Park Brand Grease???
Old 04-20-19, 06:14 AM
Tandem Tom
Quoted: 223 Post(s)
Liked 4 Times in 3 Posts
I have been noticing that when I repack wheel bearings with the above grease it seems to "seep" and not remain as thick.
Is it the quality of this brand? Is there something more appropriate?
Thanks!
Tandem Tom is offline
Old 04-20-19, 06:58 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1700 Post(s)
Liked 66 Times in 45 Posts
Bicycles are neither high-speed nor high load nor high temperature nor high moisture environments, so just about any grease is "appropriate" (well, maybe not bacon grease, if only because it degrades into corrosive fatty acids). If you feel the Park grease is too thin, try a marine-grade bearing grease.
JohnDThompson is offline
Likes For JohnDThompson:
Old 04-20-19, 07:12 AM
shelbyfv
shelbyfv's Avatar
Quoted: 1102 Post(s)
Liked 136 Times in 90 Posts
I like it because of the convenient tube, though I'm currently using wheel bearing grease because I had to buy a tub for my trailer.
shelbyfv is offline
Old 04-20-19, 07:23 AM
Brocephus
Professional amateur
Brocephus's Avatar
Bikes: Does a Big Wheel count ?
Quoted: 174 Post(s)
Liked 25 Times in 21 Posts
Along with numerous other lubricants, I still have an old tube of Park grease lying around. I've used it on bike bearings and other applications, and I never found any negative issue with the stuff, it seemed to work as well as anything else.(though I've been using a tub of Bel-Ray waterproof grease for a few years now, which came highly recommended by a really smart,knowledgeable motorcycle guy I know).
Brocephus is offline
Old 04-20-19, 09:19 AM
Crankycrank
Quoted: 184 Post(s)
Liked 11 Times in 8 Posts
There is no problem with grease seeping after a lubing. It's just the excess forcing it's way out and IMO is a good sign you have used enough grease. It shouldn't continue to seep after more than several rides though.
Crankycrank is offline
Old 04-20-19, 09:45 AM
AnkleWork
Bikes: old clunker
Quoted: 540 Post(s)
Liked 25 Times in 15 Posts
A few answers here:
Link
AnkleWork is offline
Old 04-20-19, 11:36 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
At my LBS they use nothing else , to no small part of they get it with other stuff from shop supply wholesalers..
It's Blue , Phil Grease is Green .. they are similar, 1 in a tub, 1 in a tube..
in the 80's I bought a tub of Boat trailer wheel bearing grease ,
it's a bit thicker and , obviously made to be waterproof ....
I still have some left..
fietsbob is offline
Old 04-20-19, 12:34 PM
SurferRosa
SurferRosa's Avatar
Quoted: 371 Post(s)
Liked 48 Times in 34 Posts
I've recently moved from Park to white lithium grease. It's thicker, like Campy grease.
SurferRosa is offline
Old 04-20-19, 12:37 PM
Racing Dan
Racing Dan's Avatar
Quoted: 744 Post(s)
Liked 8 Times in 7 Posts
Not all greases are compatible. Park grease is Polyurea based, one of the least compatible. Before using it you should completely clean the bearing from old grease, to avoid issues with incompatibility.
Racing Dan is offline
Old 04-20-19, 12:48 PM
Racing Dan
Racing Dan's Avatar
Quoted: 744 Post(s)
As Im sure you know, you can use most general purpose grease, but most greases are formulated with base oil that is not actually viscous enough for the low speeds on a bike. Something like Motorex fett 2000 has a much higher viscosity base oil and is better suited to bikes than most greases.
Old 04-20-19, 01:05 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Is that your only issue?
fietsbob is offline
Old 04-20-19, 02:21 PM
Tandem Tom
Quoted: 223 Post(s)
The only other would be that after packing with grease I had decided to service the freehub. Give is a flushing and relube. It seems like the majority of the grease is gone.
That is another reason I was wondering about the quality of Parks grease.
Old 04-20-19, 02:44 PM
Eric S.
Eric S.'s Avatar
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 58 Post(s)
A tube of Phil grease lasts me years, but next time I need more I'll seek out something thicker. I worked at a shop in the early '80s and the standard shop grease was Raleigh-branded with the consistency of creamy peanut butter. It was like glue for loose bearings and repacking Bendix coaster brakes.
Eric S. is offline
Old 04-20-19, 02:45 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
your rolling balls will push out the grease as they function...
a factory uses a minimum amount of grease , because in a million part production run it saves money, in costs..
fietsbob is offline
Old 04-20-19, 03:56 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 395 Post(s)
Liked 17 Times in 9 Posts
I've used Park grease for years without trouble.
If you recently used a solvent to clean the bearings or cups, are you sure you got it all out and dried the bearings and cups thoroughly. I little bit of solvent left in the nooks and crannies can do this to grease. I know from experience...........
drlogik is offline
Old 04-22-19, 05:21 PM
squirtdad
squirtdad's Avatar
Bikes: 90/91 De Rosa, '84 Team Miyata, '82 nishiski,
Quoted: 808 Post(s)
Liked 39 Times in 31 Posts
Phil's waterproof for bearings, a tub of red devil (which will last forever) for bolts, spindles, etc, Phil's tenacious oil for freehubs, and tri-flow for everything else. and Rock and Roll gold for chains
Looking for Team Miyata F&F 58cm
squirtdad is offline
Old 04-22-19, 06:11 PM
bluehills3149
bluehills3149's Avatar
Bikes: depends what week it is..
Quoted: 69 Post(s)
If you're using an expensive bike grease just cos you have trouble getting grease out from a jar or cartridge, one of these is an excellent investment at about $11 on Amazon as it makes applying grease to tight spaces a doddle.
bluehills3149 is offline
Old 04-23-19, 12:55 PM
pdlamb
Quoted: 968 Post(s)
Liked 36 Times in 26 Posts
The only reason I don't use Phil's grease for everything that needs grease on a bicycle is...
Sometimes I see the other greases I have sooner (they're in bigger cans than the Phil's tube).
pdlamb is offline
Old 04-23-19, 01:54 PM
gearbasher
gearbasher's Avatar
Quoted: 137 Post(s)
I use Park grease because when a bike shop near me (that catered to deliverymen and low end family bikes) went out of business, they gave me two tubs of the stuff. I have enough to last me until I die.
gearbasher is offline
Old 05-04-19, 08:29 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 235 Post(s)
Liked 9 Times in 8 Posts
I have a ~10-year-old 16 oz can of Park Polylube 1000 grease, stored in my garage. I've used about 1/2 the can. When I bought it I figured it would be a lifetime supply. For the last couple years I've noticed a small pool of green liquid standing in the can whenever I open it. I've tried mixing it back in but this doesn't really work. I'm not sure the separation is bad, but it probably isn't good.
Just noticed a Lifetime Warranty at Park's website - I may request a warranty replacement for my runny grease.
seeker333 is offline
kross57
5
06-13-19 09:53 AM
Spitty6
Classic & Vintage
4
09-06-17 12:07 PM
LyteCycle
Alt Bike Culture
3
11-08-10 08:14 PM
Eggplant Jeff
Foo
4
05-16-06 01:06 PM
summerwind
14
02-02-05 08:19 AM
