Rim Brakes on Carbon Wheels
Old 05-22-19, 09:09 AM
BengalCat
Bikes: 50/34, 11-40, 11 Speed
Quoted: 44 Post(s)
Liked 11 Times in 7 Posts
Thinking of buying a road bike with rim brakes and carbon wheels? Do you already have a road bike with rim brakes and you want to switch from alloy to carbon wheels? Stop and consider the following:
Bikes are lousy at stopping quickly at speed or steep descent no matter what the situation is. But you have rim brakes on your current bike and you want to go from alloy to carbon wheels you may regret the choice when you try to make descents that require slow speeds down steep descents. The difference as I found about between carbon and alloy after switching is greater than I had participated. (The heavier you are the greater difference with carbon than alloy.)
The bottom line the carbon wheels are much less effective than alloy for breaking the situations I describe
Many carbon wheels come with a braking track on the wheels for a better grip by the brake pads. Those wear out in a month or so.
Anyway, a factor to consider if you are considering going from alloy to carbon for whatever reason.
BengalCat is offline
Old 05-22-19, 09:33 AM
noodle soup
noodle soup's Avatar
Quoted: 2923 Post(s)
Liked 105 Times in 78 Posts
noodle soup is online now
Old 05-22-19, 09:41 AM
caloso
Packfodding 3
caloso's Avatar
Quoted: 1821 Post(s)
Liked 144 Times in 89 Posts
I regularly switch between alloy training/commuting wheels and carbon race wheels. I use good pads and switch alloy and carbon specific when I'm changing wheelsets. It hasn't been a significant issue for me.
caloso is online now
Old 05-22-19, 09:45 AM
jsigone
got the climbing bug
jsigone's Avatar
Bikes: one for everything
Quoted: 503 Post(s)
Liked 14 Times in 13 Posts
better brake pads? toe your pads? late brake into hairpins and don't ride your pads? don't white knuckle the downhill
210#s I'd climb GMR/Baldy and Palomar on Carbon wheels. Used swiss stop yellows and they are nice and hardly showed signs of wear
Rule #10 // It never gets easier, you just go faster.
jsigone is offline
Likes For jsigone:
Old 05-22-19, 10:03 AM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6463 Post(s)
Liked 366 Times in 239 Posts
With correct technique and properly set up brakes, this certainly isn't true.
-Tim-
TimothyH is offline
Old 05-22-19, 10:04 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 7995 Post(s)
Liked 198 Times in 129 Posts
"Rim brakes are perfectly adequate, nobody needs discs."
Seattle Forrest is offline
Likes For Seattle Forrest:
Old 05-22-19, 10:39 AM
woodcraft
woodcraft's Avatar
Quoted: 1021 Post(s)
Liked 33 Times in 19 Posts
Is zombie topic a thing?
woodcraft is offline
Old 05-22-19, 10:43 AM
tagaproject6
tagaproject6's Avatar
Quoted: 452 Post(s)
Liked 47 Times in 33 Posts
This thread has potential
tagaproject6 is offline
Old 05-22-19, 10:50 AM
seau grateau
seau grateau's Avatar
Bikes: Litespeed, IRO
Quoted: 1172 Post(s)
Liked 96 Times in 50 Posts
Alloy wheels are perfectly adequate, nobody needs carbon.
seau grateau is offline
Old 05-22-19, 11:29 AM
Riveting
Bikes: '13 Trek Madone 2.3, '13 Diamondback Hybrid Commuter, '17 Spec Roubaix Di2, '17 Spec Camber 29'er
Quoted: 165 Post(s)
Liked 22 Times in 16 Posts
Steel wheels are perfectly adequate, nobody needs alloy.
Riveting is offline
Likes For Riveting:
Old 05-22-19, 11:38 AM
str8jakett
I pedal in my sleep...
str8jakett's Avatar
Bikes: Giant Propel Advanced Pro 2017, Giant Propel Advanced Pro 2015, Giant TCR Advanced 0 ISP 2008, Cube Cross Race SL 2018
Quoted: 85 Post(s)
Liked 8 Times in 5 Posts
Wooden wheels are perfectly adequate, nobody needs steel.
str8jakett is offline
Likes For str8jakett:
Old 05-22-19, 11:43 AM
WhyFi
WhyFi's Avatar
Quoted: 8905 Post(s)
Liked 150 Times in 89 Posts
Stone wheels are perfectly adequate, nobody needs wood.
WhyFi is offline
Likes For WhyFi:
Old 05-22-19, 12:02 PM
PepeM
PepeM's Avatar
Quoted: 2613 Post(s)
Liked 52 Times in 23 Posts
Wheels? We don't need no stinkin' wheels!
PepeM is offline
Old 05-22-19, 12:09 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1647 Post(s)
Liked 60 Times in 51 Posts
How are the Swiss Stop Yellows and CF in the rain?
79pmooney is offline
Old 05-22-19, 12:11 PM
Johnny Rad
Quoted: 29 Post(s)
Johnny Rad is offline
Likes For Johnny Rad:
Old 05-22-19, 12:16 PM
jsigone
jsigone's Avatar
Quoted: 503 Post(s)
socal doesn't get much rain. Never tried them in the mountain in weather but flattish club rides seemed fine. Long life pads unlike the old cork days.
I'm on the blue reynold pads now w/ their wheel. Haven't rode in the rain with this setup yet.
jsigone is offline
Old 05-22-19, 12:42 PM
mgopack42
Bikes: 2011 Pinarello FP Quatro, 1994 Specialized Allez, cheap Scattante cross bike, Mid 80's Ciocc.
Quoted: 86 Post(s)
Liked 9 Times in 7 Posts
You guys crack me up. I literally laughed out loud when I read this string of posts!
mgopack42 is offline
Likes For mgopack42:
Old 05-22-19, 12:46 PM
mgopack42
Quoted: 86 Post(s)
I am no weight weenie, if I want to save 5-10 kg, i can lose belly fat! When I wanted deeper section wheels, I got alloy/carbon wheels (Campagnolo Bullet 50). I really like them, except for the graphics, and I pulled the stickers off of the rears, some day I will get around to the front. As I see it, this is the best compromise for the real world that I live in!
Old 05-22-19, 01:14 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Hey, sliding blocks of granite across wooden boards was good enough for the Egyptians to build the pyramids.
TimothyH is offline
Likes For TimothyH:
Old 05-22-19, 02:02 PM
MinnMan
MinnMan's Avatar
Bikes: 2016 Masi cxgr, 2011 Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220, 1991 Bianchi Osprey
Quoted: 469 Post(s)
Liked 23 Times in 15 Posts
Yeah, I know that you veterans think that this is a redundant thread, but I am appreciating the constructive contributions here. There continue to be lots of people buying carbon rims for the first time and I'm one of them, and I would like to read what people have to say in this discussion. Pointers to older threads would also be welcome. But not too old, as developments in brake pad materials make those less helpful.
So yeah - long descents, wet/dry, emergency stopping power when something unexpected happens, yellow king vs. black prince. Do tell.
MinnMan is offline
Old 05-22-19, 02:20 PM
cycledogg
cycledogg's Avatar
Bikes: Cannondale CAAD4, CAAD5, CAAD7 (Optimo), '07 SystemSix, '08 Trek TTX 9.0, 2015 Cannondale Supersix Evo - ZIPP
Quoted: 325 Post(s)
Liked 7 Times in 6 Posts
cycledogg is offline
Old 05-22-19, 02:43 PM
cthenn
Bikes: 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, 2016 Devinci Hatchet, Some BikesDirect MTB I never ride.
Quoted: 536 Post(s)
Liked 40 Times in 22 Posts
Meh, I'm one of the rare cyclists who knows how to "modulate" rim braking just fine. Thanks for your concern though!
cthenn is offline
Old 05-22-19, 03:07 PM
Abe_Froman
Abe_Froman's Avatar
Bikes: Marin Four Corners, 1960's Schwinn Racer in middle of restoration, mid 70s Motobecane Grand Touring, various other heaps.
Quoted: 9291 Post(s)
Liked 42 Times in 36 Posts
All of you guys are doing it wrong.
Edit: Huh. Dunno how to copy images here anymore hahah.
Abe_Froman is offline
Old 05-22-19, 04:03 PM
seau grateau
Crabon no stop good.
Old 05-22-19, 04:30 PM
mantis
Don't Bug Me
mantis's Avatar
Bikes: Canyon Aeroad CF SL 8.0 Disc, Cervelo S2, Look 585, Specialized Rockhopper
Quoted: 10 Post(s)
Liked 13 Times in 9 Posts
Have hydraulic discs with my carbons. Stop good.
mantis is offline
Likes For mantis:
