1968 Rene Herse Gentleman's Bicycle
2Flit
Location: Orcas Washington and currently Circumnavigating in a Farrier F36 Trimaran
Bikes: 1968 Rene Herse Gentleman's Bike; 1974/5 Jim Merz Custom-built; 1984 Rodriquez tandem; 2012 Bilenky Tandem; 1967 Cinelli SC; 1984 Specialized Exp. 68cm; 1971 Holdsworth 63cm(my first bike ever and owned since new!); 1994 Bridgestone MB5; 86'Trek420
Quoted: 38 Post(s)
Liked 170 Times
At the risk of being far to over wordy, here is my brief history with this R. Herse
Traveling thru France on a 2012 Tandem bicycle tour along the Loire River, we stumbled upon a Rene Herse being advertised in the local paper. Original owner bicycle in exceptional condition, just waiting unridden in the old owners storage. The French ad read as follows (and this reads as a good description of how she came):
EXCEPTIONAL STATE
Vélo René Herse taille 68 cm axe/axe René Herse bike size 68 cm axle / axle
Tube supérieur 60 cm axe/axe 60 cm top tube axis / axis
Potence René Herse René Herse Stem
Pédalier René Herse René Herse Crankset
Manivelles René Herse René Herse cranks
Garde boue Durex RBN Fender Durex RBN
Freins Weinmann 610 vinqueur 999 Weinmann 610 brakes vinqueur 999
Moyeux Normandy Normandy hubs
Pédales Lyotard Lyotard pedals
Pompe Lapize Pump Lapize
Selle Brooks B66 à ressorts Brooks B66 saddle with springs
Jantes SuperChampion Wheels SUPERCHAMPION
Tubes Reynolds renforcés fourreaux de fourches et arrières Reynolds tubing sleeves Reinforced forks and rear
Eclairage fonctionnant parfaitement Lighting works perfectly
Feu arrière ULO Taillight ULO
Dynamo SOUBITEZ 10 Dynamo SOUBITEZ 10
Numéro de Série 53 68 Serial Number 53 68
Remise en main propre sur Paris Hand delivery to Paris
Difficult to do anything on a two-up self-supported tour; We continued cycling on to Budapest, the Rene Herse always in the recesses of my mind… the thought of her growing… was it provenance that had caught me in its web with that incredible coincidence of my very tall frame size at 68cm axe/axe (c-c)?
We came within the tiniest of margins of cancelling our return flight to gain the time to cycle back and arrange purchase and shipment home. Looking back, I can’t believe I just flew home.
But I could not escape the attraction and arranged for a local mechanic (Enzo at Velorama) to meet up with the owner and ship the “Gentleman’s Bicycle” home.
Because the bicycle became a daily commuter on a steep and hilly ride…. I made a few reversable changes to the gearing and provisions for a front bag. The old parts (freewheel, original drilled bars, derailleur, and such) safely stored away for someone that comes eventually down the road from me, probably when I’m 80 years old like the former owner.
The conversion to the (up to) 16% grades that I commute on was mostly done with the addition of a clamp-on suicide shifter a slightly wider range of the French threaded freewheel and a bit of magic from Jan Hein with an adaption of the original cranks to a double. Shifting is not what one would call smooth but I don’t want to violate the originality with an actual Herse square tube shifter that’s brazed. My hope is that some day I (or the next owner) will be back on level-ish ground and can return the bicycle to the original unmolested state without any noticeable history of a former hilly life.
Original Condition on arrival
Original unmolested condition left side
On a sunny day before the changes started
Seat Lug and cable routing
Fender reinforcement
BB shell
Front light
Seat Bolt
Next>>>>
Original
Brakes pivot on seatstay posts (not the bridge)
Fork
Single original Crank
Rack works fine for loaded bags
Brooks original seat Has old school clamp shells
Front brake and roller
Lettering
Original bars were somewhat narrow for city streets and I wanted to add a Nitto F11 carrier which would have destroyed the original bars. Switched out for some similar modern bars and drilled them for the reverse lever brakes
Rear fender
aft view
Rear roller
EXCEPTIONAL STATE
BB shell
Front light
Seat Bolt
Next>>>>
Original
Fork
Lettering
Rear fender
aft view
Rear roller
2Flit
Quoted: 38 Post(s)
Liked 170 Times
Original single now converted to a double with Jan Hein's help
Rear rack can carry a substantial load
Original B66
Front brake on very low pivots
Lettering
Original handle bars now replaced
Fender Mark, rear fender was damaged in shipment
Likes For 2flit:
2Flit
Quoted: 38 Post(s)
Liked 170 Times
This is how the bike looks today with the modifications that I made to the gearing, shifting, and handle bars.
Likes For 2flit:
Quoted: 4513 Post(s)
Liked 6,392 Times
Man, so cool, fantastic score, very well done.
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times
Beautiful! Truly a spectacular bit of cycling history. It’s my size too…. I’m shocked that 68cm Herse bikes even exist!
Quoted: 3464 Post(s)
Liked 2,831 Times
Big enough to consider the top tube as a roll bar for me.
Fortunate to be old enough to have the hand painted downtube graphics.
Very nice.
Fits as if designed for you.
Given the size, I would have been tempted to go to a cable operated front mech and a shift lever near the seat lug as done on some demountables, using a single sided shift lever clamp.
I could see a few ways to run the cable.
No idea how you reach that far down!
Consider lengthening the shift cable housing for the rear shift at the bottom bracket.
And reducing the loop for the rear brake near the seatpost. Things are tight for sure there.
Very nice.
Likes For repechage:
2Flit
Quoted: 38 Post(s)
Liked 170 Times
It's all relative as we can all touch our toes... and me toves are way down der too!
The front cable shifting seemed like yet one more thing to potentially mar the finish and leave a trace of my molestation. The long reach keeps me honest and the bike is ridden as a 5-speed except for the truly steep bits on my gravel road. Like getting out and turning the manual hubs on my 1965 Jeep CJ5, it's a very conscious decision and something I don't want to do all that often.
It's a bit weird but this is the only bike I've owned that has the presence and responsibility of owning a piece of history and all that might imply with regards to 'stewardship'
Likes For 2flit:
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Very cool indeed - thanks for sharing! You are now the steward of an amazingly rare bike. I’m glad that you stuck with Huret for the RD. I think that the PO, and Herse himself would approve of the continued use of the bicycle as intended. He himself was known to make modifications or upgrades as bikes returned to his shop over the years. Your tasteful and reversible modifications keep it alive for you.
Here’s to many more miles with your machine!
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
Likes For Force:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 643 Times
Looking at the photos in post #1, I was sure that any added front derailleur was going to need to be modified to clear the pump peg; seeing the follow-up photos, clearly not.
Very cool bike.
Very cool bike.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Pedal to the medal
really beautiful machine you have there and amazing you tandem toured in Europe. I recently bought a road tandem (90's Santana) and enjoyed the ride more than expected, especially when the stoker and I synced our cadence. Perhaps one day I'll do a tandem tour myself!
I've also read that drilling aluminum bars is a big no-no, perhaps I'm off here. Any concerns on your end?
Here's to many more miles!
Likes For romperrr:
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
The suicide shift is a cool touch. The other options would have included a Benelux suicide shift with the long control shaft along the seat tube or a clamp-on left lever and under-bottom-bracket cable routing.
Likes For John E:
2Flit
Quoted: 38 Post(s)
Liked 170 Times
I've had enough porteur, northroad, and moustache bars on the shelf that I honestly don't recall, my best guess is that those are either an old Soma bend or most likely a heat treated bar that Nitto made because they are very wide. I have allot of spare parts around and 30 years of handlebar bend names start to become somewhat fungible in my brain. The bars were switched out because I wanted to attach the Nitto F-15 bag support that would have damaged the original porteur bars. The original Herse bars were the narrowest porteur bars that I've ever seen. Both bars are drilled for the cable housings that exit the MAFAC reverse brake levers. I enjoy the esthetics of the reverse levers and the choices that become available for the cable exit from inside the bars.
Original narrow porteur bars
New Bars (similar view)
Old Bar showing Cable exits as originally drilled
New Bars showing different cable exits allowing for hand positions on the more moustache-ey bend
Likes For 2flit:
2Flit
Quoted: 38 Post(s)
Liked 170 Times
holes
Oh-yea... I was concerned given my size!
I have an older friend named Clay that was a machinist and has the most acutely perceptive mechanical mind I've encountered and he put his 'magic' blessing on going ahead and drilling the new bars (besides Herse did this too - though I have no idea of the old bars strength). The holes are carefully chamfered to avoid a stress riser. These bars have at least a thousand miles on them now both commuting and several Brevets.
2Flit
Quoted: 38 Post(s)
Liked 170 Times
The suicide shifter needed to be modified to work around that lower pump peg. The sliding shaft and cam needed to be modified and turned upside down and the end nut changed. Still the positioning is less than ideal.
This is also why the Benelux suicide shift probably would not have worked with it's upper arm pivot and difficulty in modification
You are amazing perceptive to have caught this detail (one that I had actually not recalled untill you mentioned it)
Great catch !!
Likes For 2flit:
Liked 2,831 Times
Repêchage
Liked 6,392 Times
@2flit
Veering off a bit here.
Been so enamoured with the RH and your fantastic accounting of it that it took me this long to see the "1973 Jim Merz Custom-built" in your list of bikes, pffft!
I must really be slipping now days.
Please show and tell us about it too, 73 is very early, I have JM027 that he built for himself and he says it is 73-74, no build sheet and he's not sure.
2Flit
Quoted: 38 Post(s)
Liked 170 Times
'73 Merz
@2flit ... took me this long to see the "1973 Jim Merz Custom-built" in your list of bikes, pffft!
It's bee thoroughly messed with though!... you might hate me for that?... It's actually the bicycle I took with me here on our circumnavigation (now being ridden in Kiwi land while ocean cruising has become Covid impaired)
Bikes: 1989 Schwinn World Sport. 1994 Diamond Back Response Elite MTB. 1964 Schwinn Typhoon. 1974 Bridgestone Sprinter, 2015 Scott Sub 10 Citybike.
Quoted: 1688 Post(s)
Liked 84 Times
Beautiful machine! Way, way too big for me, but nevertheless incredible.
tantum vehi
Liked 992 Times
What's even more amazing is that his Bilenky has traveled back in time some 18,000 years!
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Liked 6,392 Times
I didn't buy it to look at, commuted on it for a while, rode it at Crater lake, in the Gorge, Silverton, and all over PDX, fantastic.
I'll wait for it but I have so many questions.
I get so much respect whenever I show them off, its amazing, even when people don't know of him they are still in awe.
Standing by.
Likes For merziac:
Likes For Vonruden:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Excellent job!
I've always thought I wanted an original Herse. But then I realized I'd want to mess with it too much- kit it out with Suntour and Dura Ace... I wouldn't want to do that. So those are just to enjoy from afar.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Likes For Jrod721:
2Flit
Quoted: 38 Post(s)
Liked 170 Times
A Rene Herse Tandem for sale at a bicycle club in France....
https://tandemclubdefrance.fr/index..../95-rene-herse
I can't pot in the vintage sales../ Maybe a paying "Upgraded" member will repost this there for me?
Asking price : €1,900
Year of manufacture : 1951
Front frame height : 55 cm
Rear frame height : 52 cm
Wheels : 650 B
Very good condition
Description : "Tandem René Herse 650B from 1951 (engraved in the fork pivot). Restored in 2008 by Gerard Saint Martin (33 Cambes)."
Perfect condition! New paint. Very very little driven since its restoration. Size: 55 front, 52 back.
Tandem René Herse cranksets, with original bottom brackets. Super SLJ Simplex rear derailleur. Lighting on. Ideale 80 saddles. Handlebar and front stem Philippe.
Tektro cantilever brakes. Maxi Car tandem hubs. Rear drum brake doubled on Mafac brake levers. New wheels on Brotherhood 650B rims.
Selling price: 1900€
Wheels : 650 B
Very good condition
Likes For 2flit:
