Training Tire for Computrainer
Does anybody know of a better tire to use on the computrainer. I tried the Continental Trainer tire and I think its just awful. Little yellow balls come off it and its a royal pain to get it on the rim in the first place.
Is there a solid rubber tire option out there somewhere?
Its weird but I blew up a Vredistein tire on the trainer yesterday. It developed a bubble and when the bubble came aorund Kablooey.
I was also wondering if I'd have better luck with a clincher tubular from Tufo. Has anybody ever tried them for that?
Been spending alot of time on the trainer lately so any suggestions would be appreciated.
Mike
Mike
Quoted: 2952 Post(s)
Liked 3,106 Times
I just use an old tire that's a little too worn to use confidently on the road. When you say your Vredstein developed a bubble, do you mean that the tube poked through a hole in the tread? Or was the tire improperly seated and the bubble near the rim?
Vittoria Zaffiro Home Trainer, and Tacx. I use the Vittoria and have not been disappointed, nothing is coming off it and seems to be handling the temperature well.
I love Vredistine tires. Normally indestructable. In this case (and I have no idea why). A pocket developed between the layers and burst. It did not go all the way through the tire. Weirdest thing I ever saw.
When I first got a trainer, I didn't know about the tire thing. I was on it for about ten seconds before I could smell the melting rubber of my nice Michelin Pro3s. I went out and bought the cheapest 700x23 tire I could find at MEC (Continental Sport), and it's been just fine. The Michelins actually left a line of molten rubber on the wheel of the trainer, but the heavy cheap Conti has been perfect.
If your tires are showing serious wear on a trainer then you have it set up wrong. I've done thousands of km's with just a bit of polish resulting.
True I did have some build up.
When I checked my trainer roller there was a ton of rubber build up on it. A little alcohol seemed to clean up it up pretty good. Your right it probably didn't help matters much.
Zaffiro Pro Home Trainer question
Hi all, I thought this would be a good thread to post this picture of the Zaffiro Pro Home Trainer tire I've had for a while... should I be concerned?
Quoted: 4560 Post(s)
Liked 2,802 Times
A little spackle and sandpaper, that'll buff right out. That tire's good for another 10,000 hours.
I don't know what make/model but a friend texted me and asked if trainer tires are directional, he was looking for an arrow and didn't find it. I told him, not knowing the make/model, that they tend to be slick, although there is some texture in the photo of the Zaphirro above, and as such, aren't directionless. Can you confirm/deny?
Bikes: Specialized Crux Expert Evo, Felt DA, Surly Crosscheck, Divvy
Quoted: 8 Post(s)
I've run the Continental trainer tires for many years on different bikes and have never had a problem with them. Fluid trainer, rollers and now a smart trainer.
Bikeforumuser0017
Road Cycling
45
01-04-13 05:12 AM
fish_h20
Road Cycling
8
01-12-11 03:15 PM
