SRAM to Shimano switch on caad 10
Bikes: 2011 Cannondale CAAD 10 SRAM Rival
Hi, I have a 2011 CAAD 10 with SRAM rival groupset. I want to change over to the newest Shimano 105 for a variety of reasons. What do I need to consider in cahnging over? I'll also be going from 10 to 11 so.. thanks !
Non omnino gravis
Likes For DrIsotope:
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
If your freehub is not naturally 11 speed compatible, often the 34t cassettes will work. https://www.merlincycles.com/en-us/s...et-118524.html
Everyone, thanks for your input
Kimmo-
most pressing is the front derailleur needs replacing. i've read and heard that shimano is a bit more sturdy and less finicky to get dialed in and my bike takes a beating here in NYC. i also wanted to try shimano's offerings as a point of comparison to SRAM. finally, there's a bit of nostalgia as my dad always road shimano on his old school cannondale
noodle soup/shelbyfv
this is the part is wasn't sure about. i'm still running the original RS10 and plan on upgrading the wheelset while i'm at it
puma 1552
fair question but, overall, i've really liked the bike and would rather spend my (limited) $ upgrading around the frame i have
thanks again!
Kimmo-
puma 1552
thanks again!
Quoted: 18883 Post(s)
Liked 10,646 Times
Shimano FDs are absolutely easier to get working right than SRAM's. That's putting it mildly and politely. I'd elaborate, but it would involve a lot of swearing.
Liked 10,646 Times
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
Shimano is just generic junk , Sram the best out , facts , if you cant run sram you probably should not be on a bicycle , of i was you id invest in some penny loafers and get to stepping , you.problaly like soy lates , and gender nutreual purses .. 😋
Likes For downhillmaster:
Expired Member
Liked 5,427 Times
Quoted: 1528 Post(s)
Liked 718 Times
Just get a Yaw FD. Even fiddlier to set up, but they work great, no trimming.
Likes For Kimmo:
I prefer Shimano over Sram
Liked 718 Times
Yeah, I prefer to set the angle with the chain out of the way so I can see the teeth. It's no biggie when you know the deal, huh. For extra points, set the cable tension without a barrel adjuster...
I reckon Yaw is the tits. Though it's a pity there's no bracing screw like on Shimano, or at least the dinky little wedges on EPS.
ZachLegleiter
General Cycling Discussion
8
12-17-15 02:59 PM
Autobus
Bicycle Mechanics
5
07-20-10 06:20 PM
