Campy brakes?
Campy brakes?
Old 07-23-08, 03:22 PM
Traveller1
Campy brakes?
Just bought a new bike with full Campy Chorus. I had Shimano on the old rig and knew how to release the brakes to change a flat. The campy brakes don;t have the lever. Do you have to release the brakes to perform a flat repair?
Traveller1 is offline
Old 07-23-08, 03:31 PM
testtube
The brake release is on the brake lever. There's a small cylinder in the horizontal plane on the outside (front facing) edge of the actual lever above the pivot. Snap that little guy to the other side and the levers will allow the brakes to open up. Do the opposite (might have to compress the lever) to close the brakes.
Keep in mind that sometimes a builder will setup with brakes with the brake lever release open. If snapping the little guy doesn't seem to allow the brakes to open up this might be the issue... You'll have to release the cable from the brake and readjust them with the release closed.
t.
testtube is offline
Old 07-23-08, 03:35 PM
Traveller1
Thanks! I just tried this, and of course just as you said the brakes openned up!
Old 07-23-08, 08:32 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1143 Post(s)
Liked 24 Times in 22 Posts
I have a bike with Campy Ergo brifters and Shimano Dura Ace brakes. The beauty of this arrangement is I have brake quick releases on both the brake calipers and the brake levers. Open both and the brakes will clear nearly anything.
HillRider is offline
Old 07-23-08, 09:26 PM
Mentor58
'Mizer Cats are INSANE
Mentor58's Avatar
Bikes: C-dale T800
If I'm tracking right, if you went the OTHER way you would be out of luck entirely, in that case neither the Brakes (Campy) or the Levers (Shimano) would have a way to release tension. ???
M58
Mentor58 is offline
Old 07-23-08, 09:39 PM
Indolent58
Queen of France
Indolent58's Avatar
Bikes: Look 565, Trek 2120
M58
Correct.
Indolent58 is offline
sallen73
Classic & Vintage
3
10-14-18 09:21 AM
David_T
Introductions
1
07-27-13 06:15 AM
ilikebikes
Foo
0
08-18-08 02:38 PM
