TT bikes in the tour make no sense
Noticing the TT bikes the guys are using in the tour and I realized that almost all of them are using risers to get their body into a comfortable position when in the aero bars. Seems to me that they could have been given properly fitting bikes designed for the purpose of aero dynamics so as to not have to use the big risers. Must be something I am issing here.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Likes For GlennR:
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
In watching Stage 20 I noticed that some risers are very high as well.
Here's LeMond in a similar race situation - takes yellow jersey the day before Paris.
Quoted: 1572 Post(s)
Liked 643 Times
You're wrong. On July 23, 1989, LeMond won the yellow jersey on the final day In Paris by 8 seconds. His victory was widely attributed to his aerodynamic gear.
Quoted: 101 Post(s)
Liked 46 Times
Note that I said "day before Paris".
Quoted: 2482 Post(s)
Liked 2,952 Times
Highly unusually, that individual time trial took place on the last day of the race and finished in Paris.
About the OP's "tt bikes make no sense," wind tunnel tests combined with power data have shown that the previous ultra-low TT positions resulted in slower rides than could be achieved with less-extreme positions. Evidently, the use of small frames with TT bar risers results in the best all-around efficiency.
Likes For Trakhak:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I caught a quick video clip from scrutinering I one of the highlight reels; A UCI inspector using some sort of gauge to measure the height of the tips of the extensions to the arm rests, and the armrests to the top tube.
This tells me there’s some minimum to how low you can make the rider position. It would make sense that you’d make that height with thin-profile risers, rather than a stem/ headset stack, since the extensions and base bar area as low as possible and integrated in to the top of the headset, for better aerodynamics.
The only UCI restriction on bar height is that they must be higher than the top of the front wheel. There is no upper limit. What you probably saw was them measuring the difference in height between the arm pads and the ends of the extensions. The ends of the extensions must be within 10 cm of the height of the arm rests up or down. The reason for the high risers is that it's been found that by separating the airflow around the arms and the bars, drag is reduced.
Likes For asgelle:
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 174 Times
What has puzzled me is why so many are constantly pushing themselves back on their saddle. It is like clock work. Isn’t that wasted energy?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
In the clip, he’s measuring the extension/ arm rest height pretty closely, then sets the jig between the arm rest and the top tube, takes a quick look, then gives a thumbs-up to who I presume is a team mechanic, who grabs the bike and rolls it away.
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,587 Times
Thread moved from General Cycling to Pro Racing for the Fans
Quoted: 4559 Post(s)
Liked 2,802 Times
Many pros who are otherwise solid cyclists seem uncomfortable on TT bikes. It's a whole nuther discipline that only a few pros master.
Before the penultimate stage time trial, the Lanterne Rouge channel Oz dude predicted bike changes from TT to road bikes for the final climb would be the downfall of some riders. He nailed it.
Aside from the scandals that overshadowed his injury and sanctions-abbreviated career, Floyd Landis was a solid time trialist. There aren't many YouTube videos focusing exclusively on this but I've watched a few. Unless the rules prohibited his preferred position, he usually set the aero bars higher than many riders and seemed more comfortable with a natural cadence, while also being more aerodynamic. I suspect that without the hip injury and doping scandal Landis would have carved out a niche for himself as a great cyclist.
It's motivated me to try aero bars on one of my road bikes again. An old C1-C2 neck injury makes the conventional aero tuck very uncomfortable and impossible to hold for more than a minute or two at a time. But a higher position, angled aero bars, with fists in front of my face, might be workable. I hate aero bars but gotta admit that every time I've forced myself to use them there was an immediate improvement in speed and shorter times, even when I used the aero tuck poorly.
Quoted: 101 Post(s)
Liked 46 Times
Quoted: 6186 Post(s)
Liked 4,803 Times
Except for stage 20 of this TdF, what stage and whom did you see using a TT bike? All I've noticed are what I'd call a standard race fit road frame with drop bars. Some more aero than others, but not what I'd call a TT bike and none with aerobars..... except for the TT stage.
Quoted: 4802 Post(s)
Liked 3,922 Times
