Go Back  Bike Forums > Bike Forums > Winter Cycling
Wore out my first studded tire
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 12-20-16, 05:37 PM
gecho
Bikes: 2009 Trek 520
Quoted: 58 Post(s)
The rear 700x35 Schwalbe Marathon Winter tire on my touring bike seems to have reached the end of its useful life. I got it back in late 2010 and put about 3,850 km on it. I've had numerous flats on the tire since the tail end of last season including one today which is not something I want to deal with when its really cold.
A few observations of the current state of the tire. The carbide studs themselves are still in good shape even with a lot of riding on clear asphalt, they really do last longer than the tire itself so I pulled them out to keep. The outer row of studs are in excellent shape, judging from the condition of their tread knobs, those studs seem to rarely make contact with road. Center tire knobs have worn down but are far from worn off. Some cracking of the sidewalls and bead rubber. Steel bead wire has popped out.
I think what did the tire in was due in part to the fact the studs wear so slowly. As the rubber wears down the studs seem to get pushed further into the casing. I noticed that water was able to get into the tire from outside via numerous stud pockets. In addition to getting pushed inward the studs can get pushed back and forth causing stretching of the rubber around the stud leaving gaps. Although the tire has puncture protection, it is only in the very center of the tire and not beneath any of the stud pockets. So the stud pockets without studs or pockets that have become deformed are an avenue through which the tube may easily be punctured. At the end of a season it might be worth checking over the tire and filling any gaps or empty stud pockets with something like Shoe Goo.
Since the side studs didn't see much use I'm planning on replacing the rear tire with the Schwalbe Winter tire that only has center studs.
gecho is offline
Old 12-20-16, 06:43 PM
benetga
benetga's Avatar
Bikes: Trek 1.1- Commuter, Nashbar Carbon105 -Sunday ride, Specialized Rockhopper-SS Winter Bike
Quoted: 14 Post(s)
Thanks for the information. I wondered the longevity of winter tires. I am now in my second year using Schwable Winter tires and the're showing little wear.
They seem to roll easier after using them for awhile. I run mine with Mr Tuffy tire liners just in case.Getting a flat on a dark frigid morning is not something I want to deal with.
benetga is offline
Old 12-20-16, 09:45 PM
Archwhorides
Archwhorides's Avatar
Bikes: Death machines all
Quoted: 233 Post(s)
Liked 10 Times in 8 Posts
Very useful information in this report, thanks!
Work is the curse of the drinking classes - Oscar Wilde
Archwhorides is offline
Old 12-21-16, 12:27 AM
Bike Gremlin
Bike Gremlin
Bike Gremlin's Avatar
Bikes: Custom made on Scott Speedster frame, Custom made on a 1996. steel MTB frame (all but frame changed at least once in the past 20 years).
Quoted: 945 Post(s)
Liked 3 Times in 3 Posts
Side studs are important. In case of getting into an uneven icy part (car tyre track got frozen) - easier to climb out of it with side studs. Also, in case the bike starts leaning on either side, for whatever reason (intentional, or a slip) - side studs are good last resort measure.
Bike Gremlin is offline
Old 12-21-16, 12:36 AM
dabac
Quoted: 813 Post(s)
Over here there are numerous reports of SMW studs wearing through to the inside. It happens to Suomityres/Nokian eventually too, but usually at a higher mileage.
You can eke out a little more life out of them by lining the tire with duct tape, if you want to put off buying new tires to next season.
And while your center studs certainly sees most action, I'd be wary about trading down. It's like removing the compression bandage from the first aid kit based on "it's only the band-aids getting used anyhow".
dabac is offline
Old 12-21-16, 07:50 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 814 Post(s)
Liked 94 Times in 53 Posts
THanks for sharing I found that interesting. Would tire liners have helped?
BobbyG is offline
Old 12-21-16, 09:18 AM
gecho
Quoted: 58 Post(s)
I'll definitely keep the full compliment of studs for the front wheel. On my mountain bike I use an Ice Spiker on the front and a Marathon Winter in the rear. I like the extra front end stability and an aggressive front tire doesn't seem to slow me down as much as having one in the rear does.
Liners probably would have got me through the season, but since the sidewalls were cracking I decided to just replace the tire.
gecho is offline
Old 12-21-16, 09:34 AM
Divebrian
Quoted: 115 Post(s)
Since I live in Florida, I have a question for you cold weather guys. Are you using studded tires on the street or offroad. I won't ride in anything colder than 55, but you cray people do intrigue me.
Divebrian is offline
Old 12-21-16, 09:38 AM
Bike Gremlin
Bike Gremlin
Quoted: 945 Post(s)
I ride in the street (public roads).
Rarely off road in the winter.
Lowest I did was -20 Celsius. If it's fine for skiing, it's fine for cycling.
Old 12-21-16, 09:43 AM
9volt
9volt's Avatar
What tire pressure are you running? I'd be interested to hear what pressures people recommend with 700c and 26" studded tires. This is my first year on studs and the 26x2.1 Nokain tires I'm using seem to work best at lower pressures. The outer studs appear to get more use this way.
9volt is offline
Old 12-21-16, 10:26 AM
Tim_Iowa
Tim_Iowa's Avatar
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 166 Post(s)
Both!
But seriously, studded tires are usually intended for pavement. They keep you upright if you cross any ice. Ice is common when the snow melts during the day and re-freezes overnight.
Studs don't do much off-road--unless the off-road surface is ice.
Tim_Iowa is offline
Old 12-21-16, 10:27 AM
BobbyG
BobbyG's Avatar
Quoted: 814 Post(s)
Yes, they sound done.
BobbyG is offline
Old 12-21-16, 10:34 AM
gecho
Quoted: 58 Post(s)
With my 700x35 marathon winter tires I run my pressure close to the max rated. The sidewalls are so stiff that the rolling resistance noticeably increases when running it at lower pressures on hard surfaces. They are so narrow nothing is going to make those tires float on snow anyway. On my mtb I run the pressure just high enough that I don't get any tire flop while cornering.
gecho is offline
Old 12-21-16, 07:07 PM
PaulRivers
Quoted: 432 Post(s)
Liked 4 Times in 3 Posts
If you never see ice on the road ever, you should not get studded tires. Studs are for gripping into ice, they have less traction on dry open pavement than rubber does.
PaulRivers is offline
Old 12-22-16, 03:46 AM
dabac
Quoted: 813 Post(s)
I use studs when/wherever the ride surface has considerable parts of ice or hardpack.
I can ride in any temperature I can ski or skate in.
Only problem is the risk of mechanical issues. The bike is more likely to suffer a mechanical issue than the skis or skates.
dabac is offline
Old 12-22-16, 04:02 AM
Bike Gremlin
Bike Gremlin
Quoted: 945 Post(s)
I use lower pressure when there is snow. They grip noticeably better. For pavement with bits of ice - max pressure, so studs stay off the pavement and, like you said, less rolling resistance.
Old 12-22-16, 04:04 PM
noglider
noglider's Avatar
Quoted: 5373 Post(s)
Liked 89 Times in 68 Posts
If you moved, there is a good chance you would get used to it. I know lots of people who come from hotter climates than yours, and they bundle up the same as we do, and they learn to live with it. In the US, people who ride in the winter are hardier than average, but not because we're crazy. It's a matter of refining the gear and clothing to work for us, which takes trial and error. Last winter, I tried a ski helmet, which, for me, was transformative. I hadn't realized how cold my head and face get until that went away.
noglider is offline
Old 12-23-16, 10:26 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
FWIW Suomi Nokian studded tires use a quite long wearing harder (even when it is warm out) compound..
fietsbob is online now
Old 12-23-16, 12:33 PM
rumrunn6
rumrunn6's Avatar
Quoted: 3029 Post(s)
Liked 114 Times in 92 Posts
time to shop!
rumrunn6 is offline
Old 12-24-16, 09:44 PM
aggiegrads
Quoted: 76 Post(s)
I use the Marathon winter 26" on a Long Haul trucker. I weigh about 160 pounds and I run pressures like this:
55psi - little to no chance of ice, just too lazy to change wheels - no stud contact
35psi - below freezing, good chance of ice - this leaves the center row of studs in contact with pavement
25psi - below freezing, definite ice or significant hardpack - both rows of studs contact pavement for max grip
I've gone four seasons with 2-3 12 mile roundtrip commutes and the tires show no wear on the outside. I have never flatted, so I don't know what the insides look like.
I've been super happy with them and would replace them in a heartbeat.
aggiegrads is offline
Old 12-24-16, 10:35 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1637 Post(s)
Liked 60 Times in 51 Posts
If you ride in traffic, seriously consider NOT side studs just front. A very foreseeable situation - you are over to the right and there are car tire ruts in the bike lane or you are out around the rut of the cars' right tire. There is a car behind you, either trying to pass or just driving a little too close. It is far enough to the left that while it is uncomfortably close behind, not an issue. You happen to be in a tire rut. You get a little too close to the left side of the rut and need another inch. Your front side spikes do there job ans you climb out, but you do find you have to oversteer some to do it. Now your front tire is a few inches to the left of your rear - but! - your rear tire won't climb out, no side studs. It just keeps going down the rut.
This quickly gets really bad. Bike goes 90 degrees, front tire wanting to go left, rear straight. Bike lays down. You scramble off and don't get hurt - until that car bumper or right front wheel hits you because he cannot stop and that is where you now are.
I did virtually this with the same dynamics on smooth ice. Fortunately the car wasn't there. I lost it, had to counter steer to the left to stay up. Got my front tire over the painted bike lane stripe successfully and thought I could keep the bike up but lost it when the rear tire slide out on the same stripe. I ended up well into the car lane. I have also (in fact just a week ago) had to deal with auto ruts in the bike lane in traffic, same (good snow/ice) tires front and rear and has to do the first scenario above, but the rear tire behaved and climbed out also. Put me two feet closer to the cars but parallel, upright and in control.
If you pass on the side studs both front and rear, you will do more crashed but generally, your tires will not get very far from the rut that took you down so your body and head only get so far toward the line of cars.
Yes, rear tires that slip more make for (in general) "better" crashes. Fewer broken bones, etc. But swerves into cars makes for a much worse outcome and the odds are that their ABS brakes aren't going to cut it. Not if they are on the same stuff you are. And drivers will NOT be expecting your sudden near right angle turn.
I have always ridden identical tires front and rear in the winter. They have served me well (for the most part - there was always the one ride where the tires were "wrong" when I crashed three times on the same street). But that paint stripe crash stood out as the one that put me into traffic and it was the rear tire not following the front that did it.
Ben
79pmooney is offline
Old 12-25-16, 12:52 AM
Bike Gremlin
Bike Gremlin
Quoted: 945 Post(s)
If you know what kind of tyres you have, you won't try such manoeuvres. Even with both studded tyres, moving out of a rut with a car close behind is a dangerous thing to do.
Old 12-25-16, 09:30 AM
gecho
Quoted: 58 Post(s)
I kept all the studs from the old tire so I can always put them in the new tire if needed.
gecho is offline
Old 12-27-16, 10:00 AM
wolfchild
wolfchild's Avatar
Quoted: 1333 Post(s)
Liked 37 Times in 21 Posts
I wore out a pair of Nokian Extremes 294's few years ago. The sidewalls ripped and the centre studs and treads wore out. I also pulled out all the side studs which were good and keet them as spares.
wolfchild is offline
Old 12-27-16, 03:48 PM
Rick Imby
Quoted: 239 Post(s)
I have almost always run home made studs. I first studded tires in 87 with roofing nails. They pushed back out quickly.
I now use self drilling hardened K-lath screws. I put an old inner tube I have sliced around the inside over a thorn tube.
I run these at max psi for the tire.
Tire selection makes a big difference as I run the stud up through a tire stud.
Rick Imby is offline
