Three broken spokes. Should I give up on the wheel?
Old 06-15-19, 02:33 PM
gary10509
Bikes: 2015 Giant Defy Advanced 1, 2014 Trek 7.4 FX, 2010 Giant Defy 3, 1984 Schwinn Voyageur
Quoted: 5 Post(s)
2014 Trek FX 7.4 hybrid bike with Bontrager Nebula 32-hole rims. The bike has between 3 and 4k miles on it. Broke a spoke on the front wheel last fall. Had it replaced at LBS. Broke a spoke on the same wheel in April. Had it replaced. Broke another spoke on the same wheel about two weeks later. Rather than having the third broken spoke replaced, I replaced the wheel. All three spokes broke while riding on smooth city streets, within a few hundred miles at most.
I'd really like to have the wheel repaired, but should I? I've not had a problem with broken spokes on any other bike. Is this indicative of a wheel problem, or just bad luck? Would you fix it or not?
Thanks.
gary10509 is offline
Old 06-15-19, 02:38 PM
wgscott
Occam's Rotor
wgscott's Avatar
Bikes: Steel
Quoted: 2366 Post(s)
Liked 213 Times in 132 Posts
If the rim and hub are ok, and worth something, have the wheel rebuilt with new spokes. But if you already replaced it, and the old wheel isn't of any use to you, just keep it for the hub and rim if you have room to store spare parts.
wgscott is offline
Old 06-15-19, 03:16 PM
Bill Kapaun
Bill Kapaun's Avatar
Bikes: 86 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 661 Post(s)
Liked 26 Times in 22 Posts
It sounds like a bad batch of spokes and/or possibly bad build.
New spokes & a competent build and it would be better than new.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 06-16-19, 06:57 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 346 Post(s)
Liked 44 Times in 29 Posts
Agree
Moe Zhoost is offline
Likes For Moe Zhoost:
Old 06-16-19, 07:52 AM
DaveSSS
Bikes: Look KG461, Colnago C-RS
Quoted: 91 Post(s)
Liked 12 Times in 9 Posts
I'd compare the cost to rebuild to the cost for a new wheel. LBS labor isn't cheap and you could pay more for a rebuild than a new front wheel of similar quality.
DaveSSS is offline
Likes For DaveSSS:
Old 06-16-19, 09:12 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
thousands of miles of wire goes into making spokes some flaws are inevitable ...
ever thought you would like a dynamo hub front wheel, for lights in the dark seasons ?
this might be the time to buy it, now, rather than keep fixing your current front wheel..
fietsbob is offline
Likes For fietsbob:
Old 06-16-19, 02:27 PM
Brocephus
Professional amateur
Brocephus's Avatar
Bikes: Does a Big Wheel count ?
Quoted: 173 Post(s)
Liked 25 Times in 21 Posts
My thoughts exactly. A 4th spoke replacement is just good money after bad, (been there), and it's only worth a full re-build if it's a fairly high-end hub and rim (I haven't looked up that bike, but being a hybrid bike, I'm thinking it probably ain't).
A full re-build, with some quality spokes, is probably gonna cost around $80, and you'll still just have a (I assume) low-end wheel.
For around twice that money, you can get a complete (matching) wheelset from someplace like BicycleWheelWarehouse, with better Shimano hubs, and some Sapim or DT spokes, which might be a good idea. If you're popping spokes on the front (kinda unusual), then I wouldn't be surprised if the rear wheel isn't far behind.
Brocephus is offline
Likes For Brocephus:
Old 06-16-19, 04:37 PM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 74 Post(s)
Liked 5 Times in 4 Posts
Unusual on a front wheel so likely it's badly built.
New wheel.
blamester is offline
Likes For blamester:
Old 06-17-19, 09:09 AM
pdlamb
Quoted: 968 Post(s)
Liked 36 Times in 26 Posts
Agreed.
Material flaw might cause one spoke to break. After the third failure (and an accelerated rate), you've probably got a cheap machine-built wheel with undertensioned spokes. The spokes have cyclic stressed, and many if not all the original spokes are close to failure.
If you want to tackle this yourself, tighten all the spokes a quarter turn (if you're a musician, see if they're now near an A above middle C). Put on some heavy gloves, and squeeze the dickens out of adjacent pairs on each side. If more break, replace and re-squeeze until the wheel is solid. That's not economically viable if you don't do it yourself.
It's worth asking the source of your new wheel if they checked the tension. Probably not, and it would be well to get a competent wheel builder to properly tension and stress-relieve the new wheel. (Once you've found that competent builder, you might get him or her to check on your rear wheel, too.)
pdlamb is offline
Likes For pdlamb:
Old 06-17-19, 10:51 AM
Bill Kapaun
Quoted: 661 Post(s)
We never did ask where the spokes were breaking, but assumed it was at the elbow.
All of the other spokes have gone through the same number of fatigue cycles, although some probably weren't "over stressed" as much.
Keep in mind, 3-4k miles probably isn't that bad for a machine built wheel.
Before rebuilding with this rim, make sure the brake tracks have enough "meat" to justify.
Lay a straight edge across the brake track and see if it is concave. If you can see daylight.....
The point about having the tension checked on the rear (and new front) is very valid. If the wheels had been properly tensioned when new, you'd probably still be riding them without issue.
Old 06-17-19, 07:38 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1163 Post(s)
Liked 32 Times in 24 Posts
Are you lucky!
This is your big chance to learn to build your own wheels. That's what I would do. Actually, that's how I got started building wheels.
Retro Grouch is offline
Likes For Retro Grouch:
Old 06-19-19, 11:40 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 327 Post(s)
Liked 64 Times in 45 Posts
There are three parts/sub-assemblies that make up a wheel - rim, hub, and spokes. The wheel is not trash, but the spokes are.
Wilfred Laurier is offline
Likes For Wilfred Laurier:
