Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Too far forward??
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Too far forward??
Old 05-31-19, 11:55 AM
darktardis
Bikes: Trek xcaliber 9, Schwinn Premis, Mongoose Switchback
Too far forward??
Hey, I know I should probably go get a fitting done, but atm I can not afford one. When I am riding it constantly feels like I'm falling forward. I notice that after some time my hands are starting to go numb due to leaning on them too much and not balancing over the center of my bike. My seat is level so I figured it's not that. I'm not sure if I need a taller stem or what may be the case, or if maybe my core just isn't strong enough. Im, 6'1, 265, havent been riding for quite a while and am now commuting to work 7 miles each way. I don't seem to have any other issues with a weak core though. Any advice would be great.
darktardis is offline
Old 05-31-19, 02:33 PM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 311 Post(s)
Liked 59 Times in 45 Posts
Sounds to me like you need to move your seat back so your center of gravity is where it should be, and not have so much weight on your hands. Now this will change your reach so you will need to adjust your stem appropriately.
jadocs is offline
Old 06-01-19, 05:39 AM
berner
Quoted: 300 Post(s)
Liked 33 Times in 27 Posts
Moving the saddle back sounds right to me also. Usually a saddle can be slid forward or back through a range of a few centimeters. If that range is not enough adjustment for you, a new seat post with a greater "setback" is needed. F'instance, I had to get a seat post with 25 centimeters setback to move the saddle back far enough.
berner is offline
Old 06-01-19, 07:35 PM
darktardis
I will definately try that, I checked it out and there is room to move it back some.
Old 06-04-19, 06:12 PM
Iride01
Iride01's Avatar
Bikes: '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 864 Post(s)
Liked 27 Times in 24 Posts
I guess I'm different. I'd move the seat forward and lower the bars.
Iride01 is offline
Old 06-05-19, 12:03 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1795 Post(s)
Liked 39 Times in 30 Posts
Definitely move the saddle back. You should be able to briefly lift your hands off the hoods while pedaling, without sliding forward on the saddle. Your hands should feel light on the bars. If the post clamp is then way forward on the saddle rails, you'll need a post with more setback. Most setback posts have about 25mm, but Velo Orange has posts with more.
Results matter
Carbonfiberboy is online now
Old 06-05-19, 12:34 PM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2509 Post(s)
Liked 56 Times in 34 Posts
Moving the seat back can work provided it doesn't cause you to lean forward more.
Just briefly, the "center of gravity" we're concerned with is with respect to the upper body only, and how far that is from the two points of support: the handlebars and the saddle. The closer the COG is to the handlebars, the more weight on the hands. It matters little where the feet are (just ignore all that "crouching balance" stuff).
So - you adjust reach in some fashion, and you adjust how much you lean, and that accounts for - with a scant few percent- how much weight is on the hands. But you describe the problem as hands going numb, and feeling like you're falling forward, and assume like most people that it's because of "too much" weight on the hands. I suggest looking at the problems without the assumption, because that doesn't always solve it or even help.
wphamilton is offline
mattgmann
Commuting
6
06-17-13 07:10 PM
Russellonabike8
Singlespeed & Fixed Gear
8
06-11-09 02:01 AM
tooth
Road Cycling
8
09-24-03 08:37 AM
