1x11 Di2 setup with XTR rear and Dura Ace 9170 shifters
Old 08-21-18, 02:27 PM
warmstrong54
Does anyone here have some insight on how to set this up successfully? I've lost two batteries and a wireless unit trying to make this work. My mechanic and I have it working now but E-tube does not seem to like the combo and loses the battery if you try to upgrade the firmware or change anything. I really would like to get the wireless unit back online and be able to program the shifter buttons to work with my bike computer. What's the trick?
warmstrong54 is offline
Old 08-21-18, 02:44 PM
shoota
shoota's Avatar
Quoted: 1004 Post(s)
Liked 29 Times in 25 Posts
This probably isn't the best place for this question. I would also try in the Bike Mechanics subforum.
2015 Cannondale SuperX Hi-Mod
shoota is offline
Old 08-21-18, 10:15 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6448 Post(s)
Liked 357 Times in 233 Posts
The first place to check is the e-tube compatibility chart. The latest is dated April 27, 2018.
E-TUBE PROJECT**********E-TUBE PROJECT????
-Tim-
TimothyH is offline
Old 08-22-18, 06:03 AM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
The article is a little dated but it might help.
Tinkering: Shimano XTR Di2 & Road Di2 Shifters - Perfect for CX & Monster CX - Gravel Cyclist: The Gravel Cycling Experience
-Tim-
TimothyH is offline
Old 08-22-18, 09:36 AM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Bikes: BMC SLR01 TeamMachine Disk Di2; OPEN new U.P. Di2
Quoted: 798 Post(s)
Liked 17 Times in 13 Posts
I did a 1x XTR rd / Ultegra Di2 shifter setup. It was plug-and-play. Very easy.
First thing . . . make sure your eTube software is current. Second . . . use it to update the software on all the components BEFORE you try using anything. There was an iteration a little over a year ago that would shut down EVERYTHING if you tried setting up the wireless unit without having everything up to date. Reset required unplugging the battery. (I suspect that's your problem, but obviously can't know for sure.) Update it all, then move forward.
FlashBazbo is offline
KonaRider125
20
11-08-15 04:46 PM
Smithie
BMX
1
05-16-12 07:41 AM
kfrazee
Charity Events
0
06-12-09 02:12 PM
Otto Rax
Folding Bikes
0
03-23-09 12:27 PM
