Reflective tape
Quoted: 358 Post(s)
Liked 136 Times
Reflective tape
Is it better to put one color of reflective tape on your bicycle? Is it much more eye-catching to put different colors on so the cars can see you in the darkness better?
Liked 6 Times
I've only seen information about brightness, and it appears that white is the brightest. See: Which Retro Reflective Tape Is The Brightest ? | Retro Reflective Tape | Retro Reflective Tape
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Bikes: Motobecane
Registered User
Bikes: NA
Quoted: 9 Post(s)
Liked 7 Times
i find the white and yellow reflective tape to be incredibly garish and would never think about putting that stuff on my nude black commuters.
3M Scotch Scotchlite Reflective Striping Tape at FindTape.com
I'm Rad.
Bikes: 2008 Allez (Sold), 2009 Surly LHT (Sold), 2014 Motobecane Fantom Cross Pro
I'm in the process of ordering this stuff:
Streetglo - Invisible high intensity white reflective black tape strips kit for black motorcycle frames, bicycles or other vehicles.
I had it before on my Surly LHT fenders and the reflective tape is legit, it looks black like fenders (gloss). When you shine a flashlight on it, it turns bright white (like the 3m reflective tape). If you're looking for something you can use on a something that's black so it matches your gear, this is the stuff to get.
V
V
contiuniously variable
I vote for white/silver tape. Reflects full spectrum, so it would be more visible.
- Andy
- Andy
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
This is the stuff I used:
Amazon.com: Motorcycle Reflective Safety Tape - Black Adhesive. RTK-03A: Home Improvement
Quoted: 39 Post(s)
From reading through that reference, it seems that the "type" of reflective tape is by far the most important aspect, and then color is secondary. Using a mix of white and yellow colored pieces of Metalized micro-prismatic reflective tape would give you a huge sight distance advantage over cheaper tapes.
I use both red and white on my bikes, the white is definitely brighter, but not by a huge amount.
This is the go-to thread for these questions:
https://www.bikeforums.net/commuting/...down-road.html
I was going to re-post one of the pics of my bikes from that thread, but for some reason my picture links are dead. I'll have to see if I can resurrect them.
Registered User
Bikes: NA
Quoted: 9 Post(s)
Liked 7 Times
There's black reflective tape. I put it on my girlfriends black city bike, and it's near invisible until light hits it.
DancesWithSUVs
Quoted: 7 Post(s)
I've always ordered from these guys:
Identi-Tape - All Kinds of Colored Tape
Huge selection of choices,and smaller rolls than most places.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Upgrading my engine
Quoted: 125 Post(s)
I'd focus more on where you put it. It really catches your eye on moving parts (rims, cranks, your ankles, etc.).
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Identi tape store is great, but costs a fortune as you have to buy in bulk. Its OK if you just want one color.
What I often do is go to the automotive parts store and get the same stuff in smaller quantities. Colors are red, and the red/white stripe you see on most commercial vehicles.
That Black tape is not bright at all. I have some, but it is near worthless compared to white.
The black stuff glows about as bright as a license plate, or a bit less. The white tape is blinding compared to it.
Still, none of it does any good unless a car light is shining directly at it.
Prefers Cicero
Wouldn't you want red on the back and white on the front?
Bikes: Bicycle!
I recommend Reflexite REF-DB Retroreflective V92 Daybright Tape, found on Amazon. I use it on my commuter. It is very bright! It comes in several different colors. I ordered the silver/white and red. Be sure you know exactly where you want to lay it because it is difficult to remove. The tape has been on my commuter/winter bike for two years, and at this point the fraying tape needs to be removed and replaced.
Liked 415 Times
Yep, I cut it up, with white on the front, and red on the back.
Realistically though, the color doesn't make much difference, what is important is that they see you. Just look at trucks, they use the automotive stuff and it is red/white striped.
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
That works by absorption of a specific wavelength/s of light, while emitting the remaining wavelength/s. This does not necessarily reduce the amplitude of the reflected light energy but rather just changes what color you see.
Just saying that the color overlay is a filter layer over the silver-white glass particles that reflects the light.
Quoted: 39 Post(s)
Side by side, the white reflective tape is clearly a little brighter than the red reflective tape of the exact same type, from the same manufacturer/batch.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
You might want to look at this report https://www.cpsc.gov//PageFiles/117813/BikeReport.pdf.
This little snip from the conclusion provides a good summary
The results of the study showed that there was no statistically significant difference in performance among the various reflector treatments and the current CPSC regulation reflectors.
Therefore, improvement to the existing reflector requirement does not appear warranted. The parallel path crash simulation showed that the flashing red LED taillight used in the evaluation could significantly improve a driver's detection distance over the CPSC regulation reflectors.
Bikes: Custom 531ST touring, Bilenky Viewpoint, Bianchi Milano, vintage Condor racer
For example, see 3M's specs for 983 "Diamond grade" reflective tape for the difference in coefficients of retroreflectivity. Yellow is a little bit less efficient than white, but red is much lower.
https://multimedia.3m.com/mws/mediawe...-&fn=PB983.pdf
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,430 Times
I spent a few dollars on a 5' roll of 3M "Conspicuity" tape off fleabay (yellow, which was kind of greenish), and my choice was to attract attention by chopping it up into a message. Here's what drivers see hanging off my left rack:
BTW the white bands top and bottom are cut from a safety vest I found lying in the road. I stuck those on with duct tape.
