Lezyne floor pumps - Micro vs Steel/Classic
Old 02-12-19, 05:49 PM
reapa
I ride to and from work, about 40 minutes in total each day.
I'm looking for a pump that I need to use regularly that will last. As a bonus, I'd prefer it to be compact and lightweight.
Generally what I've read is hand pumps should only be used to keep mobile and a floor pump is pretty mandatory. Until I did my research, I was just looking for a reliable hand pump but apparently that won't suffice.
Where I'm at now is deciding between the two pumps listed in the title. The micro seems to fit the bill (it's a floor pump, it's compact).
However, does it really just fall into the same category as the hand pumps in that it ideally should be used to keep mobile and not for regular use?
reapa is offline
Old 02-12-19, 06:02 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 216 Times in 180 Posts
Longer the stroke the better.. + you don't have to do as many..
fietsbob is offline
Old 02-14-19, 08:11 PM
martianone
Bikes: recumbent & upright
Quoted: 53 Post(s)
Carry a Lezyne Carbon road on my bike- light weight, reliable and effective when needed.
lezyne steel floor pump at home- been utilizing it for years. Even Pumped up a car tire a few times.
this too, just keeps on working.
martianone is offline
Old 02-14-19, 08:22 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1639 Post(s)
Liked 60 Times in 51 Posts
There is one hand pump that will serve you well for years as an only pump The Zefal frame pumps. Now many modern bikes do not make it easy to carry them but they are completely up to the task of use as everyday pumps. I went 17 years with the forerunner to the Zefal HPX on my three bikes and no other pump., riding sewups on all my bikes so pumping up often was a fact of life. Those pumps only got replaced when they fell off and a following car ran over them. (No one used that rather newfangled Velcro stuff yet.)
So, in answer to your question "micro vs Steel/Classic" my answer would be "Classic" as in the Zefal HPX Classic (on several of my bikes).
Ben
79pmooney is offline
kjb0419
Bicycle Mechanics
24
08-24-12 09:24 PM
solbrothers
Classic & Vintage
12
11-22-11 08:18 PM
ModoVincere
Foo
25
12-08-08 11:41 AM
2packaday?
General Cycling Discussion
3
10-15-07 09:02 AM
keevohn
Bicycle Mechanics
5
06-03-07 05:37 AM
