What part is this? Cervelo P2C
Hello everyone I am wondering what this part is for a cervelo p2c I think it goes around the fork as some sort of compression bearing but I'm not sure. It is plastic and seems to fit around the fork tube.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You're gonna have to do better than that if you want help.
Quoted: 254 Post(s)
Liked 182 Times
Is it a circle with a break in it? It may be the wedge that is the last piece to put into the top of the headset before you put your spacers and stem on.
Likes For AeroGut:
Bikes: lots
Liked 2,932 Times
Still trying to make ten posts to put up the picture this will get me one closer but yes it is a circle with a break in it and its tapered
Quoted: 254 Post(s)
Liked 182 Times
2) even if they do, it's an optional part. Basically just a differently shaped spacer
So I will rephrase. The split ring is the last essential piece before the spacers and stem. Here's a diagram from wikipedia. The piece we're talking about is labeled the "conical compression ring"
Bikes: lots
Liked 2,932 Times
That diagram is not accurate. I have NEVER seen a threadless headset that didn't have a bearing cover/dust cover over the compression ring. I'm not sure where you're from but they ALL have this part. It is not a spacer, but can be thin like the Cane Creek in the first photo or tall like the FSA in the second photo.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Seen an Aheadset?
Bikes: lots
Liked 2,932 Times
That's an ancient ball-in-retainer headset. It's quite unique in that the bearing cover is tapered internally and the compression ring goes into it...very unique. I'll say no modern headset comes w/o a bearing cover. I forgot about the original Aheadset.
Quoted: 513 Post(s)
Liked 445 Times
Same concept without the cartridge. The compression ring is to center the top of the steerer.
Quoted: 254 Post(s)
Liked 182 Times
That design stuck around much longer than the original Aheadset model and it is certainly not unique, nor ancient. I have one stock on a 2008 bike from after they changed the brand to Cane Creek, and that same Cane Creek model was still available on Amazon until covid messed up the supply chains:
https://www.amazon.com/Cane-Creek-VP.../dp/B0019QHLX8
