Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Any of you totally recovered from or avoided cyclist's syndrome?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 10-03-16, 03:14 PM
johnsmith246
Hi all,
Two years ago I did a route of 40-60mi a day over 11 days on my then-new touring bike, and ended up with some serious perineum pain during and after (12 months after!) the route. The pain in that area would start within the first hour of each ride, but I was stupid and thought it was a matter of getting used to it.
I've been much, much better over the past year or so -- pretty much "cured", but not quite. My urologist says it's OK to go back to cycling, but I should stop if the pain comes back. I've been cycling 3 miles every day and it's not been a problem. I'm hoping that at this rate I'll be totally recovered in the next few years.
Now I want to prepare for a 5-week cycle tour, hoping to do again 40-60mi a day. And I've spent a lot of time and money making sure the pain won't come back. But I'm still getting some pain in that area, although it's nowhere as bad as it was.
I recently had my bike professionally fitted, which included having the saddle replaced as per the gebioMized pressure mapping. That made a huge difference. The peak pressure went from 0.9 bar to 0.5 bar, and is now better distributed; this was the best saddle out of the 10 or so I tried.
But I still got some minor pain during and after ~30mi routes, so following the bike fitter's advice, I bought a pair of Endura FS-269 Pro SL bib shorts. Based on the extensive research I did, these seem to be the very best at avoiding this type of injuries. I rode 30mi with them, but frankly, I'm not sure they make a huge difference compared to my cheapest cycling shorts.
So, what else can I try? Before getting a "proper" touring bike, I was doing similar routes on a much cheaper, badly fitted, old, hybrid bike and never felt any pain. Too bad it can only accommodate a rear pannier!
I'm considering getting a second pressure mapping from Cyclefit, who seem to be the best in the UK -- They'll probably have an even larger selection of saddles I could try. Or maybe go to a cycling physio.
I'd really appreciate any advice you could give me!
Cheers.
johnsmith246 is offline
Old 10-03-16, 09:16 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1793 Post(s)
Liked 37 Times in 29 Posts
Never heard it called "cyclist's syndrome" before. We know there are cyclists who have permanent ED as a direct result of cycling.
The worst I ever had was a case of the "numbies" which lasted 3 days. That was a result of one ride where I was in the saddle for about 9 hours. My wife told me that wasn't going to ever happen again and of course she was right. I then tested saddles until I found one which didn't make me numb no matter how long I was in the saddle.
The OP is now complaining of "pain," but doesn't say where the pain is. Numb genitals is intolerable. Painful sit bones just means you aren't riding enough. Big difference.
Results matter
Carbonfiberboy is offline
Old 10-03-16, 09:57 PM
Leisesturm
Quoted: 1236 Post(s)
Liked 18 Times in 17 Posts
The o.p. is throwing real money and time at this and it would appear the problem isn't completely solved. It could be as CFB surmises "not enough time in the saddle" or in other words "too much too soon". I am not one of those who believes in "the perfect saddle is out there you just have to sift through piles and piles of them until you find your perfect..." No, just no.
He may be a good candidate for SMP saddles. I can't justify the cash outlay myself. Tourists are the worst when it comes to being pro-active about getting up and letting blood circulate in the area under discussion. The best saddle in the world won't help you if you just grind away hour after hour.
Edit: https://www.stevehoggbikefitting.com...ll-about-smps/
Leisesturm is offline
Old 10-04-16, 03:13 AM
CliffordK
CliffordK's Avatar
Quoted: 8522 Post(s)
Liked 79 Times in 71 Posts
I'll ride just about any seat. But, I was thinking the same... look for a seat with a center channel. Several brands available.
Brooks seats also have a strong following.
I've been a bit skeptical of the selle anotomica, but some people like them. Maybe like a cross between Brooks and SMP.
The MoonSaddle (and related seats) is also very unique, and perhaps worth considering.
CliffordK is offline
Old 10-04-16, 06:45 AM
johnsmith246
Thank you so much for your replies.
I haven't come across the SMP or Moon saddles, but I'm taking a note to do some research.
To clarify: The pain/numbness is still in the perineum, not the sit bones.
I forgot to mention that I got epididymitis as a result of that route two years ago, and I'm sure that's the pain that's coming back when I cycle (nothing else triggers it).
Cheers.
Old 10-04-16, 08:40 AM
Doc V
Bikes: Novara Trenta Road, Trek ZX6000 MTB
The Kontact saddle (Kontact Bicycle Saddles) was designed to place you on your sit bones where you weight is supposed to be. This helps keep the pressure off of the perineum and the surrounding soft tissues. Pressure in these areas causes numbness due to pressure on the nerves. It was designed by an experienced cyclist and physical the****** with a Master’s degree in biomechanics. They have a trial period before buying.
At first your sit bones are a little sore because most saddles do not place the weight on only the sit bones, but after 2-3 rides it goes away. The only downside is if you like to shift around in your saddle it does not give a lot of surface area for doing that.
Doc V is offline
Old 10-04-16, 08:52 AM
andr0id
andr0id's Avatar
Quoted: 1420 Post(s)
This is the core of the matter.
The saddle should be firm enough to solidly support you sitting on your ischial tuberosities, NOT any soft tissue.
A saddle with too much padding will put pressure on soft tissue and not support you on those two points.
Shorts with too much padding may put pressure on soft tissue.
And a rider with too much padding may also put too much pressure on soft tissue.
andr0id is offline
Old 10-05-16, 12:07 PM
berner
Quoted: 300 Post(s)
Liked 33 Times in 27 Posts
As a card carrying old guy I remember a few farmers who still used horse drawn farm equipment. They would sit for many hours each day on a cast iron seat while using that equipment. Those seats were contoured to the back side and were very wide. I've used that type equipment myself, though drawn by a farm tractor and know those seats to be very comfortable. A bike saddle has to work differently so the shape needs to be different. It will not be true for everyone but for me, a wide saddle (at least 155mm) works best. I also find comfort with a cutout area on the center line. A wide saddle at the sit bones tends to be wide also just ahead of the sit bones and many find such a saddle uncomfortable. To my mind, a shape similar to the Kontact, wide in the back but narrow forward best for myself.
My overall point is that it takes a while to identify the saddle characteristics that are most likely to satisfy and there are still many variations within such a category. There is no other answer but to try many saddles and to range in on saddle types first. I've been at the point of giving up on cycling several years ago. At that point I began customizing my saddle and finally found comfort.
berner is offline
Old 10-05-16, 01:04 PM
philbob57
Quoted: 245 Post(s)
Liked 25 Times in 19 Posts
I suggest reading
https://www.cervelo.com/en/engineeri...-road-saddles;
ismseat.com theory (http://www.ismseat.com/technology);
Steve Hogg on Selle SMP seats - just search the web on 'steve hogg smp' (no quotes).
One significant point to remember: if you reach your handlebars by rolling your pelvis forward instead of bending your back, you won't be riding on your ischial tuberosities; you'll ride on your pubic rami. If you bend your back, you might ride on the tuberosities, but you'll also risk significant damage to your back.
If you use an ISM or Selle SMP saddle as expected by the designers, you might find other objections to the saddles, but you almost definitely won't get numb.
Most Selle SMPs are pricey, but I'm using a TRK model, which I got from Amazon for $51 - $80 from an LBS, but no LBS I called had one in stock when I wanted one.
Best of luck solving your problem.
philbob57 is offline
Old 10-05-16, 01:20 PM
CliffordK
CliffordK's Avatar
Good point.
You don't necessarily want all of one's weight sitting on a single bone.
Of course, cycling is a little different from tractors with much more dynamic leg movements.
I've been experimenting a bit with carbon fiber saddles. A bit odd... like sitting on concrete. But, not that bad either, once you get used to the seat.
Old 10-05-16, 09:15 PM
Carbonfiberboy
Cheers.
I had to look that up. Maybe cycling isn't for you. Another approach which works well for some is simply to limit the hours in the saddle. Maybe it's 2, maybe 3.
Results matter
Old 10-06-16, 01:02 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 215 Times in 179 Posts
Thin Un padded/but Lined Bike shorts + a Leather Brooks saddle and I can still get it 'Up' ...
after a multi Month Cycle tour pub crawl thru Ireland and Scotland ..
Any 'Issues' Likely more related to Becoming Old
OP consult a MD Urologist , not a Bike Forum.
fietsbob is offline
Old 10-08-16, 07:43 AM
Road Fan
Road Fan's Avatar
Quoted: 805 Post(s)
Liked 10 Times in 9 Posts
Hi all,
Cheers.
Perineal pain is one of my problems in cycling, as well. So is the intoxicating feeling of a lot of power in my legs as I pedal. The power seems greater when I raise my saddle to get a longer leg extension. But the trade-off is that with my saddle on the high side my hips rock back and forth.
What helps me is to iteratively (just a few mm at a time) lower the saddle so my hips don't rock, then position the saddle (tilt and front-back) so my body isn't inclined to slip forward off of the "platforms." Usually when this is done I have to make a small adjustment or two height adjustment or two.
The good spot is when my knees don't hurt (saddle not too low), my spin is fast, free, and easy, I don't have peri pain when I start the ride with it healed, and the shorts at the end of the ride have not sign of blood where the peri is covered.
I use the Selle Anatomica, but I've found the same approach has helped me with Brooks and Specialized saddles.
I haven't found an Ann Arbor fitter who can really help with this procedure. Invariably even the best ones position by by formula.
When I'm done with this (it's happened only twice!!), usually I find my hands are lightly loaded, and I can pass the Hogg no-hands test.
Road Fan is offline
Old 10-10-16, 11:56 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Rotate your Hips More Upright so you dont press that part against the saddle Nose as Much .
fietsbob is offline
Old 12-23-18, 06:31 AM
lazysunbather
Hi, i've recently done a few rides and developed the same symptoms. Basically from an ill fitted saddle. Still the same feeling after a month off the bike. Has yours improved now further on?
lazysunbather is offline
Old 12-23-18, 07:54 PM
Carbonfiberboy
Zombie thread. The OP is probably not going to reply. See your urologist - you have a problem.
Results matter
Old 01-04-19, 04:00 AM
Road Fan
Road Fan's Avatar
Quoted: 805 Post(s)
Hi all,
Cheers.
I'm not a doc and certainly not an expert in perineal issues, though I have had perineal pain. Did the doctor identify what your risks are if you just kinda go for it?
Oh yeah, zombie thread twice over now!
Road Fan is offline
Old 01-07-19, 10:25 PM
50PlusCycling
50PlusCycling's Avatar
Quoted: 94 Post(s)
Liked 3 Times in 3 Posts
Proper bike fit is the first thing to get right, then you need time in the saddle to give your body time to adjust. Anyone who goes from occasional rides to a long period of 40 to 60 miles per day is asking for trouble.
When I have been off the bike for the winter, I know that when I get back on the bike I will have soreness for 3 or 4 weeks as my backside gets used to the saddle. No combination of saddle, shorts, and bike fit will prevent this soreness, it's completely normal. I would not attempt any long rides without at least 6 weeks to prepare. Unless you have some physical impediment, any combination of a decent saddle,shorts, proper bike fit, and time on the bike will eventually cure soreness.
50PlusCycling is offline
Old 01-09-19, 11:27 AM
Carbonfiberboy
Soreness isn't the issue on this thread. The issue is "numb dick." Soreness is acceptable, this latter issue is not, no, never, totally not acceptable. Perineum pain usually doesn't start until after one has had a numb dick for quite a while. More saddle time is not helpful, quite the contrary. And contrary to what one reads, females have a very similar problem with a similar solution - hole in saddle.
Results matter
Old 01-09-19, 08:45 PM
50PlusCycling
Quoted: 94 Post(s)
I've been riding for a long time, I completed my first century at 13, competed in races in America and Europe, and have experienced every discomfort possible on a bike. I've broken bones in crashes, have a few scars from road rash, been hit by cars three times, and have been stitched up as much as a baseball mitt. I've worked in a bike shop, and fitted many a rider. There isn't much about bicycles and cycling that I don't know.
You simply do not get on a bike and go for a long ride without getting accustomed to it. You cannot judge what will make you sore or numb without a fair amount of saddle time, and it's best to track down fit problems early. I haven't been on my bike for a couple of months now due to work, travel, weather, and the holidays. But if I go out tomorrow for a 100km ride, it doesn't matter what saddle, shorts, or bike I am riding, I am going to get sore as hell, and probably numb as well. Numbness can be caused by pressure, but it can also be caused by having blood circulation cut off to a nerve. Blood circulation to the perineum improves over time as you ride, just as circulation improves to your legs and lungs. It takes time.
Numbness usually happens early in any ride, and if it happens, you need to address it's cause. The easiest thing to do is "adjust" things in your shorts a little, and often this helps. The next thing is to adjust your position in the saddle until you get into the "sweet spot." I hate having to stop on rides, because once I get going again, it takes a little time to get everything in the proper position again. But inexperienced riders often don't consider such things, they simply sit on the bike and start riding, and when numbness or pain occurs, the first thing they blame it on is their seat and/or shorts.
Believe me, it took several years before I fully understood how to properly set up a bike, and to find my most comfortable position.
Old 01-09-19, 10:47 PM
Carbonfiberboy
You should read this article: Erectile Dysfunction and Bicycling » Sexual Medicine » BUMC
Numbness is additive because every time you get numb, you've caused damage. Numb is something one never wants to experience. The more you ride numb, the closer you get to ED. That's a fact. You can dispute that, and go ahead. But please, please, do not imply that a little numbess is OK. Numbness is never OK. Other riders are not you. The existence of threads like this, and your statements about inexperienced riders make that case.
It's certainly true that each rider must get a good fit to be really comfortable, though I believe that's not as important as many people think, judging by what I see on double centuries, and on my own experience. I believe being fit is more important than bike fit. I can ride a century on any bike where I can reach the pedals. Heck, PBP's been done on SS comfort bikes.
That said, the only way to judge if a saddle is going to work on long rides is to do a century on one. They all mostly feel OK until after the 3rd hour. I always do a century ride on a new saddle, right out of the box. How else will I know whether it'll work for me or not? And doing that, sometimes I get sore and sometimes I have to stand a lot. Has to be done, though. And that said, of course the article I posted shows that this level of devotion to bike and saddle fit isn't necessary for the vast majority of riders who ride 2-3 hours a week. However posters on this forum are more likely to want to ride longer distances, hence my concern for their sexual health.
If I go out for a century tomorrow, I will experience no butt pain, and no numbness. Why? Because not only is my fit correct, my saddle is perfectly suited to the shape of my undercarriage. That latter is actually more important than exact fit. I don't have two bikes which fit exactly the same, yet I have the same experience of no pain on all of them because they all have the same saddle. Yeah, I ride a lot. I tell folks that sex after a long bike ride is a good check on your health.
Many years ago, I did a 150+ mile ride, after which I couldn't do it for 3 days. My wife told me that will never happen again. I took her at her word, went through about 20 saddles over the next few years, and it never happened again. I finally gave those saddles to a charity bike shop. I've ridden several 400k day rides, many double centuries, and many 100+ mile mountain rides without butt pain or numbness. The saddle just disappears if it's the right saddle and you ride a lot. Good shorts help, too. Leg pain is still a feature.
We should all thank Ed Pavelka, who bravely brought this issue to the attention of cyclists in 1997.
Results matter
Old 01-16-19, 10:07 AM
bnewberry
Quoted: 59 Post(s)
This is an important topic, even if the original poster is no longer around.
I have found that the biggest contributor to any issues related to numbness for me hwas with padded cycling shorts. I changed to the thinnest pad I could find and this solved most of the issues. Using a seat with a center cut out fixed the rest. Interestingly, using a thick pad with a cut out still results in some issues, although not as bad.
bnewberry is offline
Old 03-17-19, 07:43 AM
rbk_3
rbk_3's Avatar
Bikes: Trek Emonda S6
Quoted: 68 Post(s)
I had to give up biking. It has been 18 months since I road and I have pain every day since, in my perineum. I have a dull ache that won't go away and I've been to a million specialists and they cannot tell me what is wrong. Sitting and any type of exercise flares me up. It has ruined my life.
I had a properly fitted Specialized Power Saddle and everything.
You can read how it all started here
https://www.bikeforums.net/road-cycl...ue-solved.html
rbk_3 is offline
Old 03-18-19, 02:02 AM
lazysunbather
Turns out my issues were ZERO to do with cycling or saddle. My issues are down to a pelvic floor dysfunction. Where the pelvic floor muscles become tight and cause no end of problems. So I would certainly avoid Dr's, and seek help from a specialist pelvic floor physiothe******. Sounds to me like it could be that, or if not certainly get it ruled out.
Old 03-18-19, 02:03 AM
lazysunbather
And it's pretty common with cyclists/runners too!
