Help Me find the Squeek!
Old 10-20-18, 08:59 AM
LifeNovice1
Quoted: 19 Post(s)
I have a Schwinn Sierra 80's Mtn bike. Rigid/No Suspension. It has started squeeking when I hit bumps or even if I bounce up and down on the seat at rest. Any ideas where it's coming from...what would the most common places be? Not that big a deal,,,but its obviously an area that needs some wd-40 or something. I have lube the chain and sprockets already.
LifeNovice1 is offline
Old 10-20-18, 10:57 AM
Binky
Binky's Avatar
Bikes: Too, too many....
Quoted: 56 Post(s)
I had a squeak a few months ago that was hard to find and disappeared whenever I got my ass up off the saddle.
It was the saddle creaking...
Binky
Binky is offline
Old 10-20-18, 11:17 AM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1212 Post(s)
Liked 76 Times in 51 Posts
It could be the saddle. First try to reproduce the squeak by squeezing or pushing down on the saddle with your hand. Then try to eliminate it. There are rivets and metal-to-metal and metal-to-plastic joints in saddles. I would find those contact points and put a drop of lube (like Triflow) on them.
tyrion is online now
Old 10-20-18, 02:09 PM
Troul
:D
Troul's Avatar
Liked 14 Times in 10 Posts
remove seat with post. try bouncing it again.
Troul is offline
Old 10-22-18, 01:52 PM
abramj
Wannabe Bike Mechanic
abramj's Avatar
Bikes: Specialized Roubaix
Quoted: 9 Post(s)
My big concern would be the possibility of a crack in the frame. But start with trying to single out the problem. Does it make sound when bouncing up and down on the pedals and NOT sitiing on seat? Have someone else get next to bike when it's making noise and try to locate it. The seat can easily creak where it is mounted to the post. The post can creak where it goes into the frame.
Just some thoughts. If you don't think it's the seat or post, look at the welds on the frame and see if you can see a crack.
abramj is offline
Old 10-22-18, 02:13 PM
GrainBrain
GrainBrain's Avatar
Quoted: 645 Post(s)
Liked 32 Times in 21 Posts
+1
Seriously though on my bike the seatpost squeaked, so I pulled it, wiped down the post, inner seatube, and clamp. Then I put a little grease on the interference section of seat post and clamp, took the squeak away.
I've had a loose threadless headset squeak, solved by tightening.
GrainBrain is offline
Old 10-22-18, 08:24 PM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 402 Post(s)
Liked 50 Times in 43 Posts
I think you're really looking at spokes or saddle. If you can't find the squeak whilst riding whilst standing, it's probably the seat, so try another seat.
MikeyMK is offline
Old 10-24-18, 10:21 AM
EdwinHeadwind
Quoted: 92 Post(s)
For starters, stop using WD-40 as a lubricant -- that's not what it's for. Go to your LBS and get some actual bike chain lube and a tube of grease. I suspect your squeak will need the latter.
EdwinHeadwind is offline
Old 10-24-18, 10:27 AM
shoota
shoota's Avatar
Quoted: 1004 Post(s)
Liked 29 Times in 25 Posts
Saddle rails is my guess.
2015 Cannondale SuperX Hi-Mod
shoota is offline
Old 10-24-18, 06:27 PM
martianone
Bikes: recumbent & upright
Quoted: 53 Post(s)
Turn bike upside down,
spray bottom of saddle with your wd-40.
then listen for the squeak.
martianone is offline
Old 10-24-18, 07:26 PM
maletero
maletero's Avatar
Quoted: 10 Post(s)
I recently tracked a creak on my bike to the seat. Fixed by taking saddle off and putting a bit of grease on the rails. I'd try this along with some lube on the rivets, etc.
maletero is offline
Old 10-25-18, 11:01 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Bikes: Bob Jackson World Tour, 81 miyata 912 and 86 miyata 312.
Quoted: 817 Post(s)
Liked 21 Times in 10 Posts
I find most of my creaks or squeaks are related to insufficiently tightened bolts. Remove the ones that may be at issue, grease them and tighten. Lubing the threads makes it easier to get them good and snug.
52telecaster is offline
Old 10-25-18, 07:35 PM
BlazingPedals
BlazingPedals's Avatar
Bikes: Trek 7500, RANS V-Rex, Optima Baron, Velokraft NoCom, M-5 Carbon Highracer, homebuilt recumbent
Quoted: 912 Post(s)
Liked 25 Times in 20 Posts
Every place where metal is press-fit to metal, or where metal is clamped to metal, should be lightly greased. Ditto with anything threaded. That includes seat rails, seat posts, bottom bracket shells, headsets, stems & handlebars, heck probably even shifters and brake levers. Except for cable clamps, don't grease those.
So one at a time, take pieces off, grease them properly, and re-install. If you start at one end of the bike and move toward the other end, then by the time you find the squeak you'll be well on the way to a full tune-up.
BlazingPedals is offline
Old 10-26-18, 04:13 AM
jgwilliams
jgwilliams's Avatar
Bikes: Planet X Carbon Pro Evo SRAM Force, custom built 653 and 531 bikes with frames by Barry Witcomb, Giant XTC 4 mountain bike and a Brompton folding bike.
Quoted: 101 Post(s)
Liked 6 Times in 5 Posts
Others seem to have covered almost everything here. The only thing I'd add is to look for any place where steel and aluminium alloy meet as, in my experience, this can be an issue. And also that squeaks often don't come from where you think they do.
I suffered for ages with a creak from my commuter bike which seemed to be coming from the bottom bracket. I eventually tracked it down to where the alloy seat post was clamped into the steel frame. After greasing the post it was blissfully silent.
jgwilliams is offline
Old 10-26-18, 06:06 AM
Garfield Cat
Garfield Cat's Avatar
Bikes: Cervelo Prodigy
Quoted: 342 Post(s)
Liked 6 Times in 4 Posts
This is one way technology will help in finding noises that come from the bike while riding. Of course, it will come from the bike manufacturers who are engaged in the Grand Tours and spend lots of research and development $$$ to tweak the rides for the professionals.
Various kinds of sensors attached to the bike situated in areas and monitored and recorded. Not only that, but these sensors detect movement as well as noise. They are movable and can be attached to the bike in different areas.
Think of it as a collection of data later to be analyzed for bike performance under various conditions. It would be useful in how bikes respond under loads and then the different types of material that change these responses.
So then the natural byproduct is the "noise" we experience from time to time.
Garfield Cat is offline
chris.....
Foo
0
07-14-12 05:08 PM
ProEdgeBiker
Mountain Biking
5
11-19-09 11:02 PM
urbanknight
"The 33"-Road Bike Racing
0
04-13-08 08:48 PM
MICHAELM
Road Cycling
2
04-08-06 08:01 PM
Sincitycycler
Road Cycling
7
02-28-06 10:56 AM
