60TPI vs 120TPI tires? pros cons?
Old 04-24-19, 10:41 PM
Hondo Gravel
Voted For Pedro
Bikes: Motobecane Boris Fatbike, Motobecane Omni Strada Pro,Fantom Pro CX, Fantom X7 MTB, Gravity SS MTB.
Quoted: 526 Post(s)
Liked 80 Times in 63 Posts
I really could use some opinions from you guys and gals. Fixin to buy me some gravel tires. 60s supposedly last longer the 120s better ride. I would love to hear from other gravel grinders
Hondo Gravel is offline
Old 04-25-19, 06:03 AM
ChinookTx
Bikes: Kona Rove Ti., Motobecane Whipshot Ti
Quoted: 86 Post(s)
Liked 39 Times in 31 Posts
What you said is right with regards to durability. On top of this, 60s will be a bit heavier than 120s. Also, rigidity is different, where the 60s will also have a stiffer casing, which may make installing the tires on the rims a bit harder.
ChinookTx is offline
Old 04-25-19, 07:47 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara/Centurion Ironman, '18 Diamondback Syncr, '18 handmade steel roadbike
Quoted: 2949 Post(s)
Liked 139 Times in 98 Posts
All the 120tpi tires I've used(or 330tpi due to marketing) have lasted a long time. They have been durable and reliable.
In terms of durability, its not like 60tpi is a basketball and 120tpi is a balloon ready to pop.
120tpi are lighter, ride better, and are faster while still being plenty durable(in general)
The one downside is they cost more.
mstateglfr is offline
Old 04-25-19, 10:11 AM
redlude97
Quoted: 1653 Post(s)
Liked 20 Times in 16 Posts
Don't compare across brands though they can use different casing materials. Some 60tpi casings(tubeless ready) ride better than 120tpi casings if set up tubeless compared to with butyl tubes
redlude97 is offline
Old 04-25-19, 01:42 PM
ericzamora
junior
ericzamora's Avatar
Bikes: 2018 Norco Search XR 105 steel gravel bike / 1983 Bianchi Campione D'Italia / Gary Fisher Wingra / Motobecane Nomade mixte (daughter's) / Norco Fluid 2 HT
Quoted: 48 Post(s)
Liked 5 Times in 4 Posts
Mine are listed as 60tpi, but with a "light and supple" casing. Set up tubeless.
eric/fresno, ca.
ericzamora is offline
Old 04-25-19, 02:52 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 704 Post(s)
Liked 33 Times in 27 Posts
Generalizing: 120 is lighter and more supple and more expensive. 60 has a thicker cord is harder to cut than the thinner 120 cord. The 60tpi is sometimes used on tires with extra puncture protection.
chas58 is offline
Old 04-25-19, 03:00 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1201 Post(s)
Liked 69 Times in 46 Posts
Isn't the TPI spec relatively meaningless? I've heard some manufacturers will make a tire with two 60 tpi layers and call it a 120 tpi tire.
tyrion is offline
Old 04-26-19, 09:49 AM
chas58
chas58's Avatar
Quoted: 704 Post(s)
Usually it is meaningful. Continental loves to say they have 330TPI, when it is really 3x110tpi. Basically you have to divide any TPI number conti has by 3. They label their 60TPI tires as 180TPI. Everyone else seems to do it legitimately .
chas58 is offline
Likes For chas58:
Old 04-26-19, 11:16 AM
Spoonrobot
Spoonrobot's Avatar
Quoted: 984 Post(s)
Liked 25 Times in 21 Posts
TPI is meaningless in 2019. This article and the comments are a good primer why: https://janheine.wordpress.com/2015/...e-performance/
The issue gets compounded even worse now that there are tires designed to bridge tubed/tubeless use as well as different manufacturers making difference tire construction choices with respect to using tubeless fluid.
For example, the Panaracer GK slicks in 650bx48 are a terrible tire. Stiff, uncomfortable and slow despite having thin tread and 120 TPI . The TPI number is from two layers of 60 TPI , counted twice.
WTB Horizon is a great tire. Supple, comfortable and rolls fast even though it has extremely thick center tread - TPI is 60. The TPI number is from two layers of 60 TPI , counted once.
Applying TPI like it used to be back in the 70s and 80s and the Horizon is going to be a much worse tire, on paper. The reality is completely opposite, Horizon is a great tire and that specific size of the GK slick is not. TPI also has almost nothing to do with cut or puncture resistance, both are much more concerned with tire durometer and pressure than TPI. I think I probably purchased tires based on TPI in the past but I can't remember the last time I did so, it's not a good way to choose a tire. Taking weight and TPI together is better than nothing but honestly there's no good way to pick a tire without being able to hold it in your hand - even then things can be different when you ride it.
Other examples:
Pancenti Pari-Moto has the same TPI as Compass Babyshoe Pass - 120 TPI, but it is significantly more supple and significantly less durable because the sidewall is ~1/2 the thickness of the Compass and the tread is ~1/3 the thickness.
MTB tire; the Kenda Slant Six tube-only SCT model has the same TPI as the tubless SCT model - however the tubeless model has a sidewall that's almost twice as thick and is a significantly stiffer, slower and less comfortable tire with less traction.
Spoonrobot is offline
Likes For Spoonrobot:
Old 04-26-19, 12:50 PM
Kapusta
Cyclochondriac
Quoted: 899 Post(s)
Liked 46 Times in 36 Posts
Like others have said, tpi theoretically can make a difference when all else is equal... but all else is often not equal.
I think TPI used to be a better indicator of suppleness and quality than it is now. I donít know why that is.
Kapusta is offline
Old 04-26-19, 03:33 PM
chas58
chas58's Avatar
Quoted: 704 Post(s)
interesting comments, but there are many tires that are offered in both 60 and 120 configurations. In that case, all other things are equal, and it is a valid comparison. The 60TPI tires are often sold and a more heavy duty or flat resistant tire though (with a different construction).
Idunno - 120 makes me think the tires are more supple, so it must be so! ;-)
chas58 is offline
spectastic
Bicycle Mechanics
4
07-05-19 06:39 PM
Blacksail
Singlespeed & Fixed Gear
6
03-09-09 08:33 PM
