what happens after chain slip off chainring while riding
Old 06-15-19, 05:37 PM
mtb_addict
Quoted: 3011 Post(s)
Liked 30 Times in 26 Posts
curious since i just switched to single chainring only.
i read if i delete the FD, the chain might fall off while shifting.
so, it is benign event?
or will greasy chain wrap around my foot and sully my shoes?
or will chain drop into the spokes and explode?
what is the risk of FD delete?
mtb_addict is offline
Old 06-15-19, 06:14 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3579 Post(s)
Liked 153 Times in 114 Posts
If you're using a narrow-wide chainring, the chain isn't coming off. If you're using a "normal" chainring and some kind of keeper, the chain isn't coming off.
If you're using a normal chainring and no keeper, if the chain comes off you can usually pedal the chain back on-- unless the chain dropped to the inside and wedged itself against the BB or crank spider.
Drop to the inside, shift to a smaller cog and pedal the chain back on. Drop to the outside, (usually) just pedal it back on.
DrIsotope is offline
Old 06-15-19, 07:13 PM
mtb_addict
If you're using a narrow-wide chainring, the chain isn't coming off. If you're using a "normal" chainring ...
i oreded a Shimano SG 53t chainring from Ebay. is this the type that will come off?
Old 06-15-19, 07:15 PM
mtb_addict
so it sounds like nothing catastropic is going to happen even if it comes off.
Old 06-15-19, 07:18 PM
Marcus_Ti
Frozen Solid.
Marcus_Ti's Avatar
Quoted: 1921 Post(s)
Liked 55 Times in 36 Posts
The entire Team Aqua Blue Sport racing squad (only UCI squad to use SRAM 1X, and used NW rings), would challenge this assertion....probably with some foul language
It can cause frame damage to carbon frames or wheel damage.
Marcus_Ti is offline
Old 06-15-19, 07:21 PM
GrainBrain
GrainBrain's Avatar
Quoted: 639 Post(s)
Liked 32 Times in 21 Posts
Yes. Erm, maybe? Lookup Narrow Wide rings. Or, find older rings from the mid 80s that have just a plain tooth profile.
GrainBrain is offline
Old 06-15-19, 07:27 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
I don't mention anything about racing in a non-racing context, because what happens in a race is meaningless outside of that race. Racers beat their equipment to death through a combination of ignorance, apathy, and desire to win above all. What happens to racers in a race is meaningless to 99% of us.
I've never dropped a chain with 1X. I've dropped chains on 2X, inside and outside, countless times. If the implication here is that 1X drops chains with anything approaching the frequency of 2X, that is simply false.
That's a normal outer ring for a 2X or 3X crank (pins for shifting) so you would want some type of chain retention device if you want to ensure you don't drop a chain. Lots of bolt on and clamp on chain keepers out there. I use one from Paul Components, a little pricey but exceptionally well made.
Old 06-15-19, 07:29 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1141 Post(s)
Liked 20 Times in 19 Posts
You bought the wrong thing. That is a standard road chainring intended for a double crank and a front derailleur. It will not be secure enough for use without a front derailleur. In fact it has shifting ramps and teeth shaped specifically to assist shifting.
Look up "narrow-wide" chainrings intended for 1X drivetrains and buy one of them.
HillRider is offline
Old 06-15-19, 08:49 PM
Gresp15C
Gresp15C's Avatar
Quoted: 629 Post(s)
Liked 29 Times in 25 Posts
My yellow bike has a 1x drivetrain and a "wrong" chainring. Yeah, the chain falls off. I looked up the narrow-wide ring, and it makes sense, but I just haven't bothered with it yet. Meanwhile, I developed a pretty good sense of the conditions that cause the chain to fall off, namely back-pedaling in the longer gears, so I just don't do that any more and it's been OK. Usually it just goes slack and hangs there until I slow down and stop, then I find something by the road, like a stick, and push it back on.
Gresp15C is offline
Likes For Gresp15C:
Old 06-15-19, 08:58 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 3888 Post(s)
Liked 58 Times in 43 Posts
If you're stomping on a pedal when the chain drops, very bad things are apt to. happen
LesterOfPuppets is offline
Likes For LesterOfPuppets:
Old 06-16-19, 04:31 AM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 74 Post(s)
Liked 5 Times in 4 Posts
You can have a very bad fall if it happens at the wrong time.
blamester is offline
Old 06-16-19, 06:50 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 343 Post(s)
Liked 44 Times in 29 Posts
Ride what you have for a while to see if you have any issues. It's likely that chain drops will be infrequent if you are riding on relatively smooth surfaces and your RD puts sufficient tension on your chain (you probably have to remove a few links when you go single in front). Chain drops are not likely to be dramatic, although I had once one that confounded my ability to sort out). Because of that single incident I opted for a narrow-wide ring, even though I had over a thousand miles without incident.
Good luck.
Moe Zhoost is offline
Old 06-16-19, 07:40 AM
FiftySix
where's the gas tank?
FiftySix's Avatar
Bikes: Norco Cityglide, Schwinn Jaguar, Schwinn Willy
Quoted: 221 Post(s)
Liked 92 Times in 70 Posts
Same experience here. Don't backpedal to gain ground clearance while riding over something that bounces the bike harshly.
Otherwise, the chain drops and in my case it tends to go between the frame and the chainring/crank.
FiftySix is offline
Old 06-16-19, 07:48 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1260 Post(s)
Liked 45 Times in 31 Posts
Don't let these bikers fool you. If you drop a chain, you WILL end up in the hospital.
trailangel is offline
Old 06-16-19, 09:05 AM
FiftySix
FiftySix's Avatar
Quoted: 221 Post(s)
I haven't had that happen yet. Granted, the chain drops I've had didn't jam in the spokes and stop the rear wheel from freewheeling.
FiftySix is offline
Old 06-16-19, 09:17 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 212 Times in 177 Posts
Its a 'spoke protector' unless you feel superior, to your mates , then its a 'dork disk'..
fietsbob is offline
Likes For fietsbob:
Old 06-16-19, 09:22 AM
LesterOfPuppets
Bikes: everywhere
It doesn't have to be hospital all the time, but a couple of knee-to-stem and knee-to-bar incidents have had me wishing I was skipping the hospital and headed straight for the undertaker.
Old 06-16-19, 09:28 AM
LesterOfPuppets
Bikes: everywhere
That's not required to get you a trip to the ER. It could be your foot comes off the pedal as the chain drops and frees up your cranks, then your knee hits the stem and your foot gets trapped in front of the pedal, while your hands slip off the bar and you start to tumble face first for the ground.
Old 06-16-19, 09:39 AM
FiftySix
FiftySix's Avatar
Quoted: 221 Post(s)
I haven't had that scenario playout yet.
Probably because my chain drops were while back pedaling over hard bumps and and the chain locked up the cranks immediately when resuming forward pedal power. It basically turns my bicycle into a motorcycle with footpegs, but no throttle. So, I'd brake or coast to a stop and reinstall the chain. Only harm to myself was riding away with greasy hands.
I know not every chain drop would be the same for everyone, but I do know that a chain drop is not a guaranteed trip to the hospital.
FiftySix is offline
Old 06-16-19, 09:45 AM
LesterOfPuppets
Bikes: everywhere
Yep, backpedaling and light pressure forepedaling incidents are typically less dramatic.
Foot retention can also help to reduce likelihood of a bad situation, but not prevent such situations - I've kneed stems with SPDs on.
Old 06-16-19, 10:26 AM
Gresp15C
Gresp15C's Avatar
Quoted: 629 Post(s)
Don't worry. Try as I might, I haven't fooled anybody yet.
I should have noticed the OP's user name. I'm almost 100% pavement cyclist, with occasional forays into the woods. I know what my bikes are capable of. The times when I've dropped a chain on my particular bike have been under no load. Honking up a hill on the smallest cog is something that I'm not strong enough to do anyway. Likewise with the dreaded no-gear on the old Sturmey Archer AW hub. You had to be a fairly athletic cyclist to even be at risk of that failure mode.
But if @mtb_addict is talking about riding an actual MTB under rugged trail conditions, that's not my bailiwick.
Gresp15C is offline
Old 06-16-19, 10:39 AM
mtb_addict
no, i am talking about road biking.
i rarely do mtb anymore.
which reminds me i did do a very techical trail once, full of roots and rocks.
i was riding a converted single-speed with a very bad chainline.
the chain came off every time the back wheel hit a root hard.
but since, i was usually going walking speed, i just step off, but sure someone not as agile as i am might fall hard.
i did recall thinking if the chain gets jammed into the frame in bad way, then i was for sure walking back to the car.
then, i converted that mtb to 1/8" chain and chainring...corrected the chainline with a new wheel...and it never dropped a chain afterthat.
Old 06-16-19, 11:02 AM
HillRider
All of this debate on the consequences of a chain drop; inconsequential, minor, bad, very serious and life-threatening, would be moot if you just use the proper chainring. Narrow-wide chainrings are readily available and not very expensive. Buy the right thing and be done with it.
Old 06-16-19, 11:35 AM
LesterOfPuppets
Bikes: everywhere
Even a non-NW single speed ring might do for light pressure seated pedaling.
Old 06-16-19, 12:20 PM
FiftySix
FiftySix's Avatar
Quoted: 221 Post(s)
Curb hopping will make a single front chainring's chain come off on a bike with a rear derailleur. Just don't backpedal to level the pedals for ground clearance during the curb hop. Get the pedals set before the hop and landing, then pedal away.
Or, get an internal gear hub bike with a single rear sprocket to go with that single chain ring.
FiftySix is offline
