Looking for recommendations
Old 02-02-19, 04:16 PM
hashjoin
hashjoin's Avatar
I lost my Kona Jake the Snake 2008 which I loved in a move & looking to get another cross-bike. Main purpose of the bike would be:
1) go on 40-60 mile rides on the weekends (mix of road & trails)
2) ride with the road bikers .. so speed is needed. I was only able to go upto 13mph on Kona. I read that cross-bike tires can be swapped with road tires, so that's my plan for the road rides (instead of buying a road bike). Aiming to ride faster and attain upto 18-20 mph to keep up with the road bikers
3) go on 2-3 days of lightweight touring so the bike needs to be able to mount a carrier & rear panniers
4) Price range $600-1200
5) alumunium frame, shimano gears, upto 22 lbs, 53-54cm frame size
Any suggestions for a cross-bike that meets the above? Thanks!
hashjoin is offline
Old 02-02-19, 05:07 PM
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 138 Post(s)
Narrower tire fit, but there's a couple of 54cm alu Synapse (one SE) on ebay:-
https://www.ebay.com/itm/2019-Cannon...MAAOSwj9hcNVzo
https://www.ebay.com/itm/2018-Cannon...4AAOSw8KJbymCd
tangerineowl is offline
Old 02-03-19, 08:53 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara/Centurion Ironman, '18 Diamondback Syncr, '18 handmade steel roadbike
Quoted: 2967 Post(s)
Liked 146 Times in 104 Posts
not sure there is a cross bike available that will net you 7 mph faster on pavement versus your Kona.
Tires can account for some speed, but 7mph is huge.
https://www.raleighusa.com/willard-4-141
this is $1140 shipped to you if you use the free discount code.
carbon fork, 105 shifting, quality crank and good general gravel gearing.
mstateglfr is offline
Old 02-05-19, 09:24 PM
hashjoin
hashjoin's Avatar
thanks for the excellent suggestion .. very tempting to get this bike
hashjoin is offline
Old 02-06-19, 10:17 AM
Elvo
Quoted: 345 Post(s)
Liked 6 Times in 6 Posts
This is the answer:
https://www.ebay.com/itm/2017-Cannon...53.m1438.l2649
Elvo is offline
Old 02-09-19, 01:38 PM
hashjoin
hashjoin's Avatar
Thanks for the recommendation. How does one get the discount code?
hashjoin is offline
Old 02-09-19, 01:39 PM
hashjoin
hashjoin's Avatar
Originally Posted by Elvo View Post
This is the answer:
Thx .. nice bike though no rear eyelets for carrier
hashjoin is offline
Old 02-09-19, 02:23 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 215 Times in 179 Posts
Ritchey Swiss Cross bikes? drive train of your choice
fietsbob is offline
Old 02-09-19, 02:24 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Disc frame & Carbon fork ..
fietsbob is offline
Old 02-09-19, 02:26 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Rack mounts on heavier bike, = with roadies, you go off the back , right?
fietsbob is offline
Old 02-09-19, 02:36 PM
hashjoin
hashjoin's Avatar
right not planning to mount the rack when riding with the road bikers as that would get some speed. To also mstateglfr's point
Some other adjustments to ride faster I'm thinking of is narrower tires (e.g. 28c) .. vs 35c that Kona had. Although I am not sure if 28c would work for multi-day touring or light gravel/trails in terms of going flat. Also planning on using clipless pedals and shoes which should get some speed. Used to ride on platform pedals before.
hashjoin is offline
Old 02-09-19, 02:49 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
The readers of Bike Quarterly have seen the publisher's tire comparison tests and so will offer the Compass tires can be fast , without being thinner ..
fietsbob is offline
bobthib
Southeast Regional Rides and Events
0
04-21-12 08:04 PM
bobthib
Road Cycling
0
04-21-12 08:02 PM
bobthib
Tandem Cycling
0
04-21-12 07:59 PM
kbabin
Singlespeed & Fixed Gear
2
11-10-07 11:23 AM
