I've got a 27" wheel and it won't be true...
Old 06-16-19, 09:31 AM
mmcc73
Quoted: 23 Post(s)
... according to the LBS mechanic. I took it in the other day and he said he wasn't able to get it round.
Here's a video:
It seems good laterally, but it has a couple low spots.
Is this anything to be concerned about? My inclination is just to keep riding on it.
This is a rear wheel on a mid 70's Dawes Galaxy. It is a Weinmann rim (aluminum, or at least non magnetic) on a Shimano large flange hub.
mmcc73 is offline
Old 06-16-19, 09:35 AM
scarlson
Bikes: Ron Cooper touring, 1959 Jack Taylor 650b super touring tandem, Vitus 979, Joe Bell painted Claud Butler Dalesman, Colin Laing curved tube tandem
Quoted: 46 Post(s)
Liked 29 Times in 22 Posts
The braking might be a little lumpy, but as long as the pads don't go into the tire, there's no reason not to just use it. I've used much worse for various amounts of time.
scarlson is offline
Likes For scarlson:
Old 06-16-19, 09:42 AM
sdn40
Bikes: 88 Cannondale Criterium
Quoted: 194 Post(s)
Liked 26 Times in 19 Posts
I'm sure someone much smarter than me can speak more intelligently, but unless you are going to the Salt Flats to break a land speed record, take it for a ride and use your best judgement. You may never reach speeds to notice the imperfections. If you do - re-evaluate
sdn40 is offline
Likes For sdn40:
Old 06-16-19, 09:45 AM
mmcc73
Quoted: 23 Post(s)
I'm not terribly concerned about speed - I'm more concerned about catastrophic failure. I take it that isn't really an issue?
mmcc73 is offline
Old 06-16-19, 10:03 AM
sdn40
Quoted: 194 Post(s)
In my non-expert opinion, it's all about speed. The wheel is sound until the speed is reached which reveals the imperfection. I don't know what speed that is. Your best judgement should be good enough. If you start feeling weirdness - it's too fast for that wheel. I think it's splitting hairs though.
sdn40 is offline
Old 06-16-19, 10:08 AM
BradH
Catching Smallmouth
BradH's Avatar
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 36 Post(s)
Liked 3 Times in 2 Posts
A song popped into my head as soon as I read the title.
I wouldn't worry about that. You won't even feel it.
BradH is offline
Likes For BradH:
Old 06-16-19, 10:14 AM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 70 Post(s)
Liked 5 Times in 4 Posts
I've got a worse wheel on the front of one of my bikes right now. It appears the rim is literally bent. I've gotten over 30 MPH coming down a hill with it and never noticed any wobble or wumping. It's annoying to watch though as you ride and it makes me want to tweak on it all the time. But as far as catastrophic failure, what are you expecting to happen?
Bigbus is offline
Old 06-16-19, 11:48 AM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Bikes: 1977 Trek TX700; 1978/79 Trek 736; 1984 Specialized Stumpjumper Sport; 1984 Schwinn Voyageur SP; 1985 Trek 620; 1985 Trek 720; 1986 Trek 400 Elance; 1987 Schwinn High Sierra; 1990 Miyata 1000LT
Quoted: 1708 Post(s)
Liked 45 Times in 35 Posts
I got a 27" wheel that wants to ball all day
I got a 27" wheel that stay drunk all the time
Hey, hey, what can I do?
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Likes For The Golden Boy:
Old 06-16-19, 12:06 PM
GrainBrain
GrainBrain's Avatar
Quoted: 640 Post(s)
Liked 32 Times in 21 Posts
That's not bad at all, I wouldn't worry. Of course you could walk the town - keep a searchin' all around - lookin' for a street corner wheel.
GrainBrain is offline
Likes For GrainBrain:
Old 06-16-19, 12:38 PM
PilotFishBob
My brain hurts!
PilotFishBob's Avatar
Bikes: A ridiculous number
Quoted: 274 Post(s)
Liked 19 Times in 16 Posts
Just name the wheel Maybellene and get it over with.
PilotFishBob is offline
Likes For PilotFishBob:
Old 06-16-19, 12:57 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 535 Post(s)
Liked 19 Times in 19 Posts
Unless that rim is being made more round by means of uneven spoke tensions, It looks perfectly serviceable to me and I doubt that I would notice it ever.
In some cases, a mounted tire may either help or exacerbate a rim's out-of-round condition, depending on how the tire is positioned rotationally, so you could try moving the tire around if the out-of-round condition is worse at the tire tread than it is at the rim.
A rim's durability is hugely dependent on the uniformity of spoke tension and on the weight loading, so as the weight loading is increased then a higher standard of spoke tension uniformity should be applied. With some bent rims, a limit is reached here and the correct action would be to replace the rim, especially with single-walled or lighter weight rims and/or with lower spoke counts.
dddd is offline
Old 06-16-19, 01:15 PM
mmcc73
Quoted: 23 Post(s)
It sounds like the answer to (hey hey) what should I do is nuthin. That is my favorite kind of advice.
Thanks!
mmcc73 is offline
