Hey guys, I found something
Old 06-10-19, 04:33 PM
Tomsl923833
Quoted: 42 Post(s)
Head badge
Tomsl923833 is offline
Old 06-10-19, 05:01 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 965 Post(s)
Liked 18 Times in 16 Posts
1983? Likely. Check the Sugino crank for date codes.
clubman is offline
Old 06-10-19, 05:12 PM
Tomsl923833
Quoted: 42 Post(s)
Originally Posted by Hudson308 View Post
Third-ring spacers appear to be 5mm thick.
I posted some pictures finally. They should be on here soon.
Old 06-11-19, 09:57 PM
Hummer
Hummer's Avatar
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 111 Post(s)
Well thank you for enlightening us that models made in Japan during this period were made by Bridgestone.
I would have just assumed Panasonic, like it was in the mid-70's.
For the record:
Schwinn Le Tour models, of the various designations, with frames made in Japan where made by at least three different manufacturers: Bridgestone, Panasonic, and Kuwahara. Each frame manufacturer has their own serial number formats.
Edit: The OPs frame serial number, as mentioned previously, is a USA serial number.
Hummer is offline
Old 06-15-19, 07:59 PM
Tomsl923833
Quoted: 42 Post(s)
This post doesn't seem be online any longer. I posted some photos but, after that my thread disappeared. I discovered that the BB didn't need to be changed. I used 6 mm spacers. I noticed on my 30T ring that it was recessed on one side and, the gap was almost perfect. I had to reset the cable 3 times due to stretching. But, I finally got it. The one issue I did have problems with was shifting to the large cog on the freewheel when the front chainring was on the 52T. The chain kept pulling off but, I think I got it finally. I went to the bike shop in my area and, showed the mechanic what I was doing and, he said "those derailleures are ancient" lol!!! Thanks Hudson!!!
Old 06-15-19, 08:12 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 342 Post(s)
Liked 21 Times in 16 Posts
Good job getting it all to work!
It's great that you got the chain to work on the big/big. Experienced riders will tell you that may not be completely necessary, as that's not a cross-chain combo they would use anyway. However it's always nice when you can get any possible gear combo to function.
Hudson308 is online now
Old 06-16-19, 04:29 PM
Tomsl923833
Quoted: 42 Post(s)
Not sure how thick the spacers are... they're the factory ones. I can measure them sometime in the next day or two. When I took it apart to refurbish it, I was a bit surprised that all three rings used the same bolts.
As far as the BB spindle length, I would assume you'll need a longer one. I never measured the length when I had it apart.
One thing about this particular BB is that it's an easy swap going from a double to a triple. There's enough clearance. Just be mindful of the spacers you use. I used 6mm spacers on the small chainring and, I was able to use the friction shifter that came with it. At first the cable kept stretching while I was adjusting the H&L but, after about 4 tries it finally held.
Old 06-16-19, 07:21 PM
Tomsl923833
Quoted: 42 Post(s)
The top picture is the crank side
Old 06-16-19, 07:29 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 965 Post(s)
GC is '87 but it's really not likely that an '87 bike had top mounted shifters. They were almost always found on 83-84 frames. Your bike looks to be in this 83 catalogue. Arx derailleurs, same crank, correct shifters?
I think maybe the date code is elsewhere on the crankset. Reading thru the thread, this was all covered already.
clubman is offline
Old 06-16-19, 08:38 PM
Tomsl923833
Quoted: 42 Post(s)
I'll keep looking. I definitely like the 83 water slides better than th 84s.
FormerBMX'er
Northeast
2
01-16-10 09:09 AM
Rick540
Mountain Biking
17
04-07-09 12:03 PM
cinco
Foo
24
02-10-07 10:20 PM
cs1
Bicycle Mechanics
4
04-23-06 07:17 PM
