Bafang BBS01/02 + Shimano Nexus 5 ?
Old 04-01-21, 12:51 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
Question Bafang BBS01/02 + Shimano Nexus 5 ?
Hello,
Unlike the older models, the Shimano Nexus 5 was built for e-bikes.
Out of curiosity, can it be used…
  • Without hooking it up to a Shimano Steps mid-drive, just like a regular Shimano gear hub
  • Manually (ie. with a classic, cable-actuated shifter instead of a Di2 shifter)
  • With a Bafang BBS01/BBS02 mid drive engine, or will it only connect to a Shimano Steps motor
Thank you.
Winfried is offline
Old 04-01-21, 03:27 PM
2old
Quoted: 883 Post(s)
Liked 823 Times in 622 Posts
The SL C-7005 lever is compatible. How would the rear hub "know" which motor it's attached to?
2old is offline
Old 04-02-21, 02:50 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
I guess it depends on how the motor talks to the controller. If the Nexus 5 only works through Di2 and will only talk to a Shimano Steps motor, it might be difficult.
Google returned no hits on such a setup.
Winfried is offline
Old 04-02-21, 06:54 AM
Pop N Wood
Quoted: 668 Post(s)
Liked 529 Times in 355 Posts
If you go cable then just put a shift sensor on the cable.
Lots of people ride with no shift sensor so that is an option as well.
Pop N Wood is offline
Old 04-02-21, 12:05 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Thanks for the tip.
https://gearsensor.com/
Winfried is offline
Old 04-04-21, 08:54 AM
Pop N Wood
Quoted: 668 Post(s)
Originally Posted by Winfried
Thanks for the tip.
That is the one I am running with my Bafang. Works perfectly.
Likes For Pop N Wood:
