Absolute Black chainrings and 142mm thru-axle bikes
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I'm considering Absolute Black 46 & 30 chainrings on a Shimano R7000 crankset on a bike with disc brakes and a 142mm thru-axle.
I've installed these chainrings on a 6800 Ultegra crankset in combination with a 130mm quick release rear hub on a rim brake bike. The chainline is significantly inboard of the stock set-up. I find that perfect adjustment of the derailleur and archiving totally quiet operation is elusive.
Does the chainline also cause issues on 142mm rear axles? I would expect the chain-line to become an issue while combining the small chainring with the smaller cogs.
Just finidng my cadence
Bikes: Motobecane Ti Century Pro, Catrike 559
Quoted: 7 Post(s)
I have the same setup with my R8000 crankset and they work perfectly! As always; you should try to avoid crosschaining (Small to Small).
Likes For kokak:
