My first Merz
#51
Quoted: 226 Post(s)
Liked 258 Times
Stole the bars from my Trek 640 to try out the red:
It clashes nicely. Might get a lot of hate, but I think I like it.
Here's some shots of the tight brake fitment. Mafacs will be a little better. Or maybe I'm just not trying hard enough! In part it is the long pads which don't play well with the fork blades.
I was surprised to see no fender attachment on the chainstay bridge. Was this not something that was common on older fenders? The other fender attachments seem very deliberately placed.
Likes For jPrichard10:
#52
Quoted: 4513 Post(s)
Liked 6,389 Times
I doubt Jim would have drilled for fenders unless he was putting them on, I believe any water intrusion was a paramount concern for him here in the PNW.
Two of mine were built for fenders and TW189 is very nice with them as they are original.
And JM027 was built for them and came to me with poorly fitting ESGE's, not shown but as built originally with Bluemels.
Likes For merziac:
#53
Quoted: 226 Post(s)
Liked 258 Times
merziac it does have threaded bolts for fenders on both the fork crown. (on the back) and seatstay bridge. Just not chainstay bridge.
#54
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Thank you for the detailed photos! Indeed the Frogglegs cantis are not as eager to play as other vintage cantis. You do still have a lot of pad and arm angling available to you, but the first problem I foresee with further "leaning out" of the canti arm is that the straddle cable will heavily interfere with the brake pad post, and it looks like you've positioned and angled things to just before that point, front and rear. "Maxed out" in a way. Are you also concerned that any further "leaning out" will completely disengage the springs? I could see that happening, and it was something I dealt with on my 620.
Don't know why I didn't lead with these photos earlier, but here is the stock 1984 620 setup with 27" wheels. Chunky pads, but at least they didn't hassle the fork blades. That, too, is a battle for me.
I misspoke earlier, the pads are Jagwire and not Kool Stops. The Jags are thin, with a nice clean look and perform well against machined brake tracks. I was having trouble with them in the short front/long tail orientation, so I did what many OEMs have done: I flipped them around. No fork blade interference, and they open up to accept a fully inflated tire.
Both of these cantis put the pad post really low, and both allow for some real leaning out of the arms along with the ability to really angle the pads downward (relative to the arm), especially the Shimano units. They'd have zero issue with the Merz, IMO.
#55
Liked 6,389 Times
Yep, I see them now.
The Bluemels just had a spring metal clip at the CS that normally did a real number on the paint, no bolt or screw.
#56
Quoted: 3811 Post(s)
Liked 6,717 Times
For installing fenders on bikes without drilled chainstay bridges (which was really common in the 70s), I use plastic p-clips:
Likes For nlerner:
#57
Quoted: 226 Post(s)
Liked 258 Times
Mostly installed the Mafac Criteria (thanks again, bulgie !) today and did a test fit with 700c:
This is on a Wolber 58, so not the skinniest rim. I'm not sure how beyond horizontal the arms are safe to go. As it is, the straddle cable barely clears the brake pad posts, and that's with this rather ludicrous looking triangle. When I actually set this up, I'm planning on a much shorter straddle cable.
#58
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times
Neat bike! If you decide to try going with 27" I have a nice wheel set with Specialized sealed bearing hubs and Ambrosio 19 rims mounted with almost new Pasela 27 x 1 1/4 tires that I'd sell for $100 plus shipping if you want them. PM me if you have any interest.
#59
Bikes: 1946 Holdsworth Cyclone, 1969 Cinelli SC, 1972 Raleigh Pro, 1973 Merz road bike, 1974 Alex Singer Sportif, 1974 Merz track bike, 1975 Teledyne Titan, 1976 Ritchey road bike, 1977 DiNucci built Merz track bike, 1977 (?) Exxon Graftek, many more!
Quoted: 139 Post(s)
Liked 1,432 Times
I would just have a framebuilder move the brake posts down to the correct location. I did that on a frame and fork and Ed Litton touched up the paint. One could barely tell that it had been repainted around the posts. Or, use 27" rims. Jim Merz
#60
Quoted: 226 Post(s)
Liked 258 Times
Top tube cable guides, down tube shifter bosses and a threaded chainstay bridge for fenders are on my list as well as moving the canti posts.
I have a feeling that I might just enjoy the frame as-is for many many years first.
As far as the broken canti bolt, is there any reason not to use one of the mounting bolts to a Mafac Racer centerpull?
#61
Quoted: 139 Post(s)
Liked 1,432 Times
Likes For Portlandjim:
#62
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
I'm torn — on a vintage bike, I like to use original parts. But I'm not a slave to it, and I like having allen-head fasteners so that I have the wrench with me on the bike. Not that I've ever needed to tighten a canti bolt mid-ride! It's a very unlikely scenario, and the polished-chrome Mafac bolts sure are handsome.
Peter Weigle once sanded the chrome off of a set (it's super thin) and polished the brass to a mirror finish. It'll tarnish, but at least for a while, it looks faaabulous.
#63
Quoted: 139 Post(s)
Liked 1,432 Times
I like the way the stock bolts look, but made my own using titanium! Socket head bolts require a larger head, the flange head version works for cantilever brakes.
#64
Quoted: 226 Post(s)
Liked 258 Times
With any other brakes, and perhaps on any other bike, I'd swap them for different bolts.
Those Merz titanium bolts would be an elegant replacement however!
#65
Quoted: 226 Post(s)
Liked 258 Times
Got the bottom bracket and crankset I'm hoping to use, but I got the wrong spindle (pre '79 Campy) for the crankset (1983 Record Strada). 42t chainring grazes the chainstay and that's without even tightening the bolt:
I do have a 1983 68mm spindle I could use, but it's mated with a Nuovo Gran Sport crankset that I would like to keep together. And anyways, the plan is to triplize this Record crankset so I might need a longer spindle anyway.
What spindle length do people use for those fancy triplized Record cranksets? I was hoping for a 74bcd chainring, maybe a 28t?
And maybe it would be enough to have a pre 79 Record Crankset on a post 79 spindle (115.5ish, iirc)?
I might be overthinking this hike and trying to make it match too many of the older Merzes. I'm sticking with a Suntour drivetrain because it's just better in every way than the Campy derailleurs, Rally included. Jim says a bike is "a tool, not a piece of art" anyway ("why not both?" Say some of us) so I may stick with my preferred Stronglight 99 crankset.
#66
Liked 6,389 Times
The "fancy" Record triples are only 100 BCD with 36t rings being the only ones readily available and the bolts can be as much as the crank, also hens teeth if you find one.
You can of course wait to find a Merz tripleizer but you will need one that comes with the ring and they are 31t for the most part, usually worn out, "hens teeth" is an understatement.
A Willow tripleizer is a good option.
Here's a good deal on a complete Campy.
https://www.ebay.com/itm/18632345113...3ABFBMjOCsicJj
#67
Liked 2,576 Times
You can use a narrower spindle if the granny is smaller, but don't go under 28t if you use the Super Record style inner chainring with the "webs" removed. The chain can get wedged between the middle and granny in a way that's hard to get back out without disassembly with tools. Not frequently but super annoying when it happens. Less likely with 26 than with 24t, don't go there! The webs on a NR style middle ring help prevent that, if you want to "get small". You mentioned 28t though, which is well in the safe zone.
You can also use a narrower spindle if you're willing to indent the chainstay. On such a nice bike, I'd be hesitant to suggest this, unless it were done sensitively by someone who's real good at it. I have seen some hack jobs by DIY-ers that made me cringe...
As to using a double spindle for a triple, it can be done but usually requires a pretty deep indent. Here's the actual bike ridden to victory in the crucial mountains stages of the Giro in '81 by Battaglin.
Clearly a double spindle, since SR Ti was never made in triple.
I don't know whether his mechanic used any trickery like a post-'78 spindle on a pre-'78 crank. My guess is no, but he should have — that indent is fairly heinous. His granny at 36t is much worse for clearance than your 28t though. So, "maybe..."
On my '80s racing tandem I used the opposite swap, used a shorter pre-'78 X3 spindle and a post-'78 crank, to make the Q-factor narrower, I think I got it down to 135 which is crazy narrow for a triple. And that's with a 45t timing ring on the left crank. Even the left chainstay needed an indent on that bike. But my sweetie shouldn't have to pedal all splay-footed!
Those are abnormally large chainstays too. Normal (trad) for steel is 7/8", "OS" is 24 mm, inch would be crazy big, and these are 1-1/8" round, the biggest steel chainstays I know of from any bike tubing set. They're Columbus Max, which start out oval, but I reshaped them to be round at the BB shell. Transitioning to oval at the tire clearance point, like R-O-R stays. Then also indented, to allow 32 mm tires, which is tight with a typically-short road-racer chainstay length of 42 cm. I would do it differently now, longer chainstays to allow fatter tires.
#68
Liked 2,576 Times
I also drill Campy cranks to take 86 mm BCD Stronglight 99 granny rings. Only goes down to 28t but that's as low as I want on a Record triple anyway. For the older bikes I have put them on, I like that it uses only parts that were available in the early '70s, could plausibly have been done then ("period correct"), tho I'm not a slave to PC-ness.
For the granny "stand-off" bolts, yes the real Campy #818 bolts are expensive when you can find them but there are lots of alternatives, such as Stornglight 'Mygal' bolts which are either still made or at least still in the retail pipeline. You might need to go to a Euro or UK seller to find them. Normal industrial shoulder bolts such as from McMaster-Carr can also be made to work with a little modification, ask for more detail if interested.
If you want your crank drilled at 74 mm, Bob Freeman of North Bend WA has a drilling jig that makes that mod pretty easy and very precise. I don't know what he charges but it's probably reasonable. He knows all about which McMaster shoulder bolts and spacers to buy, and how to make them work, so he's your one-stop shopping for Campy Triplizing.
And let's not forget BF's own Jon Vara who makes the Red Clover triplizer for 144, way simpler than drilling your crank and searching for stand-off bolts/spacers. And it's a fully-reversible mod, the crank is not harmed!
Likes For bulgie:
#69
Quoted: 226 Post(s)
Liked 258 Times
It's not too hard to make yourself a 30t granny to fit the 100 mm BCD. A few people I know have done it, by starting with an existing 74 mm BCD ring and adding 5 new holes. Here's a little Flickr album showing how I made mine. I also made one at 29t once, but that's a bit impractical, stick to 30t minimum.
merziac, I wasn't meaning the factory drilled triples, but either a triplizer ring or having it custom tapped for 86bcd or 74bcd.
86 is my favorite bcd (why I love the Stronglight 99) and chainrings are still being made by Stronglight last I checked. 74bcd only tempts me as possibly more future-proof. I don't think I've ever seen an 86bcd drilled Record crankset though; do you have pictures? And since it sounds like you might have some experience here, any guesses on a good spindle length for a Record 45/42/28? I know it does depend somewhat on my chainstays here.
#70
Liked 6,389 Times
Good to know about the chain getting stuck on 26t and 24t.
Honestly not sure on the length, I have always done the hunt and peck method, go to a co-op and grab a handful of spindles, usually 5, more if they are cheap in what seem to be good sizes and swap around until I get the right combo.
This can build a very good "feel" for this and help anytime you have to dig in.
#71
Quoted: 139 Post(s)
Liked 1,432 Times
I have at least one Merz Triplizer middle ring, NOS. The one I noticed recently is 46 teeth. I don't have any 31 or 32 tooth Merz inner rings, but do have a Campagnolo 36 tooth 100 BCD ring. If anyone is interested I'll dig them out, the price will be cheap. I may have a triple spindle for the CPSC Campy cranks, again I'll have to look for it. Jim Merz
#72
Quoted: 226 Post(s)
Liked 258 Times
This has been upgraded to "rideable!" I still need to swap tires and maybe lace a new set of wheels (I have some Record hubs and some 1st Gen Phil's; thinking of lacing one pair to some concave Weinmanns). Not sold on the Cinelli 66 bars yet, which is why the shifter housings aren't wrapped. Need to install fenders, cable clamps and hoods.
