Overhauling a 2002 SID SL Front Shock
Greengulch
Bikes: GF Hardtail
I need to overhaul a '02 SID SL that is leaking oil. Anyone know a LBS in SF Bay Area, preferably in the North Bay, that can do this work in-house? I'm willing to put about $100 into an overhaul. Does anyone think it is worth putting in more before going to a new shock like Marzocchi MX Comp? BTW, the shock is for XC -- rider weight about 190 lbs. Thx.
Factory Spec
Paul,
Well, $100 will get you a full overhaul (minus bushings and any hard parts, those are a little extra), and would pay for shipping both ways to Ventura, which is where I'm at.
Let me know if you can't find anyone local. Yes, an '02 SID is definately worth rebuilding unless it has major mechanical damage.
Ed
Factory Spec
Ed
Factory Spec
The Red Lantern
That is a keeper for XC esp. if you use the bar mounted lockout. A little flexy but much lighter then the Zoke.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Greengulch
Bikes: GF Hardtail
Thanks for your replies. Ed, I'll search a bit longer for a LBS solution -- will contact you if I still cannot find one.
