French Crank - What to Do, what to Do?
Bikes: 1980 Marinoni Special, 1987 Ciocc Microf. C40, 1978 Raleigh Competition GS, 1982 Colnago Super, 1972 Gitane Pro TdF, 1976 Belgian Diamant by Martelly, 1989 Trek 520, 1972 Dawes Galaxy 2014 Cervelo R5, 2020 Salsa Warbird, 2013 Giant Trance X1
Quoted: 91 Post(s)
Liked 61 Times
I had this French crank on a bike I acquired. It is a 3 bolt number,urrently with a 52/48 ring set-up. The BCD seems quite small. Am I out of my mind to think that somewhere out there I can find a replacement inner ring that is 40 t or even smaller for this?
Anyone know:
1. What make the crank may be?
2. What the BCD is?
3. Thoughts about where I may find that smaller inner ring?
Thanks for your input. - Dan
Quoted: 3815 Post(s)
Liked 3,345 Times
make: Specialites T.A.
model: Trois Attachees
smallest inner offered: 36T
BCD: 116mm
tip: puller thread is unique size which does not interchange with others
BCD: 116mm
Likes For juvela:
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
Dannyboy21-
That is a TA Professionel crankset. It has a unique 23 mm crank extractor and a 116 mm BCD. Excellent cranksets and rings are still available on EBay. More info here: VeloBase.com - Component: Specialités TA Professional 3-arm and here: https://www.ebay.com/itm/1975-Specia...cAAOSwTxJcP4EC
Likes For bertinjim:
Quoted: 823 Post(s)
Liked 1,396 Times
This model crank, with 42/52T rings, was the stock crankset on the Raleigh Competition Mk. II c.1973-76. Certain older Park Tools crank pullers came with a double-sided head, one side the now-standard 22.0 mm, the other a 23.0 suitable for T.A. cranks. Do not attempt to use either side on a Stronglight!
Likes For rustystrings61:
Quoted: 91 Post(s)
Liked 61 Times
Is it possible that a TA 6 bolt might have the same 116mm BCD and work with the 3 bolt Crank? This 36T on eBay below for instance?
Look at this on eBay https://www.ebay.com/itm/324181006350
Quoted: 4513 Post(s)
Liked 6,392 Times
Anyone know:
2. What the BCD is?
If you did not use a TA thread tool, then this has already had the wrong tool forced into it and the threads may be compromised and may not come off again if it is reinstalled, you may have gotten very lucky getting it off.
This can be a PITA as the threads are very close to others so the wrong tool often gets used until the threads strip out and then you have to resort to brute force to get them off.
I would not go any further until you can determine this and sort it out completely, you don't want to source a spendy, hard to find part before you can be sure the crank will live on.
Likes For merziac:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I'm a little confused what crank your ring fits. You can see the 44 tooth ring on the adapteur is already close to the minimum size. It looks quite used as well.
Half way there
Quoted: 989 Post(s)
Liked 884 Times
I have the same crank on my 1974 Raleigh Competition. I believe it has a 42t inner so you may be able to tease one out of the ebay market. Personally, I'd recommend using that 52/48 to set up your bike with half-step gearing. Assuming it's going on a 5-6 speed vintage bike, half-step will be perfect to reduce the number of duplicate gears.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
FWIW the 3-pin was also OEM on Motobecane Grand Record, from '74 to '76...(I checked the catalogs on VeloBase and the teeth specs are 42/52)
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
116 mm BCD was the Continental standard for many years, starting by the 1930’s. Italian, French, and even English makers used it. But that was in the chromed steel age. In the alloy age, Campagnolo, TA, Stronglight and Nervar all made cranks with this BCD.
Seems to me you can get a 36t ring. If it were mine, i would not balk at a steel ring, if that were my only choice.
Another chain ring option is to take a dremel to an 86mm bcd chainring from FSA.
Likes For rhm:
Quoted: 91 Post(s)
Liked 61 Times
Thanks for this advice. I did get help removing this crank from a seasoned mechanic who worked on bikes for over 30 years from the 70s into the 90s. Thankfully the threads are good. French bikes are the latest steepening gradient to my learning curve it seems. I tried to replace a nice Stronglight Competition headset on an old Browning V last night with something less sparkly and quickly learned that not all 1 inch headsets are the same diameter. Lots of fun. Thanks again.
Likes For Dannyboy21:
Liked 6,392 Times
The key step in much of this is to realize when your out of your depth and make sure you get the correct help.
That being said, since you already realize that, you are well on your way to sorting these type of things on your own.
Quoted: 3464 Post(s)
Liked 2,831 Times
Good cranks - I have them on two bikes.
i found a 40t on eBay a year + ago
not cheap
38’s show up And I will outbid you.
even when I worked for a shop that stocked TA rings- never saw smaller than a 38t
the 6 pin ring cited earlier won’t do it
there was for a time an intermediate “ring” that bridged the 3 to 6.
the problem with these aside from the lack of spares is that the teeth are oriented to the back side... easy to down shift- not a happy on the shift in the big ring.
No land, ramps or pins...
the chain has to fully clear over the top of the teeth.
light, low “Q” factor.
many came in French threading
can be tapped to 9/16” x 20
but you will lose the backside filler.
both of my crank sets on bikes have French threads with thread matching pedals
have a 5 pin with English threading... looking for that #374 spindle... they turn up- not cheap!
not cheap
Liked 2,831 Times
Likes For repechage:
Likes For conspiratemus1:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Quoted: 91 Post(s)
Liked 61 Times
Nope. You'd need to use this 'adapteur' and still source out a smaller chainring.
Quoted: 91 Post(s)
Liked 61 Times
Quoted: 823 Post(s)
Liked 1,396 Times
DO let me know if you see a deal on a 44T ring for these - I would use that with my existing 42 and mount my set of T.A. Professionals back on my Raleigh Competition with the Dingle Drive!
Quoted: 91 Post(s)
Liked 61 Times
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 165 Post(s)
Liked 102 Times
Criterium: 152 mm bcd, smallest ring 44 teeth.
Randonneur: 116 mm bcd, smallest ring 36 teeth.
Cyclotouriste: 80 mm bcd, smallest ring 26 teeth.
The Ebay ring is a Randonneur and will fit your crank perfectly. You should buy it right now, because these don't show up all that often. You'll have 3 extra holes but so what. 3-hole 116mm rings smaller than 42t are almost impossible to find unless you get steel rings (this used to be one of the standard chainring bcd's in Europe).
Quoted: 1106 Post(s)
Liked 1,328 Times
HOWEVER, count the teeth. I just picked up a 1973 SC and it has a "made by Stronglight" steel crankset with a 42 (!) - 52. The 72 SC spec says "Stronglight 40-52".
Steel ring teeth make sense; the smaller the ring the more sense they make. I suppose the best arrangement would be a U-channel ring of steel teeth with an inner aluminium ring and arms centrifugally cast into the ring and then machined and peened.
