reaches through the average ”old” method brake bridge. Then the even stubbier bolt on the intended rear brake is replaced with a longer one that allows for the traditional, standard nut, through-mount of the front brake.
With that said, front double pivot and rear single pivot is not that unusual.
Not that this IMO makes it in any significant way a rear specific brake. It’s simply a brake nowadays primarily intended/expected to be used at the rear.
Some will happily use them at the front b/c they’re a tad lighter, b/c that was what they had, b/c the rider prefers the look, or b/c that was how some famous cyclist decades earlier rode. Or any number of other, less obvious reasons.
Re:R7000 - I know what ”reach” is for a caliper brake. But what is ”drop”?
Liked 1,360 Times
I suspect the optimization process tends towards front and rear brake that are almost the same but not too strong.
If you make the rear "more effective", people will want the front to be the same. If you make rear "less effective", people will want it to be "better".
Likes For njkayaker:
Quoted: 576 Post(s)
Liked 1,002 Times
MTBs in general have used mismatched brakes over time; starting with U/Rollercam rear + canti front, to V rear + front disc, to the current meta of running a smaller rear rotor, and even flat mount rear+post mount front. Now that I think of it, I ran a low profile rear canti (Dia Compe 987) with a mider profile canti (Ritchey WCS) up front in the early 90s. They were both cantis but one used cone wrenches for spring tension and the other used a tiny allen key; both ran the same pads. Some modern brakes like the Avid Ultimate allows one to change the profile.
As others have said, you will get used to it. But, I'd just run the best matched set I could to run the same pads f and r.
Likes For DorkDisk:
Liked 4,218 Times
https://www.merlincycles.com/en-us/s...rs-117080.html
Stuart Black
Stuart Black
Liked 4,218 Times
Not many brakes have adopted that kind of set up. I suspect that there is little advantage to it and lots of manufacturing and distribution headaches.
Stuart Black
Stuart Black
I have Mafac tandem front cantilevers and their shorter Criterium rear ..
& TRP Hy Rd Front & Avid BB7 mountain rear & Avid speed dial brake levers for both..
It works .. physics of a decelerating mass , makes the front brake more effective anyhow..
I'm going to be another voice telling you it's OK to be mis-matched. The braking capability is different between wheels anyway. I have three bikes that have one wheel with a disc brake and the other with a V-Brake and they work fine. Just be sure to get 2 road calipers or two mountain calipers, so the pull ratios both match and you can at least have matching levers on your handlebars.
Likes For BlazingPedals:
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Suggestion -- if the bike has these brakes, im guessing its at the entry level parts spec. That doesn't mean its dangerous. Why not send him a premium set of pads for the stock brakes and spend the rest of the money you intended to spend on a nice hydration pack, and /or a few more pieces of cycling clothing ?
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Quoted: 1182 Post(s)
Liked 833 Times
I use Paul cantilever brakes on 3 touring bikes. I use the Paul Retro brake on the front wheel and the Paul Touring brake on the rear. The front Retro brake arm is almost horizontal to the ground; and it has more stopping power than the Touring model used on the rear wheel. The Touring model's brake arm on the rear wheel is angled more, about 45 degrees to the ground. This is a good set up that is used in CX and works well for touring. The touring brake does not interfere with the panniers, and there is less chance of catching a leg on mounts and dismounts.
This combination work extremely well. Paul Retro on the front, and Paul Touring cantilever on the back wheel.
