Go Back  Bike Forums > Bike Forums > Triathlon
Do you use a bigger-than-53T chainring?
Triathlon Swim / Bike / Run your thing? Drop in our new triathlon forum for the latest in training & gear. From beginner to expert, and sprint to ironman.
Old 10-16-17, 08:49 AM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Bikes: BMC SLR01 TeamMachine Disk Di2; OPEN new U.P. Di2
Quoted: 798 Post(s)
Liked 17 Times in 13 Posts
Over the weekend, with standard 53/11 gearing, I found myself spun out on a mild 5% down slope. I was spinning a little over 110 rpm at the time and I don't anticipate developing a lot of torque at speeds higher than that, so I'm considering going to a bigger chainring. I don't think a 54T would give me enough to justify the bother/expense, so I'm considering a 55T.
Does anyone here use a 54T or bigger big ring? Is it worth the trouble/expense? What small ring do you have paired with it? Does the bigger ring impact your shifting? Besides moving it up a little, is there anything more you have to do with the front derailleur? And finally . . . do you have cranksets that you would recommend?
FlashBazbo is offline
Old 10-16-17, 02:11 PM
ZIPP2001
Life Is Good
ZIPP2001's Avatar
Bikes: Kestrel RT900 Road Bike, Zipp2001 Singlespeed, Zipp2001 TT Bike, GT Mountian Bike, Trek Stache 5, Giant Momentum Fat Bike
Quoted: 127 Post(s)
Liked 43 Times in 30 Posts
Back when I did a weekly TT series I was running a 56/39 - 11/21. I don't do TT's any longer and run a 54/39 and several different combos in the back depending on terrain 11/21, 11/25, or 11/27. I still try and get out on it once a week and sometimes several times a week. If your already running a 53/11 then I would consider the 55 and skip over the 54. The bigger ring has never had a negative impact on my shifting. I still have my shifting set up as friction not index which allows for fine turning while riding. I do have a slightly wide front derailleur. I run an FSA crank but everyone has there own preference.
Here is it's present set-up.
ZIPP2001 is offline
Old 09-03-18, 11:29 AM
FSU421
FSU421's Avatar
Bikes: A bunch of Cannondales, and a Raleigh
Quoted: 10 Post(s)
I switched to a 56/39 set because I too was spinning out on downhills. I love the set up. I haven't spun out since the switch. I run 11-23 cassette, the bike is full DA 7700, it's older but still works perfect, never had any issues with shifting.
FSU421 is offline
Old 06-20-19, 06:29 AM
ribikeguy
Just another bike nut
ribikeguy's Avatar
I ran a 55/39 on my bike last year for the same reasons. Our local tris are hilly and I kept spinning out with my 53, the 56 solved that problem for me. Iím riding a different bike this year and looking to make it a 56 also. I need new cranks for this bike though, canít get a 56 for a 110bcd crankset.
ribikeguy is offline
gsa103
Road Cycling
19
09-21-13 05:03 PM
Digital_Cowboy
Advocacy & Safety
79
07-07-09 08:24 PM
Jerseysbest
Foo
36
05-09-06 02:56 PM
