pros and cons of tubular tires vs. clincher
Old 03-28-05, 12:29 PM
d-new
Bikes: bianchi eros
hi,
great forum you have here. stupid newbie question. whats good and bad about tubular tires vs. clinchers. i know a little(started riding in december) but not which is better and also have any of you heard of these TUFO clincher/tubulars?
http://tufonorthamerica.com/tiretypes.php
d-new is offline
Old 03-28-05, 12:39 PM
ShinyBaldy
Tubulars
Pro
- the lightest practical tubulars will always be lighter than the lightest clincher
- if you flat, you can ride on it for a little longer
- if glued properly and the tire will stay on the rim even if it flats
- ride quality
Con
- costs more (rims, tubulars)
- more difficult to maintain/repatch as an individual without team support on the road
- you could get tire/rim seperation, esp when rims are hot from braking and end up like Beloki.
Clincher
Pro
- cheaper
- more common
- wheels are more common
- easier to patch on the road, no need for gluing, stretching tire, etc
Con
- if you flat, you can't really ride on it
- some say a lower quality ride
- will always be heavier (tube, tire, clincher interface)
The ride quality and weight differences are getting smaller, but will always continue to be there. Esp with carbon wheels - carbon clinchers are more difficult to make... and will be heavier than their carbon tubular rim counterparts.
I've heard of TUFO tubular clinchers... altho I don't see the point of them. Listening to the experiences and advice of others, they only seem to make sense for things like cyclcross... allowing you to run at lower pressure? sorta like a tubeless clincher for MTB. But why use it on a road bike? They're not necessarily lighter, cost a lot more, requires liquid sealant to patch? *shrug* But a lot of people love them so they must offer something - so listen to their input too.
ShinyBaldy is offline
Old 03-28-05, 12:42 PM
lotek
lotek's Avatar
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 9 Post(s)
d-new.
Ok, this is right up there with Campy v shimaNo, in terms of controversy.
To set the record straight I ride tubulars almost exclusively so I'm a
bit biased.
first do a seach here for Tubulars there are quite a few threads.
If you flat on a tubular the tire stays on the rim
(usually there are rare cases where you roll a tubular), if you are on a
downhill or riding fast its easier to maintain control. On rare occaisions
you can ride a flatted tubular home and not kill your rims (but I don't
recommend it). This doesn't work with clinchers, you end up with rim on
road which is not a good thing.
Clinchers by design make it easier to repair/replace tubes on the road.
with a Tubular you need to cut threads, repair the tube then sew up the
carcass.
Tubulars are easier to change on the road, break the seal, roll the old
tire off, stretch new tire on center it, pump it up and away you
go (and NEVER go out without spare tubular or repair kit).
Clinchers are cheaper that tubulars. Good tubulars can be very expensive
(I think there is one that is $300 per tire but its a track only tire).
Cheap Clinchers are better than cheap tubulars.
The Tufo tubular clincher is the best of both worlds in terms of
a clincher rim with a beaded tubular tire, btw Tufo's are NOT repairable
if the sealant does not work, sol.
Tubulars do not pinch flat.
I've said enough for now. I'm sure others will chime in shortly
from both sides of the camp.
Marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
lotek is offline
Old 03-28-05, 12:44 PM
R600DuraAce
I really miss my Chris King hub/Reflex rim tubular wheelset and Zipp 303 tubular because I have been racing/training/riding with my Powertap SL wheels. They are clincher.
Originally Posted by d-new
hi,
R600DuraAce is offline
Old 03-28-05, 12:45 PM
skydive69
skydive69's Avatar
Bikes: Guru Geneo, Specialized Roubaix Pro, Guru chron 'alu, Specialized Sequoia
hi,
The above post leaves out the reason I have tubulars on my race bike - they are faster, and you can pump them up to much higher pressures. Of the Pros that I know, I don't know one who rides on clinchers.
I use clinchers for my training bike, because tubulars are too expensive, and too much a pain in the butt (and expensive) to change.
skydive69 is offline
Old 03-28-05, 12:46 PM
53-11_alltheway
"Great One"
53-11_alltheway's Avatar
Location: Might as well be underwater because I make less drag than a torpedoE (no aero bars here though)
I really like the Tufo tubular clinchers. I like pumpin' my tires up to high psi though.
Compared to tubulars they weigh more, but they don't have the glue problem that supposedly increases rolling resistance due to tire squirm on the tubular rim.
The Tubular clinchers are very easy to mount and I believe safer than a regular clincher during a blow-out at high speed.
53-11_alltheway is offline
d-new
Bikes: bianchi eros
thanks shinybaldy,
thanks for the info
d-new is offline
Old 03-28-05, 12:49 PM
netso
I like tubulars. They ride better, and very easy to change if you get a flat. I just carry a spare (already stretched), and some glue. You can also ride when they go flat.
netso is offline
Old 03-28-05, 12:50 PM
d-new
Bikes: bianchi eros
thanks everyone for your imput!!!
d-new is offline
Old 03-28-05, 03:02 PM
fogrider
Bikes: Ron Cooper, Time VXSR, rock lobster, rock lobster, serotta, ritchey, kestrel, paramount
Note that Beloki's tire did not roll off. this has been an issue that has been discussed extensively and if it did roll, he would have just slid and laid down the bike and he would not have landed the way he did.
fogrider is offline
Old 03-28-05, 03:16 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 23 Post(s)
Liked 5 Times in 5 Posts
General riding - clinchers.
Racers - tubulars.
operator is offline
Old 02-19-08, 10:05 AM
defoorr
Bikes: Specialized S-Works E5
Safety of Tubulars
Hi Folks,
Another newbie question about tubulars. I am 6ft tall, 185lbs and race CAT3. Always have used clinchers in the past, but recently bought my first set of carbon tubulars. Do you think there is any danger of the tires rolling off in fast, hard corners due to the fact that I am heavier than the average racer - assuming the tires are glue properly?
Thanks,
Rob
defoorr is offline
Old 02-19-08, 10:13 AM
cslone
Quarq shill
cslone's Avatar
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
There's always a chance, but not if they're mounted correctly.
cslone is offline
Old 02-19-08, 10:31 AM
ZeCanon
Writin' stuff
ZeCanon's Avatar
I ride a set of box-section (ambrosio f20 and an old gel280) tubulars in crits and a set of deep carbon tubulars in road races. For crits, I prefer the round, lower profile of good tubulars for cornering, plus they are light as hell and spin up fast. Tubulars make for a much lighter wheel, they are more comfortable, and "feel" faster.
I train exclusively on clinchers, because both of my tubular setups are race-only, very light wheelsets and because carrying an extra tub with you on a training ride is just a pain the as$. Plus I train with a powertap laced to a clincher rim.
ZeCanon is offline
Old 02-19-08, 11:14 AM
Smorgasbord42
A better compromise, IMO, are the so-called "open tubulars" like the Deda Corsa RS or Vittoria Open Corsa CX. These are clinchers that mount on clincher rims, but the tread side is built like a tubular. They have a high tpi (threads per inch) of 290, and you can run a high psi - up to 145. If you ride-compare them side by side to other tires on the same bike/wheels you'll never run anything else - if you can afford them. They're not cheap and they don't last very long. Here's a couple of links:
http://www.cyclingnews.com/tech.php?...datre_rs_corsa
http://www.bikeforums.net/archive/in.../t-378247.html
And here's a cut-away pix:
Smorgasbord42 is offline
Old 02-19-08, 11:39 AM
skydive69
skydive69's Avatar
Hell, I can hardly get them off when I want to. I happen to use glue on my Zipp 999 set which are on my time trial bike, but I use Tufo extreme tape on my road bike to mount my tubulars. I changed a tire yesterday, and I finally had to cut the damn thing off it was so hard to even begin to remove. I can't imagine that these things would ever roll off if mounted properly. I just wish I had a better method to get them off!
Old 02-19-08, 02:34 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 798 Post(s)
Liked 30 Times in 22 Posts
Originally Posted by defoorr View Post
Hi Folks,
Thanks,
Rob
No problem
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 02-19-08, 03:18 PM
logdrum
Headset-press carrier
logdrum's Avatar
Bikes: Kona with Campy 8, Lynskey Ti with Rival, Bianchi pista, Raleigh Team Frame with SRAM Red, Specialized Stump Jumper, Surley Big Dummy
Here in the High desert and Southwest, we have these pesky thorns called "goatheads", They will go ttrough any tire at some point, but Conti Vectrans and Gatorskin and the Armadillos resist them farily well but I still use tufo or stan's sealant. If you ride through broken glass and then through goatheads, there is a grater chance for your tire to be punctured by goatheads before the glass. A glass may tear the thread but a goathead is guaranteed to go through.
I still use tubulars, because ,my bike came with 2 tubular wheelsets and 1 more pair with no freehub body. I use tofus but now using Conti Sptinter Gatorskins and the Vectrans. Most of tofu's work too but you have really to get them inflated at higher PSI.
Here's what I found... My traditional looking wheels Mavic SUP and some really light Campy rims are better at climbing than newer clincher wheels I've tried (no carbon though) . They are also durable and hold their roundness. Plus all the benefits above. As long as I use the conti gators or vectran plus the sealant, I have zero flats most of the season. The only time that the sealant failed are when the threads got cut (this was a cheaper tufo) and if this was a clincher the inner tube would burst out of the hole anyway unless you boot the tire.
Having said that my other bikes have clinchers and I am happy with them as well.
logdrum is offline
Old 02-19-08, 03:39 PM
SoreFeet
Quoted: 17 Post(s)
Liked 6 Times in 4 Posts
If you dont have a high disposable income don't run tubulars. Clinchers offer a variety of tire sizes that are not offered with tubulars.
Unless you want to pay big bucks you can't get a wider tubular. Tufo tires are crap. I don't care what people say about them. You can't repair a tufo once it is punctured it will leak. The magic sealant might work okay but thats just more $$$
If you aren't racing stick with clinchers. Having a race only set of tubulars is logical. A 20$ clincher will be rounder than a 20$ tubular.
If you want a lighter wheel get tubulars but be prepared to spend big bucks. The main advantage of a tubular is that a flat will have more control because it is fixed to the rim.
SoreFeet is offline
Old 02-19-08, 04:01 PM
vic32amg
Registered User
Bikes: Cervelo S5 SRAM Red -
open tubulars are clinchers. don't be fooled by the terms
I switched from clincher to tubulars last summer. Have not had a flat since.
just sayin.
the ride is very nice too. yes it is noticeable. I will say that the Michelin Pro Race 2 were a nice clincher
vic32amg is offline
Old 02-19-08, 04:39 PM
vic32amg
Registered User
All of these are silly and please pay no attention to them.
I am broke and use tubulars.
for sealant you can use just about any sealant. I use stans
this is very silly
vic32amg is offline
Old 02-19-08, 05:34 PM
maddog17
Worker Ant
maddog17's Avatar
Bikes: Ted Wojcik road and Iron Horse Hollowpoint mtb
my take on tubulars vs. clinchers.... for me, when i started racing, i used clinchers. i didn't trust myself gluing a tire on a rim, just that thought alone scared me. so i stuck with clinchers. while the pro's and con's of each are good, my take on it would be are you racing or just out riding? i think needing the extra roll resistance with tubulars for racing makes sense, but not for everyday riding. if it's for price, then clinchers are cheaper. a tube is a lot cheaper than a tubular.
maddog17 is offline
Old 02-19-08, 06:51 PM
unbelievably
unbelievably's Avatar
Please correct me if I'm wrong,
but I'm in the understanding the a tubular
is less likely to puncture over a clincher.
unbelievably is offline
Old 02-19-08, 07:12 PM
operator
cab horn
Quoted: 23 Post(s)
Too bad if you do puncture, then you're ****ed. Seriously. Nobody in their right mind would ride tubulars on the street unless they're racing, or really like carrying spare tubulars with them on every ride.
operator is offline
Old 02-19-08, 07:27 PM
patentcad
Peloton Shelter Dog
patentcad's Avatar
Bikes: 2017 Scott Foil, 2016 Scott Addict SL, 2018 Santa Cruz Blur CC MTB
Quoted: 1027 Post(s)
Racers - tubulars.
It doesn't get much more complicated than that. I've been riding/racing tubies for the better part of 20 years, and I even trained on them for a time. But they are a massive pain in the ass compared to clinchers, very expensive, and between the need to repair (very difficult or a mail order project) a tubular after a flat and re-GLUE the stupid things, I mean, forget it. It's up to you, tubulars are really lighter, better riding, handling, climbing, sprinting, etc., but for most cyclists clinchers are just dandy. I have tubular racing wheels (Zipp 404s) because you just can't beat 'em for light (about 1250 grams for 58mm carbon deep section rims) wheels that are aero and super light. And because in a race, I don't carry a spare. It ain't the Giro, you flat, your race is over. But my races are 30-50 miles long, I have never punctured in a USCF event, only on training or competitive street rides. So I ride my Zipp tubies on The Nyack Ride and Park Ridge Rides here locally (local racer dude fast training rides that are like sandlot bicycle races) and for racing. So they'll see <2000 miles each season.
The rest of the time I'm on clinchers. If I didn't race I wouldn't bother with tubulars. I like them, but I don't love them enough to put up with the hassle. They are worth it for competitive riding. I can feel the difference with those Zipp tubies, particularly on the late ride cimbs when I'm on the rivet, or when my nose is in the wind @ 30mph. To be sure zero doubt. Everybody I know who rides/races similar wheels will tell you the same thing. Everybody who's too cheap to buy Zipps or light tubie wheels comes on here to tell you it's all a crock of ****. The entire pro peloton in Europe is riding this stuff. Who do you believe?
Will tubies propel you from Cat V to Cat II? No. Do they make hanging on for dear life a marginally less desperate endeavor? Yes.
patentcad is offline
