Go Back  Bike Forums > Bike Forums > Fitting Your Bike
my left shoulder a lit bit numb after change handlebar according to bike fitting
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 04-22-19, 09:13 AM
cycling2012
Bikes: Merida x-fit 2010;
Quoted: 52 Post(s)
Recently I made bike fitting by shimano bike fitting system.my shoulder width is 400mm,my original bike handlebar width is 420 ,so everytime I cycle over 40km-200km,when I got home or on the last tens of km my shoulder is numb.but after change to 400mm handlebar ,it's a little better,but only left shoulder is a little numb.
so I just want to know it's because the handlebar angle or shift lever angle problem or I should use 380mm handlebar?
cycling2012 is offline
Old 04-22-19, 09:18 AM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 311 Post(s)
Liked 59 Times in 45 Posts
I don't know what a bike fitting by shimano bike fitting system is....numbness can be caused by a multitude of things related to bike fit (beyond just bar width).
jadocs is offline
Old 04-22-19, 09:49 AM
cycling2012
Quoted: 52 Post(s)
so how to find the reason and resolve it.only left shoulder ,numb a little ,not too much.
Old 04-22-19, 11:53 AM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1795 Post(s)
Liked 39 Times in 30 Posts
Bar width usually doesn't make much difference. Numb, IME, means a pinched nerve or pinched blood vessel. Changing your fit caused this, so change your fit again.
I usually recommend getting the weight off your hands by moving your saddle back until you can briefly lift your hands from the bars while riding, without sliding forward on the saddle. Before moving your saddle, measure your saddle height and reset your saddle height after moving the saddle. After you're satisfied that your saddle position meats these criteria, next set your reach so that, with your hands on the hoods and elbows slightly bent and your back as straight as you can get it, your upper arms make a 90° angle with your torso. That'll probably mean changing stem lengths.
Make those changes, go ride, and see how that works for you.
Results matter
Carbonfiberboy is offline
Old 04-22-19, 10:16 PM
cycling2012
Quoted: 52 Post(s)
thank you for your advice.so only one left side shoulder pain or numb ,is that related to the handlebar and shift lever angle?
Old 04-22-19, 10:33 PM
Carbonfiberboy
Who knows? Your shoulders are obviously different in some way. I'm suggesting you make some changes, putting yourself into a normal road bike fit. If that's the identical fit your fitter has you in, obviously don't bother. But if it's not, give it a try.
Shift lever angle? You mean the location of your brifters? Set them up so they look like this: https://www.bikeforums.net/19145009-post3.html The levers are approximately vertical and the tops of the hoods form an extension of the bar's ramps, continuing forward in a more or less straight line.
Results matter
Old 04-23-19, 10:42 AM
Iride01
Iride01's Avatar
Bikes: '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 864 Post(s)
Liked 27 Times in 24 Posts
Was the fit a one time deal? They don't let you come back and ask about things that aren't working for you?
Iride01 is offline
Old 04-25-19, 04:19 AM
cycling2012
Quoted: 52 Post(s)
not one time deal,I can come back and try.
but before I come back ,I am building a new road bike,so I want to finish it and then go fitting again.
AbsoluteMike
Hybrid Bicycles
7
09-07-18 10:13 AM
flammenwurfer
Utility Cycling
19
10-05-09 08:37 AM
BigSean
"The 33"-Road Bike Racing
23
04-27-08 06:26 PM
