Battery pack
Battery pack
Old 05-31-19, 02:51 PM
badangel
Quoted: 15 Post(s)
Battery pack
I got an e bike with extra battery but its really hard to carry in my bag. Even if i carry its getting wet cause its a delivery bag. I dont wanna carry in my bag. Is there anyway to set to my rear bike rack with security. What is ur advice. Its a li-on 48V-13A. Amego infinite battery. Thanx
badangel is offline
Old 05-31-19, 03:55 PM
2old
Quoted: 212 Post(s)
Liked 8 Times in 7 Posts
Can't you strap it to the rack (unless yours doesn't have one (if so, procure a seatpost rack) and wrap in plastic if you're concerned about rain? You might consider placing a "bed" of foam between the rack and battery for insulation. BTW, met Virginia two years in a row at Interbike; she's a real enthusiast and seems like a great shop to do business with.
2old is offline
Old 05-31-19, 08:30 PM
badangel
Quoted: 15 Post(s)
I m delivering food. Somebody can stole it i need something not easy to take off and should be in a bag.
badangel is offline
Old 05-31-19, 10:14 PM
2old
Quoted: 212 Post(s)
Now I get it; look at steelcore and their locking straps or a similar product.
2old is offline
Old 06-02-19, 02:15 PM
badangel
Quoted: 15 Post(s)
Im in canada and this is pretty expensive. 700$ Bag for a battery!! I dont think so.
badangel is offline
Old 06-04-19, 01:49 PM
elizilla
Awkward Rider
elizilla's Avatar
Bikes: Small fleet of e-trikes
Quoted: 10 Post(s)
Liked 7 Times in 4 Posts
I'm thinking something like this: https://www.amazon.com/Akro-Mils-951.../dp/B00017IPLS
Put a piece of plywood inside, on the bottom, for strength. Drill some holes through the plywood and the box, and use big washers and bolts to attach the box on your bike's rear rack. Leave it permanently mounted on the rack. Maybe seal around the holes with Shoe Goo or similar to make it more waterproof.
Put the battery in it, maybe wrapped in a foam cushion to protect it from jarring. Close the box and put a padlock on the clasp.
The box could be removed from your rack, using tools, but if you do it right the tool user would need to get a wrench on a bolt head that is inside the locked box.
Note I know nothing about that toolbox I linked; I just picked it as an example of what I am talking about, it isn't a specific recommendation. I'd go to the hardware store and look for something like it that is sturdy, locking, and of a good size to fit the battery. There are both plastic and metal toolboxes out there. Plastic will be quieter and won't rust, but metal might give more security. The weak point in any such box is going to be the hinges so I'd pay close attention to those.
elizilla is offline
Old 06-04-19, 02:02 PM
elizilla
Awkward Rider
elizilla's Avatar
Quoted: 10 Post(s)
If you get a bigger box you could put the food in it as well. In which case you would need to build something inside the box to hold the battery still, keep it from crushing the food.
There are cheap imitation Givi locking topcases for motorcycles. Here's one that is 30 liters: https://www.amazon.com/Yescom-Motorc...dp/B01MF5S1S4/
This would look weirdly large on a bicycle but if it makes your life easier who cares?
elizilla is offline
Old 06-10-19, 08:47 PM
speedy25
Bikes: Specialized, Trek, Diamondback, Schwinn, Peugeot
Quoted: 111 Post(s)
Liked 4 Times in 4 Posts
Get a box similar to the Pelican cases, that your battery can fit in. You can bolt it to a rack and lock the box. Pack in some foam to keep the battery safe inside while cruising bumpy roads.
-SP
speedy25 is offline
Old 06-11-19, 04:15 AM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 404 Post(s)
Liked 52 Times in 45 Posts
My old bike had one battery in the frame and one on the rack. I properly fitted them, so I could lock them in place.
My current one has one rack battery either side of the frame. Again, properly fitted.
If you're going to use two batteries, it's really best to fit them properly - remember weight balance/distribution though, as my earlier one had handling issues.
MikeyMK is offline
Motman320
Foo
0
05-29-09 07:27 PM
The Figment
Foo
24
05-13-09 09:19 AM
bikingshearer
Classic & Vintage
17
12-31-08 10:47 PM
RoadRash
"The 33"-Road Bike Racing
0
03-17-00 01:08 PM
