650b conversion worth it to go from 700x32 to 650x38?
Old 09-17-18, 11:28 AM
zucchiniboy
Hi there,
I'm considering converting a road bike from 700 to 650b. I can barely squeeze some skinny 32mm tires in the rear (they actually measure 30.9), and can probably do up to 35mm in the front. If I convert to 650b, I'd still only get enough clearance for 38mm in the rear. Would this be worth it to convert this into a gravel bike? I was thinking of putting on Maxxis Ramblers (650bx38) if I wanted knobs, or Panaracer Gravel King Slicks (650bx38). My thought is I'd still get some extra volume in the tires, lowered the overall height a bit, but overall I'd really be going from 32mm to 38mm in tire width.
Any thoughts? Is this worth the effort?
zucchiniboy is offline
Old 09-17-18, 02:02 PM
Elvo
Quoted: 345 Post(s)
Liked 6 Times in 6 Posts
Depends on your BB height. Going from 700x38C (686mm wheel diameter) to 650x1.5" (660mm) is over a 13mm drop in BB height.
Elvo is offline
Old 09-17-18, 02:14 PM
shoota
shoota's Avatar
Quoted: 1003 Post(s)
Liked 29 Times in 25 Posts
Depends on the surface you're riding and how attached to the bike you are. I would vote no.
2015 Cannondale SuperX Hi-Mod
shoota is offline
Old 09-17-18, 02:30 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 704 Post(s)
Liked 34 Times in 28 Posts
I've thought the same, and decided no.
BB drop is a big issue. And, really, really make sure you have width all around the tire - brake bridge, chain stay, front derailer...
I do ride 32 and 38mm tires (ramblers). The difference is significant to me. but in the end, I got a bike that can comfortably take both sizes.
chas58 is offline
Old 09-17-18, 04:39 PM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 138 Post(s)
You really need to try that tyre size first, or a bike with a 650b x 42 on it. Whether you like the rolling-diameter feel.
If I was strictly on smooth paved surfaces I would only do it. Anything above groomed mild gravel and I would give it a miss.
For me a 650b x 42 feels borderline acceptable but only over smooth stuff. Over heavier stuff the tyre just feels too small.
tangerineowl is offline
Old 09-17-18, 09:39 PM
Spoonrobot
Spoonrobot's Avatar
Quoted: 986 Post(s)
Liked 25 Times in 21 Posts
I wouldn't bother. Every road-focused 650bx38ish tire fudges height to keep the weight low. Most are only going to be ~35mm tall. Since wide tire comfort comes from both height and width you are not gaining near as much as you expect.
700c tires are often more true to height and will have close to the same comfort as a wider but shorter 650b tire. Also the 650b gravel king sicks are probably worse than gatorskins as far as rolling resistance and suppleness are concerned. My pair of 650bx48 measured only 44mm tall on 21mm inside width rims. 700c gravel king slicks are a much better tire.
Spoonrobot is offline
Old 09-18-18, 09:28 AM
chas58
chas58's Avatar
Quoted: 704 Post(s)
Phoo hoo on the naysayers for 38mm. The 38mm rambler is my do everything tire. Light, fast and very versatile. I do roll mine on a 700c though...
chas58 is offline
Old 09-18-18, 11:36 AM
zucchiniboy
With 700x32mm tires right now I'm at 285mm BB height, so this would theoretically bring me down to 272mm, which I've read is still ok.
Yeah, I'm on the fence because I can only get to 38mm, but if it's a true 38mm, I'd still be getting something like 50% more air volume. But would it be worth it?
That's helpful to hear. What do your 38mm ramblers measure? If I did this, I'm thinking of building a set of wheels on A23 or Quill rims and the slightly wider internal width than my current 19mm outer rims.
Thanks all for your input thus far. I was hesitating, and most of the feedback here seems to be leaning toward no. I'm still pondering it though...
Old 09-19-18, 09:06 AM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 168 Post(s)
Liked 17 Times in 8 Posts
I would consider going with a wider rim than that so that later you can use these wheels for 650B x 47 or wider tires when you eventually realize that what you really want is a bike that can take bigger tires.
BluesDawg is offline
xfimpg
General Cycling Discussion
7
03-15-12 12:45 PM
Doolally
Foo
9
06-06-08 01:24 PM
maximan1
Foo
20
12-20-06 07:19 AM
fubar5
6
11-27-02 10:12 AM
