Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Feet Placement
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and donít know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. Itís more than just measuring your height, reach and inseam. With the help of Bike Fitting, youíll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here yaí goÖ..the location for everything fit related.
Feet Placement
Old 07-16-18, 04:46 PM
SoldSpartan
Quoted: 23 Post(s)
Feet Placement
How should your feet be while sitting in place with your bike?
SoldSpartan is offline
Old 07-16-18, 06:35 PM
pass the peas
like we used to say
Bikes: 2009 Surly Cross Check, ca.2013 Worksman INB, 2018 Breezer Doppler Pro
Quoted: 19 Post(s)
It's typical for the balls of your feet to be over the pedal axle. Your heels should not be rotated too far inward or outward, but relatively parallel to bicycle.
pass the peas is offline
Old 07-17-18, 12:40 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1790 Post(s)
Liked 37 Times in 29 Posts
Just sitting upright? Off the ground. Maybe your tippy toes touch. At a stop, butt off the saddle, ball of left foot on pedal, bike leaned slightly to right, right foot on the ground.
Results matter
Carbonfiberboy is offline
Old 07-18-18, 01:14 PM
rumrunn6
rumrunn6's Avatar
Quoted: 3033 Post(s)
Liked 115 Times in 93 Posts
right foot on top right pedal, left toes or foot touching ground. until the light tuns green, then push off with your left toes or foot & pedal with your right foot until the left pedal rises, then pedal w both feet
rumrunn6 is offline
Old 04-25-19, 07:16 PM
SoldSpartan
Quoted: 23 Post(s)
So let me get this straight how much of my feet do you want touching the ground while seating on the saddle?
Old 04-26-19, 10:19 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
You adjust the saddle height for pedaling not stopping..
If your frame design has a high BB , to reach the ground, you get off the saddle
shift your weight to 1 pedal , and put your other foot on the ground..
Now there is the Crank Forward cruiser.. leg extension is diagonal (no standing on the pedals for hills) ,
but saddle to ground is low, so you can stop and put your feet down.. ...
fietsbob is offline
Old 04-26-19, 01:48 PM
Iride01
Iride01's Avatar
Bikes: '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 862 Post(s)
Liked 26 Times in 23 Posts
I agree, if you are talking about when being stopped then the saddle height is not any consideration. If your frame geometry is such that you must get off the saddle, then the height of the top tube is what you need to be concerned with. If the frame was properly sized to you when you acquired it, that shouldn't be an issue.
Iride01 is offline
Old 04-26-19, 03:19 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
In my case , (not the OP) its a Bike Friday, essentially a step through .. Pocket Llama
I stop at lights with a foot up on the curb.. to stay in/on the saddle ..
fietsbob is offline
Old 04-26-19, 05:16 PM
rando_couche
Quoted: 133 Post(s)
Liked 13 Times in 11 Posts
Um, no. It depends on the geometry of your legs. My feet point outward at angles of 10 and 30 degrees relative to the respective knees. If I were to force my feet into line with my bike I'd need surgery in a few miles. Forty years of cycling experience taught me to do what my body says, not what some "expert" says.
rando_couche is offline
Old 04-27-19, 03:39 PM
pass the peas
like we used to say
Quoted: 19 Post(s)
I donít claim to be an expert. Thank you for sharing your experience.
Im sorry if I gave bad advice. I jumped into this thread assuming the question was about foot placement on the pedal and offered advice I thought was practical and correct.
Not to derail this thread too far off topic, but I am curious about your slew-footed cycling How did you deal with toe clips and straps back in the day? Does your 30 degree heel rub your crank arm? We can start a new topic or discuss this in pm if you like.
tommy2000
Bicycle Mechanics
0
06-26-17 12:33 PM
barok
Recreational & Family
1
03-27-13 02:21 PM
X-LinkedRider
Road Cycling
3
01-05-11 02:46 PM
RideStrong31
General Cycling Discussion
0
07-27-09 03:58 PM
misterE0
0
03-29-09 11:28 AM
