2 x 11 or 3 x 10 for Commuting on roads?
Old 04-12-18, 09:53 PM
shawngs
Hey guys, Iím looking into getting a bike solely for commuting. Would 2 x 11 46/30 or 3 x 10 48/36/26 be a better setup? My commute is 15 miles each way completely on paved roads but there are a couple of long, steep hills. Iíll be carrying a pannier style backpack on a rear rack with computer, paperwork, etc. This bike wont be used for anything else (except maybe running to the grocery store).
shawngs is offline
Old 04-12-18, 10:21 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Bikes: '76 Paramount, Salsa Timberjack, Burley Samba, Terra Trike
Quoted: 1475 Post(s)
Liked 90 Times in 61 Posts
Yes, that sounds lovely
Genesis 49:16-17
Darth Lefty is offline
Old 04-12-18, 10:26 PM
Kontact
Kontact's Avatar
Quoted: 2145 Post(s)
Liked 4 Times in 4 Posts
Have you ridden the route before? What sort of gear ratios did you use?
Kontact is offline
Old 04-12-18, 10:56 PM
banerjek
Portland Fred
banerjek's Avatar
Bikes: Custom Winter, Challenge Seiran SL, Fuji Team Pro, Cattrike Road/Velokit, РOS hybrid
Quoted: 205 Post(s)
Liked 16 Times in 12 Posts
It's all about the terrain, rider, and bike. The triple will give you more overlapping gear ratios, better midrange as well as total range. Unless the 26 is too low for the climbs, I'd be inclined to spring for the triple.
banerjek is offline
Old 04-12-18, 11:07 PM
Aubergine
Bad example
Quoted: 771 Post(s)
Liked 16 Times in 13 Posts
Yes, it really depends on the hills and your legs. In Seattle (with plenty hills) a 26 tooth granny is a good thing to have. In your area? Only your knees can say.
Keeping Seattleís bike shops in business since 1978
Aubergine is offline
Old 04-12-18, 11:14 PM
ColonelSanders
ColonelSanders's Avatar
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1242 Post(s)
Liked 14 Times in 12 Posts
How big will your cassette be?
Even with a 2 x 11, I literally never use the smaller of my chainrings.
11 speed cassette's has made 3x's irrelevant, unless you desperately want to save a few pennies.
ColonelSanders is offline
Old 04-13-18, 01:43 AM
Branko D
Quoted: 10 Post(s)
I have 3x10 with 48/36/26 and 26" wheels and I'd say it's pretty awesome. I do in fact use the entire gearing range. The terrain here varies a lot and it's really nice. The grannies are definitely nice on 10+% grades, just shift down and spin. That said I use my bike for everything from recreation (involving riding on the flats and riding up the mountains both) to shopping with panniers on.
The only downsides to a 3x10 setup are a bit of weight (but no sense in being a weight weenie when you're planning on lugging panniers with stuff about) and that the 3x system can be a bit fiddly to adjust at times. Personally, I wouldn't trade it for a 2x11.
Of course some people might just not have the terrain where the use of a 18" gear inches low is warranted, but I do.
Branko D is offline
Old 04-13-18, 01:58 AM
Kontact
Kontact's Avatar
I don't know how I get home on Capitol Hill with a 42x25 low gear.
People's tolerance to climbing in different gears really varies an incredible amount. I don't think I have the patience to climb a Seattle Hill in a gear as low as 26xSomething.
Kontact is offline
Old 04-13-18, 05:27 AM
mcours2006
mcours2006's Avatar
Bikes: Giant Rapid, Bianchi Advantage, Specialized Roubaix, 1985 Gardin Quatro, Norco Threshold, Raleigh Serengheti MTB
Quoted: 1720 Post(s)
Liked 39 Times in 22 Posts
I'd opt for the triple as well, just because of the versatility it provides. Weight is not an issue with an issue, and it's no more difficult/easy to adjust than a 2x system.
I've got a 3x9 on my lugging-stuff and grocery-getting commuter, and though the shifters are looking very dated and beat up I am very reluctant to change it.
mcours2006 is offline
Old 04-13-18, 06:52 AM
Skipjacks
Skipjacks's Avatar
Quoted: 937 Post(s)
Liked 148 Times in 96 Posts
Another vote for the triple.
I went through this same debate last year for myself. I decided on the triple and I've never regretted it.
I don't use the smaller ring much, but it's nice to know its there when I need it. Occasionally I'll be at the end of a long ride and am just gassed and facing a hill...that smallest ring make a huge difference for the 1 mile out of ever 100 I ride.
It also comes in really handy when I need to cross a grass patch or something and my pavement tires get bogged down.
Skipjacks is offline
Old 04-13-18, 07:27 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 2463 Post(s)
Liked 102 Times in 69 Posts
That is a good question but ultimately won't make much difference if both cassettes have the same range.
The number of cogs a bike has on the rear doesn't make that much difference. The range of the gearing and how well the shift pattern works has much more impact. I would suggest that the reason you "literally" never use the smaller ring is because the shift pattern for doubles is horrible. It's not a system that lends itself to easy use like a triple does.
Exactly. This gear calculator allows you to easily see the difference. Granted this is a very wide cassette but you can substitute any cassette and the results are the same. The transition from the outer ring to the middle ring is smoother and more natural.
Let's pick, for example, transitioning from outer ring to the second ring on the 19 tooth cog. For the double, you go from a 68" gear to 44" gear which is a very large jarring jump. In terms of cadence, to keep the speed at 18 mph, you would have to jump from 90 rpm to about 140 rpm. To put it another way, it feels like you've dropped a chain.
The same shift on the triple goes from a 71" gear to a 53" gear. To maintain the same speed, you need to increase cadence to 120 rpm. That's still a lot but it's much easier to do than 140.
If you match the chainwheels (a 46 in both cases), the gearing gets even better for the triple. Now the same gear change results in a cadence change of from 90rpm to about 100 rpm.
You could even improve the double (make it more useful) by tightening up the chainwheel difference. Going to a 46/34 gives this shift pattern. It's a closer pattern at the expense of the low end. On the same graph, I've also tightened up the triple which makes for a closer ratio as well but, since it's a triple, you still have the low end gearing.
Compact doubles, in my opinion, were designed and marketed by people who have zero understanding of gearing or the needs of the vast majority of the public. Yes, they have a similar range but the range of the gearing is only one part of the equation...and a small one at that.
Stuart Black
An Good Ol' Fashion Appalachian Butt Whoopin'.
cyccommute is offline
Old 04-13-18, 07:53 AM
Buddha2499
Quoted: 23 Post(s)
I just switched to a bike with a compact double (34/50), 32 tooth largest rear cog. Previously I had a triple road bike gearing.
Iím a lazy shifter. I never used my smallest chain ring on my old bike, but I liked knowing it was there. Iíve been pretty impressed with the new bikes combination. The lowest gear is PLENTY low to get up any hill, to the point that I donít actually use it much. I donít miss having a triple chainring.
Buddha2499 is offline
Old 04-13-18, 08:02 AM
alan s
alan s's Avatar
Quoted: 1320 Post(s)
Liked 45 Times in 29 Posts
I vote for “it depends.”
alan s is offline
Old 04-13-18, 09:08 AM
pdlamb
Quoted: 964 Post(s)
Liked 35 Times in 25 Posts
If the gearing range is similar, which has the more comfortable saddle and the better paint color?
pdlamb is offline
Old 04-13-18, 09:13 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2028 Post(s)
Liked 95 Times in 79 Posts
Either one will do the job if you pick the chainrings and cassette appropriately.
I get by on 14 speeds total.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-13-18, 09:31 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
Im liking my IGH bikes, best , want higher end, lots of gears,? Alfine 11, like tech,? they offer a Di2 shifter..
With a chain tensioner even that can take a double crankset.. there are a couple gear box cranks that shift internally, with the chain not moving off the 1 chainring
functioning like a double and triple range..
fietsbob is offline
Old 04-13-18, 10:07 AM
HardyWeinberg
GATC
Quoted: 451 Post(s)
Liked 5 Times in 5 Posts
I use 1x11 42/11-36
I had 1x7 11-28 but needed to gear it down for bikepacking.
HardyWeinberg is offline
Old 04-13-18, 11:09 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 814 Post(s)
Liked 94 Times in 53 Posts
I vote for the greater range of the triple...especially in hill country.
BobbyG is offline
Old 04-13-18, 11:23 AM
Aubergine
Bad example
Quoted: 771 Post(s)
I am retired so I have time! Just as well. The days when I could get anywhere with a 42-25 are long gone.
Old 04-13-18, 11:43 AM
Kontact
Kontact's Avatar
I would much rather have a wide selection of closer ratio gears on the cassette than a granny gear that is available as a bail-out that never gets used. Especially if the effective low gear is pretty much the same between them. 10 and 11 speed give people the option of having both range and fairly close ratios on one cassette.
My earlier question for the OP and remarks about low gears were about what low gears he actually uses. As Aubergine and my different experience riding the same hills shows, what is more than low enough to one person can seem ridiculously high to another depending on their riding style. Around Seattle my usual low gear is a 39x26, which means 1% of the time I have to stand to complete a climb. If I had a 26 granny I would never use it, and if I went to the trouble of purchasing a bike with a super low gearing it means that I gave up some more useful gear ratios to have a capability that never gets used. If you have an 11 speed bike where you only use 8 of the sprockets, you really just have an expensive 8 speed bike.
That's why the OP should figure out what kind of low gearing he actually needs and then compare that to the ratios offered by the bikes he's shopping for.
Close ratio gearing is really nice. When you are tired and cruising home it is really great to have that 16t sprocket to shift into that best matches your speed and cadence rather than having to drop down to 17t.
Kontact is offline
Old 04-13-18, 11:50 AM
CliffordK
CliffordK's Avatar
Quoted: 8517 Post(s)
Liked 73 Times in 65 Posts
Is that 26T on the front or the rear, or both?
Lots of details here. Look at gear ratios not as simply the sprocket size of the front or rear, but a combination of the two. Calculators will also look at wheel size, but you can somewhat ignore it if all the wheels in the comparison group are the same size.
So, a 26T x 26T gives identical gearing to a 30T x 30T or even 42T x 42T.
A long/steep hill for one person may not be the same as for another person. If a long hill is about 20 miles of climbing, I'm not quite sure how one could fit two of them into a 15 mile commute.
I think cleats and being clipped in also affects whether you can do the big gear ratios or not.
Each of my bikes is a little different. For light commuting (no heavy trailers) or cargo loads, my preference would probably be something like say: 52x34 front, 11x26 or so rear. 11 speed.
More or less.
But, that is only because I'm getting old.
CliffordK is offline
Old 04-13-18, 12:04 PM
Dave Mayer
Quoted: 592 Post(s)
Liked 9 Times in 8 Posts
My recommendation is an unsuspended mountain bike from the late 80s to early 90s. 26" wheels. 3x7 drivetrain. Cheap (almost disposable) and bombproof.
For commuting with loads, a triple setup will be superior to any double or single ring solution.
Dave Mayer is offline
Old 04-13-18, 03:11 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 13 Post(s)
Liked 52 Times in 42 Posts
I have 2x9 (50/34, 11-32) and I literally never use the larger of my chainrings. (And I expect every bike I buy in the future will be 1x)
As others have said, you need to figure out what range of gearing your legs need on your terrain.
RubeRad is offline
Old 04-13-18, 04:37 PM
alias5000
Raised a new winter bike
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, 2007 Trek 6000, Circe Morpheus
Quoted: 140 Post(s)
As many have said before, it depends on the rider and terrain. I would avoid a triple setup, in which commonly used speeds result in me jumping between chainring 2 and 3 (middle & large) a lot; e.g. when 2x11 is too easy, but staying on 3xsomething easily results in a lot of cross chaining. Using the front derailleur a lot can become annoying pretty quickly.
alias5000 is offline
Old 04-13-18, 06:33 PM
ColonelSanders
My chainrings are 34/24 and I have an 11-42 cassette
