Gouge in 631 steel frame
Old 05-28-19, 02:35 PM
harryzee
Hello all,
Apologies if this is in the wrong place.
I am getting my Dawes Galaxy's 631 steel frame powder coated. After cleaning it and looking it over I noticed a rather nasty looking gouge in it.
It's not dented and it's about 1mm deep.
I know nothing about steel frame damage: should (or indeed, can) this be patched up a little before the new coat goes on, or is it nothing to worry about with a steel frame?
Would post a picture but I'm new here! Any opinions much appreciated.
harryzee is offline
Old 05-28-19, 03:11 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 235 Post(s)
Liked 9 Times in 8 Posts
Originally Posted by harryzee View Post
Hello all...
1mm is a pretty deep gouge considering the tubing wall thickness is only a bit over 1mm thick at the butts (the thick wall section at tubing ends where tubes are joined by welding or brazing). Wall thickness in the middle of the tube is often less than 1mm on road bikes.
This may be serious damage. You may want to have a professional framebuilder inspect the damage before powdercoating.
See the 631 tubing profile chart at this link, about a third of the way down the page. See the 1.2/0.6/0.9... I believe the units are millimeters!
seeker333 is offline
Old 05-28-19, 03:26 PM
harryzee
Originally Posted by seeker333 View Post
1mm is a pretty ...
Ah! Thanks for the chart. I think I may have slightly overstated the depth... I work in 1mm units
I'll try and find some way of measuring it more accurately.
harryzee is offline
Old 05-28-19, 03:57 PM
harryzee
Looking at it again, it is a little dented.. I don't think there's much material missing, but rather it's been a bit compressed.
harryzee is offline
Old 05-29-19, 07:35 AM
djb
Quoted: 1088 Post(s)
Liked 38 Times in 30 Posts
take opinions from strangers as they are, but a slight dent generally isn't a problem and depending on where it is and how dented, it most likely is alright.
again, getting a couple of experienced opinions from knowledgeable people who can actually look at it first hand is your best bet, even from older experienced mechanics that have seen and experienced this sort of thing first hand for decades would be good (bicycle frame builders arent around every street corner).
djb is offline
Old 05-29-19, 06:55 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1177 Post(s)
Liked 42 Times in 30 Posts
I would take it to your local frame builder or frame repair shop if you have one and if not check with the head tech at the local bike shop or maybe the person who has been there the longest.
It might be nothing or it might be something and guesstimating is not a good idea. Certainly you can post plenty of good clear pictures with some measurable items (like a common coin or measurement device) and people can take a look but at this point we are just guessing.
veganbikes is offline
Old 05-30-19, 09:07 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6836 Post(s)
Liked 215 Times in 179 Posts
ask the powder coater what filler can be used and is compatible with the upcoming applied coating melt
It may need nothing as the molten powder will fill it while being cooked.
or they may do that filling as part of the prep for coating. ..
fietsbob is offline
Old 05-30-19, 10:55 AM
alan s
alan s's Avatar
Quoted: 1320 Post(s)
Liked 45 Times in 29 Posts
Under no circumstances should you ever ride it again. Send the frame to me and I’ll dispose of it properly.
alan s is offline
Old 06-01-19, 04:07 PM
delbiker1
delbiker1's Avatar
Bikes: 1991 Ochsner steel frame, 2002 Airborne Zeppelin titanium, Schwinn DBX SS aluminum, Orbea MD 40 carbon fiber
Quoted: 182 Post(s)
Liked 34 Times in 27 Posts
Dent is sort of visible below decal just above the fork.
Dent really shows up in this photo
this is the finished bike.
Without seeing the gouge/dent, everything is just a guess. I recently had a steel frame/fork powder coated. The fork had a nickel sized dent in it, and it had been there since I bought the bike new in 1992. The dent had not changed in any way after 27 years. No paint chipping, cracking or any other sign of worsening damage. When the powder coating was done. the powder and the baking process filled in the dent, and now you have to really look closely to see any sign of it. If you did not know it had been there, you probably would not notice any sign of it.
Dent not vivible
Other minor scratching and chipping are now gone.
delbiker1 is offline
Old 06-01-19, 04:17 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 235 Post(s)
A dent may be nothing more than a detraction from appearance, a blemish.
A deep gouge near a joint may serve as a stress riser which over time can lead to a tube or joint failure / ruined frame.
GoldenThiefBug
28
09-14-17 09:04 AM
stringmaster
Bicycle Mechanics
2
04-29-16 06:50 AM
acrowder
Bicycle Mechanics
2
08-20-13 07:24 PM
Mac_48
Road Cycling
6
11-13-09 10:46 AM
