Stuck cork in handlebar?
Ok, C&V gang, I figure you all are the folks to ask how to extract a cork from handlebar. Oh no. Ha you thought it was easy one where it was just wedged in and you simply pull it out. Oh no, this one has been pushed into the bar about 2 inches.
Any ideas or experience? Or is it just now a permanent feature of the bar? I was thinking maybe something like this as a hail mary but then I was wondering if there's some sort of plumber's tool or an awl-like thing with a hook.
Thanks for any help.
Likes For Soody:
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Yep, corkscrew is the perfect tool. Imagine....
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Leave it in there for vibration attunement, a la the old Bontrager Buzz-kill plugs.
When I worked in a shop, there were a few rabid devotees to those things.
Likes For Dylansbob:
Likes For jiangshi:
Quoted: 1199 Post(s)
Liked 1,355 Times
If the bike is built with Campagnolo, the cork must be removed with a Campagnolo wine cork
Likes For malcala622:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,007 Times
If you have access to an air compressor, you may be able to use air to blow it out from the other side. I have an old bar end plug with a hole in it that I'll use my blow gun to pressurize the handlebar to blow off grips off the other side. I would think the same technique would work for a cork, unless it is really jammed in there.
https://www.bikeforums.net/21970072-post8.html
Quoted: 1088 Post(s)
Liked 1,205 Times
Off grid off road
Can you get a long bendy stick like hazel in from the other end and push it out?
Quoted: 3015 Post(s)
Liked 3,804 Times
Likes For iab:
2” inside of the bar end! Just leave it there. Who’s going to know it’s there besides you? I’d think about putting one in the other side too!!
Likes For sovende:
mycocyclist
Quoted: 910 Post(s)
Liked 820 Times
Put A Cork In It
Fill a basin large enough to accommodate the handlebars with a strong solution of Lye, NaOH, Sodium Hydroxide.
Immerse bars, which should promptly dissolve.
Rinse off cork before using, but it should be fine!
Likes For machinist42:
Quoted: 1858 Post(s)
Liked 664 Times
With a long drill or awl, or a drill on as extension bar, cut or punch a bunch of holes in it. Then progressively tear it to pieces from the outside.
Worked for me on a cotter pin, using chain saw sharpening files! Should be way easier for a wine cork!
Could also attach a driver of some sort to a flexible tube like an old hand brake outer cable, and try to push from the inner side.
Corkscrew first. Hopefully the cork is wedged tightly enough to get the cork screw inserted.
I know someone who permanently disfigured his face by pressurizing something that was not designed to be a pressure vessel with an air compressor. If you must attempt the pressure thing, use water as Vintage_Cyclist suggested. Domestic water pressure is around 70psi. Inside of handlebar around 20mm. You could get 35lb of force on the end of the cork.
Another thing that might work since the cork is only 2" deep- find something about 1/2" diameter with a square cut end. Glue it to the end of cork (steady... ) and pull after glue has set.
I.C.
I.C.
Quoted: 4236 Post(s)
Liked 2,949 Times
Likes For himespau:
Off grid off road
Hey you could stuff the bar and indeed the whole frame full of corks and have an amphibious bicycle. That would be
a w e s u m
a w e s u m
Wow. Love all the creativity.
It's not hurting anything. It's just sorta annoying me mentally that something isn't quite right. Just mildly bugs me.
Don't think corkscrew will work. It's not wedged enough. I think I'd just push it in farther. In fact I tried it but with one of those 2 pronged ones, hoping to wedge and grip it a bit and it just pushed it farther in. But if I get desperate, I may give it a go with a real corkscrew.
I may try the destroy and chop in small bits. Don't have air compresssor but that's a great idea. Maybe I can borrow one or something.
I was also thinking of getting like a dental pick to see if I can "stick it" and then pull in back out.
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times
Likes For b dub:
