Rust proof?
Quoted: 50 Post(s)
Rust proof?
Since in my area have been getting lot of rain for the whole summer, my question has come up to the point where I try to find a solution Of my worrisome about rust building on my bike. Is there a proper way to equip/clean my bike to ride in the rain to prevent rusts from building? Before and after ride in the rain? Anything will help. Thanks.
wiping a wet bike off with a shop towel helps.
keeping the little "limber" holes clear helps to drain water out of the frame.
hanging bike up so moisture can flow to those cleared holes helps.
turning a fan on the hanging bike helps dry out the saddle faster.
also if real soggy, I lightly spritz the chain with wd-40 and wipe it off,lightly
with a paper towel - I know some will throw flame about the Wd-40 use.
Carbon fiber is corrosion proof, and titanium and aluminum are so resistant that even riding through brine all winter will not really affect them.
The chain and gears, and the spokes on the wheels are still susceptible, though.
Quoted: 4227 Post(s)
Liked 2,488 Times
Go to your local auto parts store or a hardware store and buy a spray can of automotive rustproofing oil...I've used a product called Rustcheck and sprayed it on the inside of my steel frames.
Liked 2,488 Times
Quoted: 50 Post(s)
Some people buy titanium framed bicycles specifically for their corrosion resistance (pretty much no natural environment on earth will affect them) and immunity to UV damage (which the epoxy resin in carbon fiber can be degraded over time by).
Frankly, unless you're riding your bike regularly through seawater in puddles or along the beach, I don't think it's really that much of a concern.
The inside of the tubing, mostly inaccessible except for the the seat tube when you remove the saddle post.
Quoted: 50 Post(s)
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
TriFlow. I've used it for decades on all sorts of mechanical equipment--especially bikes--and it's never failed me.
I see. Let's put the concern on frame and money aside. That leaves me the most important parts that flows me on the road which is pedals, chain, shifter(they are metals right) and the I'm..rest derailure(sp?) How can I keep up with rust free daily through rain or no rain?
I would give it a rinse with clean water after riding through brined/salted roads during winter, if that's a thing you do.
Quoted: 4802 Post(s)
Liked 3,922 Times
The salt air of places like Martha's Vineyard is a killer to bikes that spend their life in it.
I've treated several frames with AMS Oil Heavy Duty Metal Protector. One $8 can will do 3 bikes.
For bikes that are going to see a harsh environment, I pack the bearings in lots of marine trailer hub grease; the stuff that can both hold up at highway speeds under load and then get submerged several feet to launch the boat. Nothing a bicycle see will ever touch it. (Any auto parts store.) I also use that grease on threads.
If you really want a finish that will protect a steel frame in any conditions. paint it with a two part epoxy paint. (A brush does a surprisingly good job. Epoxy "flows" as it sets up and brush marks disappear. (Don't even think about touching the paint at this time!)
Ben
Ben
Problem is most components use chrome plated steel bolts..
there is no perfect cure short of the Moon
which is too small to retain an atmosphere, .. with Oxygen in it..
given Rust is Iron Oxide after all ..
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
I have seen some horrendously rusted bikes, but for the most part they were ones that lived outside in all weather. If you store your bike inside and do normal care and maintenance you should not have any issue with rust. There are a lot of phobic tendencies here about rust on frames, especially internally, and that sells a lot of products that supposedly treat the condition (the phobia, that is). I have never treated a frame with Frame Saver or the like and have had no internal rust issues on any of the many bikes that I own. I own 7 steel bikes ranging from 20-50 years old. My daily commuter bike, which gets the most abuse, is over 45 years old, ridden in all weather, all year and the only rust is the small amount that forms if I get a chip in the paint and don't attend to it quick. After every wet ride, I just wipe it dry with a damp rag. I do use anti-seize on the BB threads, and grease the stem and seat tube but that's about it.
To summarize: Wipe it down when wet, store it in a dry area, maintain the components, and don't worry.
This is my feeling. I see a lot of 1970s steel road bikes in daily use. I've never personally heard of one failing due to rust. IMO, this is a non-issue. Squirt some Boeshield in the tubes if you're worried.
I've had a couple steel road bikes which were made in the 1940's, and they are still in good condition now.
You really have to neglect a bike for it to rust. And even then its typically the stuff i.e. pedals, wheels, seat post, stem, etc., that rusts and not the frame. The only exception is a Walmart bike. It may look identical to the bike you bought at your LBS when its shiny and new, but a year from purchase is when you'll really see what you get for 100 bucks.
The simplest way to keep in from rusting is to stay out of the rain. If it does get wet, rinse it with tap water as soon as you get home. Even better, wash and dry it.
Quoted: 86 Post(s)
Don't ride your nice bikes in the rain. Get a rain bike. Rain bikes are cheap bikes that you don't care about ruining. Make sure to slap some plastic full size fenders on it. The fenders are there to protect you, not the bike. Beat the hell out of the bike all you want, just as long as it still works.
Rain bikes are fun. It's a game to see how long you can keep the thing going. It can teach you a lot about maintenance when you have a cheap beater bike to work on which you don't care about as much as your more expensive nicer bikes.
Quoted: 50 Post(s)
Clark W. Griswold
Quoted: 4343 Post(s)
Liked 3,978 Times
Ti is an awesome material and after riding a ti bike for over a year now, I can say it may rival my steel bikes and certainly is getting the most riding these days. The corrosion resistance is great but the ride quality is even greater and it is pretty light too!
