Alloy vs Carbon for gravel
Old 12-20-18, 06:57 AM
Chris(NJ)
Bikes: CAAD9 5-Sram Red, Pivot LES -XX1, Ibis Hakka -Force1
Quoted: 20 Post(s)
Originally Posted by rosefarts View Post
Fwiw, I ride a ton of shale trails. Every time I ride, sometimes several times per ride, I kick up a big chunk of rock that hits my bike.
I ride steel and a powder coated frame so I'm not super concerned. If I was kicking up rocks like that into a carbon or aluminum frame, I'd cringe.
I'm at 22lbs. I could drop to 20 if I needed to.
haha, It happens to my carbon pivot LES all the time around here in the NE when mountain biking. And yes....I cringe every time it happens lol. But nothing in comparison to when my Hakka got hit last summer. Cracked the downtube almost in half. It was still completely rideable and I chose to ride it home 30 more miles that way. So I learned the hard way that rocks alone probably won't do enough damage to carbon to ruin the bike and since bike weight came up. My Hakka comes in at 18.5lbs w/ i9 alum wheels, sram force1 group, carbon bars, 2x h2o cages, alum post/stem, xtr spd pedals. Could easily get it into the 17s if I wanted to throw money at it. but no need. It's been such an amazing bike. Comfortable on long gravel rides, commuting around, racing cx. Absolutely love it's versatility. Lacks rear mud clearance for CX though.
My answer to the original question would simply come down to funds. If you can spring for carbon, go for it. Otherwise, alum or steel will be just fine, too
Chris(NJ) is offline
Old 12-20-18, 07:11 AM
Metieval
Metieval's Avatar
Quoted: 664 Post(s)
Liked 5 Times in 5 Posts
Originally Posted by gus6464 View Post
I think the ones who swear that a 22lb bike will slow them down to a crawl vs a 16lb one are worse. Lately I'm wondering if I'm reading the 41 vs the cx/gravel subforum.
plural... hmmm show us some (plural) links to post where people have said that.
Dawes SST AL, Cannondale Synapse Alloy 105, Giant Talon 29er, Trek Crossrip Elite,
Metieval is offline
Old 12-20-18, 07:55 AM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6449 Post(s)
Liked 357 Times in 233 Posts
Originally Posted by srode1 View Post
That's about what mine weighs also. An RLT9 RDO is carbon fiber and about 1/2 lb lighter, same geometery. I was thinking about upgrading to the carbon version, but with the minimal weight difference I couldn't justify the cost, couldn't even rationalize it!
2017 RLT 9 RDO frames are $1495 right now.
https://www.competitivecyclist.com/n...-frameset-2017
Here's a review that had a demo bike weighing in at 18.5lbs without pedals or bottle cages in a 59cm, so I added a pound for pedals to get 19.5 lbs. You probably have lighter wheels or something. Here's the article https://pelotonmagazine.com/gear/nin...l-goes-carbon/
Mine is an RDO.
https://www.pedalroom.com/bike/niner-rlt-9-rdo-33084
I just weighed it at 19.8 lb including GPS mount, speed/cadence sensors, Xpedo ti pedals, carbon cages and a good amount of dirt on it. It is size 53.
Di2 battery adds a few ounces and the 11-36 SRAM cassette isn't light. It also uses larger 180 mm rotors and that requires a spacer in the rear. It adds up.
It doesn't surprise me that the 5 Star was 18.5 lb without pedals, cages or dirt. Mine is basically a 5 Star with different wheels, bigger cassette and larger rotors. At 19.8 lb dirty, I'm pretty happy with the build.
-Tim-
TimothyH is offline
Old 12-20-18, 09:48 AM
ogmtb
the snark is gratis
ogmtb's Avatar
Quoted: 140 Post(s)
People who endlessly mention how much their bike weighs go to the same ring of hell as people who talk about how much their shoes cost.
https://www.google.com/search?q=timothyh+20+19.8+lbs+site%3Abikeforums.net
ogmtb is offline
Old 12-20-18, 09:52 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3594 Post(s)
Liked 161 Times in 121 Posts
Especially when you take a 16lb bike, put two water bottles and a saddlebag on it, and bam-- it's a 20lb bike. Are those guys much, much faster at the ends of their rides after the water has run out?
DrIsotope is offline
Old 12-20-18, 11:29 AM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Relax. Its just a conversation.
There really isn't any need for "Burn in hell" drama and cartoons.
If the conversation upsets you that much then click the x in the corner and go make a sandwich or read a book. Participation here is optional.
-Tim-
TimothyH is offline
Old 12-20-18, 11:35 AM
ogmtb
the snark is gratis
ogmtb's Avatar
Quoted: 140 Post(s)
-Tim-
You're assuming folks are upset or need to relax when in fact some, like me, have been laughing the whole time.
Projection just induces more chuckling.
p.s. The cartoon was merely a representation of a light bulb going off for me after reading that Isotope guy's insightful post.
ogmtb is offline
Old 12-20-18, 12:26 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara/Centurion Ironman, '18 Diamondback Syncr, '18 handmade steel roadbike
Quoted: 2967 Post(s)
Liked 146 Times in 104 Posts
? where are the burn in hell cartoons?
mstateglfr is offline
Old 12-20-18, 03:11 PM
srode1
Gravel Rocks
Bikes: Trek Domane and Crockett, Niner RLT9
Quoted: 71 Post(s)
Originally Posted by Metieval View Post
the Only negative about the RLT RDO is the lack of tire clearance.
Is the tire clearance on the RDO any different than the Aluminum version? I have the Aluminum RLT9, seems to have plenty of room for 40mm tires.
srode1 is offline
Old 12-20-18, 03:14 PM
srode1
Gravel Rocks
Quoted: 71 Post(s)
I always drink all that's in my bottles before the last big climb on our weekend ride to lighten the load, it helps a lot!
srode1 is offline
Old 12-20-18, 03:51 PM
gus6464
Quoted: 221 Post(s)
Liked 11 Times in 8 Posts
Apparently the carbon RLT has less clearance than the metal versions. I've seen an RLT steel version with a Fox AX and 650b 2.1 thunder burts.
gus6464 is offline
Old 12-21-18, 12:44 AM
Metieval
Metieval's Avatar
Quoted: 664 Post(s)
yes.
Metieval is offline
Old 12-21-18, 10:56 PM
ogmtb
the snark is gratis
ogmtb's Avatar
Quoted: 140 Post(s)
On my RLT RDO there is plenty of room for 40mm Ramblers mounted on 25mm IW rims.
ogmtb is offline
Old 12-22-18, 12:54 AM
Wattsup
Quoted: 205 Post(s)
Mine is an RDO.
-Tim-
Jeezus, are you posting pics of your plastique-fantastique again?
Wattsup is offline
Old 12-22-18, 02:13 AM
Metieval
Metieval's Avatar
Quoted: 664 Post(s)
but you can also find his negative 3 lb steel frame bike that way too.
Metieval is offline
Old 12-29-18, 08:47 PM
shoota
shoota's Avatar
Quoted: 1004 Post(s)
Liked 29 Times in 25 Posts
My SuperX weighs 19lbs. There. Plural.
2015 Cannondale SuperX Hi-Mod
shoota is offline
Birthday
Introductions
2
09-16-12 06:02 PM
SonataInFSharp
Foo
18
08-02-12 07:50 PM
shabbasuraj
Road Cycling
0
06-06-08 12:54 AM
Bernodu
Mountain Biking
0
01-27-05 09:27 AM
