Silica Secret Chain Blend. Anyone try it yet?
First time waxing a chain, and first time using Silica to do it, so we shall see how it goes. Melting the wax as we speak. Has anyone else tried it? If so, what are your thoughts?
www.mp-aviation.com
www.mp-aviation.com
All done. I have no idea if it worked right but we shall see lol.
www.mp-aviation.com
www.mp-aviation.com
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
It's far from being a secret blend. I've heard it's just some wax with some Nano-Scale Tungsten Disulfide thrown in.
Likes For Sy Reene:
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
Questions abound! How long is it supposed to last and can you reissue the left over wax until it’s all gone?
ive been using some type of wax/water blend in a squeeze bottle for the last few months. Can’t remember the brand right now. It’s been quite good but I have to wax the chain every 300 miles or so it seems
www.mp-aviation.com
www.mp-aviation.com
How has this wax been? chain life, relube intervals, cleanliness? Also zerofriction suggested that KMC chains were not the best for waxing because of their coating, did you observe any problems ?
Also Has anyone tried both PTFE+wax and this one, can you say this one is better than wax +PTFE?
I was also wondering if it is possible to add Tungsten Disulfide in Wax instead of PTFE and get a homemade version of this wax?
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
I started using Silca’s wax liquid lube when it first came out. It works. I normally would have to replace a chain at about 1500 miles. I’m at over 4000 miles on my current chain and it shows virtually zero wear - still tests out at the “new chain” range. I also get much more mileage out of an application than I have in any other lube at nearly 300-350 miles. Most other lubes are getting pretty noisy at 150-200. Side benefit is no more chain ring marks on my leg. Caveat: You do have to follow their guidelines in cleaning the chain the first time.
Short answer: yes, it works.
Qualitatively, it’s also made my chain quieter than any chain I’ve ever had. I love this stuff.
J.
J.
J.
J.
What do you do to replace a chain at that mileage?!
Likes For waters60:
Likes For JohnJ80:
I switched to it in September and have no complaints so far. Relubing every 500 or so km and it keeps the chain clean.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
I use some lamp oil to soften the wax, so it's not so brittle.
I don't know about the tungsten mix. If you can get it,, you could add it in. Regular old paraffin wax works great all by itself.
I use wax and ptfe, don't know if it helps or not but it certainly cant hurt.. I get between 400 and 500 miles out of a treatment with wax. The chain stays clean the entire time. And as long as you don't contaminate the wax with oils and grime,, you don't have to clean your chain after its initial cleaning. Drop it in, swish it around a bit. Hang it to cool. I use a 1 quart crock pot for my wax.
How do you decide when to rewax your chain ?
he said member
Bikes: yes please
Liked 1,951 Times
Mostly by sound and shifting performance. When the mix is right, and the wax is the correct hardness its real quiet running. There is a distinct rattle when its time for a soak. Its a very dry, sharp, sounding rattle, very metallic.
Funny you should mention kmc, I just put one of thier stretch proof 10 speed chains on the wahoo bike. It seemed to get a nice even coating of wax. Ill keep an eye on it.
Last year I split 4500 miles between 2 bikes, an 11 speed and a 12 speed. No noticeable wear on either chain. They measure 12 inches with tension on the pedals. Chain checker says all is well too.
Even if it works only as good as regular lube, the cleanliness is worth it to me.
Mine after 130miles is usually in between, it is very quiet or sometimes when I push it I can hear the slight ticking sound of the chain but not squeaking.
For me that metallic sound, though very faint, is there even at 100 miles but gets noisier after 200miles. I was also wondering which model/speed kmc chain are you using?
I will really appreciate it if you can tell update me the miles it took to the first re-waxing when you do. I wonder if it really is shorter than other brands.
J.
Does anyone know how much WS2 is used in Silca's secret Wax? The ratios would be great. I have some leftover wax and I want to give WS2 a try too.
I am thinking of adding 25-30gr of WS2 to 1lbs of Paraffin wax (half of PTFE that I mix in),
Liked 8,925 Times
I wish OP would give us an update.
