Do I need a physical brake to Zwift?
Old 06-10-19, 11:10 AM
pennpaul
Bikes: Diamondback Haanjo Trail
Quoted: 50 Post(s)
Liked 7 Times in 5 Posts
I'm going to do a simple Zwift setup (Tacx dumb trainer and adding speed/cadence sensors to my bike) but tonight realized my spare rear wheel is missing the disc brake lock ring because it's on my main rear wheel.
So do I really need to have working brakes for a Zwift setup? I guess if I don't, I need to be vigilant not to use the brakes so I don't actuate the calipers against nothing.
I am going to order a lockring but because of where I am, it's really expensive locally and ordering one online is going to take another week and I want to start Zwifting ASAP.
pennpaul is offline
Old 06-10-19, 12:13 PM
caloso
Packfodding 3
caloso's Avatar
Quoted: 1811 Post(s)
Liked 129 Times in 78 Posts
I have never used the brakes on Zwift.
caloso is offline
Old 06-10-19, 12:15 PM
autonomy
autonomy's Avatar
Quoted: 367 Post(s)
Liked 15 Times in 15 Posts
No, you don't need a brake unless you want to use it. Now, as far as wearing a helmet to Zwift... that's a conversation for another thread.
autonomy is offline
Likes For autonomy:
Old 06-10-19, 01:42 PM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 314 Post(s)
Liked 58 Times in 40 Posts
There are little plastic inserts that are usually included with sets of hydraulic disc brakes. They are just flat bits to keep the pads from being clamped onto nothing, requiring an annoying pry-apart activity. If you don't have any of these thingys, your LBS almost certainly does. If you have hydraulic brakes you should consider them while on the trainer.
Wilfred Laurier is offline
Old 06-10-19, 01:52 PM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 282 Post(s)
Liked 52 Times in 39 Posts
Just cut a few old credit cards in half and stack/tape them together and insert between your disc pads....or use something similar. It's not hard to press the pistons in if you have to. You just don't want to actuate the brake without a disc so much that it causes the pistons to break the seal from the caliper, which means you need to bleed the system.
jadocs is offline
Old 06-10-19, 08:33 PM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1007 Post(s)
Liked 23 Times in 18 Posts
Have fun. Make sure you put it on a big screen TV - it's better that way.
TrojanHorse is offline
Old 06-10-19, 09:04 PM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 385 Post(s)
Liked 42 Times in 36 Posts
Remember to turn your rear light on.
MikeyMK is offline
Likes For MikeyMK:
Old 06-10-19, 09:25 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3576 Post(s)
Liked 147 Times in 111 Posts
My trainer wheel, complete with red Vittoria trainer tire, doesn't even have the brake rotor on it. As soon as you stop pedaling, the "bike" starts slowing down.
If there's any upside to being trapped on a trainer, it's the things you don't need: brakes, helmet, shirt etc.
DrIsotope is offline
Old 06-10-19, 11:41 PM
pennpaul
Quoted: 50 Post(s)
Yes, of course! KISS!
Thanks for all the responses. I hope I do enjoy Zwift. I am also anxious to find out how I do in the FTP test.
Paul
pennpaul is offline
Old 06-11-19, 08:49 AM
sdmc530
Heft On Wheels
sdmc530's Avatar
Bikes: Specialized,Cannondale
Quoted: 531 Post(s)
Liked 57 Times in 45 Posts
I have been an off season zwifter for 3 years and have never applied a brake ever.
The helmet would be terrible while zwifting! the heat would be unbearable in a helmet even with fans......I never ride any other time without a helmet.
Just like DrI said, its a pretty minimalistic riding situation. I wear bibs, socks and shoes...nothing else needed!
sdmc530 is offline
Old 06-11-19, 09:56 AM
jadocs
jadocs's Avatar
Quoted: 282 Post(s)
I recommend a sweat band for your head and a sweat shield for your bike. You can make one out of an old towel.
jadocs is offline
Old 06-11-19, 10:04 AM
PepeM
PepeM's Avatar
Quoted: 2609 Post(s)
Liked 51 Times in 22 Posts
Some bikes used for Zwift don't even have a rear wheel!
PepeM is offline
