1x10 Crankset
Old 08-07-18, 01:04 PM
CX Farmer
CX Farmer's Avatar
1x10 Crankset
Hi,
I'm building up a Raleigh RXM to try out CX with. It is threaded for an English 68mm BB. I'd like to buy all new crankset components and am looking for the most versatility.
I will be running Shimano SLX shifter and RD with a Sunrace cassette. I'm a beginner and don't want to spend a ton, but would like something kinda nice.
What do you guys suggest? I'm leaning toward something with a replaceable spider but not sure.
Thanks,
Scott
CX Farmer is offline
Old 08-07-18, 01:25 PM
Teamprovicycle
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 314 Post(s)
I could only say fsa cranks , sram force or red , shimano 105 or ultegra , sram or wolftooth cx 1x chain rings ....
Teamprovicycle is offline
Old 08-07-18, 01:28 PM
shoota
shoota's Avatar
Quoted: 1004 Post(s)
Liked 29 Times in 25 Posts
So basically anything.
A Sram 1X gxp crank or Shimano w/ Wolftooth 1X ring make the most sense to me.
2015 Cannondale SuperX Hi-Mod
shoota is offline
Old 08-07-18, 02:01 PM
rosefarts
Quoted: 266 Post(s)
Liked 43 Times in 15 Posts
I'm running an SLX derailleur and sunrace cassette. I've got a Campagnolo crank with a narrow wide ring.
Really anything will work.
I have 135bcd so have fewer options for narrow wide chainrings. Anything with 130 would probably have more availability.
rosefarts is offline
Old 08-09-18, 02:54 PM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Bikes: BMC SLR01 TeamMachine Disk Di2; OPEN new U.P. Di2
Quoted: 798 Post(s)
Liked 17 Times in 13 Posts
I've used the SRAM Force1 1x crank with Shimano XTR rear derailleur / cassette / etc. It worked flawlessly. I used SRAM chains, but I doubt it mattered.
FlashBazbo is offline
Old 08-09-18, 04:18 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3589 Post(s)
Liked 156 Times in 117 Posts
Tough to beat the Rival 1X GXP crankset, normally about $150, including a 42T X-Sync narrow-wide chainring. And it's trusty 5-bolt 110bcd, so you can change rings without hunting around for some bizarre bolt pattern.
DrIsotope is offline
Old 08-09-18, 04:32 PM
cobra_kai
Quoted: 40 Post(s)
+1 any 110 BCD crankset would be great. I know wolf tooth makes 1x chain rings from 34 teeth to 52 in 2 tooth increments for 110 BCD. You should be able to find the right gearing for just about any terrain with that range and an appropriate cassette.
cobra_kai is offline
Old 08-10-18, 07:48 AM
Facanh
Quoted: 118 Post(s)
Rival 1.
1X out of the box, replacable spider, you can run direct mount on it.
Doesn't cost a ton and it's kinda nice.
Facanh is offline
Old 08-11-18, 10:31 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
Common Cyclocross 1 by, has been a Disc chain guard in place of a chainring for the outer
and a 'chain minder' or a inner disc chainguard, to keep the chain from coming off to the inside, on a road crank.
cassette 12-27, 42 t chain ring.. low gear is your feet,
getting off, throwing the bike on your shoulder and running, then jumping back on ..
keep your momentum up , or get lapped , by those who do..
gravel grinders I suppose* don't have course barriers set up to force
a dismount, remount , at speed..
*none around here..
fietsbob is offline
SlimRider
Utility Cycling
2
09-09-11 09:26 AM
Scott_t_CT
Bicycle Mechanics
0
10-03-10 10:15 AM
king-tony
"The 33"-Road Bike Racing
25
08-26-08 11:40 AM
Berodesign
Bicycle Mechanics
8
07-16-05 01:35 PM
ndelaude
Road Cycling
1
06-25-05 09:39 AM
