new kalloy riser/dirt drop stem won't fit onto drops
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i have an old one from years ago that fits on fine. i just needed one with less reach, so i bought this 80mm off ebay. i can return it i'm sure, but i wondered if anyone else has gotten a new one and run into the same issue?
by comparison, the new one has a bulkier clamp head and the chamfered portion that normally would allow the head to slip around the bar's bends has a wider cross section. i'm sure this is the issue. and, yes, i have tried wedging the stem clamp open to no avail
perhaps it is what it is and should just return it getting something else, but nitto stems are just so much pricier and i'm admittedly a little attached to this old school/riv type set up style i was going for. maybe there's another brand making the same style of stem? haven't seen one, yet, but maybe there is
btw, i'm trying to install it on some mid 80's SR road champions, so it's not that the bar bend is really all that tight
TXHC
Sakae made some dirt drop quill stems which show up for less than their Nitto counterpart from time to time.
That Kalloy stem was probably designed around flat bars. That’s a shame; I was looking at them, too.
Bikes: yes
Quoted: 14 Post(s)
Liked 10 Times
cut it down
Don't know if you're game, but I was face with the same problem.
Using a standard road stem as a model, I sawed a small slice off each side of the clamp.
Filed the cuts smooth and polished the surface. No problems in a few years of use.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yeah, it is a shame. i guess kalloy decided to change the design a bit. beef it up or something. it's not like the older vintage more slender design ever had problems
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,047 Times
There's more than a few marques that have the same problem.Flat bars only or gouge your bars trying to install.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
what did you use? a band saw? i have thought about putting it to a grinder (don't have a band saw), but it's a bit of work when i was shooting for plug and play. and, when i have several things on the plate as it is. otoh, in part of an afternoon i could have it together
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Technically this technique should be used only on a steel stem. But it does work and I have done it (delicately) on a Kalloy and I am still here. Grinding a bit of material away may be the safer route.
https://janheine.wordpress.com/2012/...&preview=true/
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
again, thanks!
Quoted: 634 Post(s)
Liked 444 Times
I don't know if an open faced stem is a non-starter for you but these Sunlite stems are surprisingly nice and are 80mm. I used one on my girlfriend's bike and was impressed. They look to be sold out of silver at a lot of the big retailers but maybe you can find one somewhere.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
I have one of those stems and went at it with my belt sander. Had to get pretty aggressive for the first bit and less aggressive later for a better finish. Use a regular stem a bit as a guide to have a taper toward the inside radius that can go around the tight bend like the road stem.
Likes For sd5782:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
edit: just ran a quick search and modernbike has them for around $18 + shipping.
you wouldn't happen to have a photo on the bike would you? thanks so much!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For halb:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
lol....i don't quite see how i'd get much of good bite angle with a hack saw, but i will chalk it up as an option. just found a good bolt and nut to try this coin trick thingy. report coming soon enough
thank you all for the great input thus far!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
the dime i tried to use failed miserably under the screw, so i had to use a steel fender washer instead. once i had the gap wide enough, it went on with little fuss even around the tighter transition to the bar top. i couldn't even get the stem clamp passed the drop bend at first attempts!
anyway, thanks so much, again, gentlemen. i dare say this method will work for any quill and classic bar combo. in fact, i will always do this method from now on. so much easier
success!!!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Glad it worked, and as I said I have done it and lived. I do feel the obligation though to point out again that the bending limit of alloy is nowhere near that of steel, which is why I said grinding is probably the safer route. One makes one’s own choice, but understand the risks. It’s not a part you want to have fail. In my case it was for a town bike that never gets ridden hard, so I wasn’t very concerned.
Likes For ofajen:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
