Go Back  Bike Forums > Bike Forums > Recumbent
Sun EZ Rider seat angle- any ideas?
Recumbent What IS that thing?! Recumbents may be odd looking, but they have many advantages over a "wedgie" bicycle. Discuss the in's and out's recumbent lifestyle in the recumbent forum.
Old 05-08-19, 04:57 AM
Alathea
Mr. Frowny Man
Alathea's Avatar
Bikes: 2009 Giant Yukon single speed;2014 Foam Green Surly CrossCheck
The Sun EzRider that I have (the AX model) has a seat base angle too shallow. I have to have slightly less angle in my legs due to being large around the middle, so if I adjusted the distance from the pedals the way most sites suggest I have trouble getting my other foot on the pedal after I start moving. My issue is that I still slide forward in the seat as I ride. Has anyone found a way to adjust the seatpan angle? This model is just 4 bolts on the bottom to hold the seat- no actual angle adjustment. Ive adjusted the seat depth, backrest, and distance from pedal, but if I could get the front to nose up about 1/2 an inch I think id be golden.
Alathea is offline
Old 05-08-19, 05:44 PM
Irishred
Bikes: Tour Easy
Yes- you might try to insert a shim.
Irishred is offline
Old 05-08-19, 05:54 PM
BlazingPedals
BlazingPedals's Avatar
Bikes: Trek 7500, RANS V-Rex, Optima Baron, Velokraft NoCom, M-5 Carbon Highracer, homebuilt recumbent
Quoted: 913 Post(s)
Liked 27 Times in 22 Posts
Can you fabricate some angled bushings to go between the frame and seat, to hold the seat at an angle? Sort of a variation of the shim idea.
BlazingPedals is offline
Old 05-14-19, 10:29 AM
bkaapcke
Quoted: 54 Post(s)
Liked 6 Times in 2 Posts
It looks like the seat mounts to square tubing like the other EZ recumbents from Sun. There is some up & down play at the front of the clamp mount. You can get a shim in there and raise the front of the seat. You can get about 1/4" from between the seat mount bracket and the seat
tube. If you need more, you can get it between the seat base and the bracket. Have a look, and good luck. bk
bkaapcke is offline
Andrew R Stewart
Framebuilders
8
06-07-12 07:03 AM
Square & Compas
Recumbent
7
08-26-09 07:50 PM
dekindy
1
12-25-07 02:03 PM
c0urt
Foo
3
08-18-07 10:58 AM
