Rear Tail Light that mounts on rear rack
Bikes: Thorn Nomad, Haibike XDuro Trekking
Quoted: 25 Post(s)
Liked 13 Times
I'm a tourer. I use panniers and secure my tent and sleeping pad across the rear panniers. There are boatloads of great tail lights available that mount on the seatpost or one of the tubes on the bike, but those lights cannot be seen because of my tent and sleeping pad are in the way. So I'm in the hunt for a great rear tail light that will mount to my rear rack mount. What say ye?
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
There's a bunch of lights with dedicated rack mounts.
Cateye reflex is a good option because you don't have to remember to turn it on and it has a built in reflector.
https://cateyeamerica.com/products/reflex-auto
Cygolite have a rack mount if you want a brighter option.
https://cygolite.square.site/product...&category_id=4
Quoted: 523 Post(s)
Liked 230 Times
Are you into a little DIY? Someone asked me this question a couple of years ago and I have pictures of a very easy DIY that uses three parts, a bolt, an L shaped corner bracket and a short piece of 1/2" PVC irrigation pipe both of which can be bought from Home Depot or a similar store. It's picture heavy so see the Private Message I will send you later today.
Quoted: 3462 Post(s)
Liked 1,470 Times
No irrigation hose here, but I fabricated a bracket from a piece of angle aluminum from the hardware store. Used a hack saw, drill, few nuts and bolts. I mounted it extra low so if something hung over the back of the rack, it did not change the light beam, an earlier one I made would sometimes have the light aimed too low if something on the rack pressed down on the light.
Some Planet Bike lights and possibly some others include a bracket that will wrap around a seatstay that has a smaller diameter than a seatpost. I have wrapped some inner tube rubber around rack tubing to make it thicker and then used the seat stay brackets to mount lights on a rack. When touring, I like a spare taillight, so usually have two on the rack. In the photo, a reflector is installed on the rack light mounting plate. This light mount did not take any extra tools like a saw or drill, used a scissors to cut the inner tube rubber.
If you can't find it here, you can go to Shapeways (3D printing marketplace) and search for your favorite light. You'll almost certainly find someone has made one there. That's where I got one for my Garmin Varia Radar+light.
Likes For Rick:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 568 Times
Busch + Müller (Germany) make a variety of lights, including ones that mount on the rear of a rack.
Battery powered:
https://www.bumm.de/en/products/akku...cklichter.html
Dynamo generator powered:
https://www.bumm.de/en/products/dynamo-rucklichter.html
E-Bike powered:
https://www.bumm.de/en/products/e-bi...cklichter.html
Myself, I've got a pair of CygoLite Hypershot 350 USB. CygoLite makes a rack mount adapter, if that's your preferred mounting spot. Very bright light. Good range of flash patterns. With two of them, one on the rack and one on your helmet, seat post or seat stay, it's all but impossible to not easily see a bike from a few hundred yards away.
https://cygolite.com/product/hypershot-350-usb/
Battery powered:
E-Bike powered:
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
ALL Bontrager flare lights can mount to the light bar of a rear rack.
I recommend the Bontrager Flare RT. If you buy this light it comes with a seat post mount. The 2 part seat post mount has the rubber strap and a plastic adapter recessed in the rubber strap that you can remove and mount to the rear rack light bar with a small socket screw since it has a brass threaded bushing in it. It’s done this way on purpose for this reason.
This mount part can also be bought separately at any trek dealer as well as the light obviously:
https://www.trekbikes.com/us/en_US/e...t-kit/p/25674/
Quoted: 4560 Post(s)
Liked 2,802 Times
Planet Bike, Bontrager, Portland and a few others make (or made) inexpensive, very good and long lasting rack mount taillights that used AA and AAA batteries. I still have one or two for my early 1990s Univega hybrid with rear rack. They bolt into the holes already drilled into most racks. Pretty standard sizes. And it's easy to drill new holes or add sheet metal brackets if needed for custom fit.
And I have two or three sets of AA and AAA taillights that clamp to the seat tube or seat post but can be adapted to a rear rack with some sheet metal brackets and bolts.
Much as I prefer newer, brighter USB charged headlights, some of the older style taillights with AA and AAA batteries are still just fine for most purposes. The main advantage to super bright USB taillights like the Cygolite Hotshot and Hotrod is for daytime visibility. Those Cygolites are really too bright for nighttime group rides -- great way to blind your buddies behind you. So I'll use both types on some rides.
I discovered that Cateye ViZ, Portland Design Works, and Planet Bike rack mount tailights all use the same mount form.
Planet Bike is cheapest to buy just the mount (6$) for using the same light on more than one bike.
When in town I use the USB ViZ450 and have a AAA battery powered PDW Danger Zone for off grid touring.
As an aside, Planet Bike also use a front headlight mount (they have more than one) that is the same as B+M and is only $6 allowing me to also switch my big B+M IQ headlight between bikes.
Likes For Paul_P:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
thumbs up to the DIY suggestions. That's what I do for my tour bike and for various light brands. I also 3D printed some brackets.
I also have a 3D printed version for my Garmin Varia radar and light combo that fits on a rack. I got it from the marketplace on Shapeways.com.
J
Quoted: 626 Post(s)
Liked 402 Times
Cygolite, Specialized and Niterider all have rack mounts for their lights. I use the versions of both that are 300 lumens except for the specialized that is lower lumens..
I mounted a tubus fender support upside down. Attached it to the tail light mount on the tubus rack. I mounted the Nitto rack accessory to it.
Quoted: 25 Post(s)
Liked 13 Times
Thanks!
J
J
